Muy buenas tardes, pues he decidio hoy pasar el vagcom para ver que fallos tenia y bueno me he llevado la sorpresa de que hay varios modulos con fallos sobre todo el 46, alguna solucion??
Muchas gracias.
Sunday,25,January,2015,18:49:47:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8E************* License Plate:
Mileage: 209370km-130096mi Repair Order:
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E********* Mileage: 209370km/130096miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 909 518 M HW: 8E0 909 018
Component: 1.8L R4/5VT 0002
Coding: 0011701
Shop #: WSC 63351 000 00000
VCID: 3A712AA876A158CE9A7-5000
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04275
Shop #: WSC 06435
VCID: 2649EED8C219CC2ECEF-5072
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 00000
VCID: 60C5B8C0E0BD621EF43-5072
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
VCID: 346D049004C5AEBE40B-4A3A
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0010602
VCID: F4ED449094456EBE00B-5000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
VCID: 36693E9812B9BCAE7EF-4A3A
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 H
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 01100
Shop #: WSC 00000
VCID: 2953E5E4D307E356E3D-5000
WAUZZZ8E********* AUZ6Z0A0366946
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBDF5FEC997BB146D11-5000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AH
Component: Komfortgerát T1B 0617
Coding: 07754
Shop #: WSC 63351
VCID: 77F7F39C553385A6A59-49D8
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
9 Faults Found:
01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00943 - Heated Exterior Mirror; Driver Side (Z4)
57-10 - Electric Circuit Failure - Intermittent
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
37-10 - Faulty - Intermittent
01331 - Door Control Module; Driver Side (J386)
01562 - Rear Right Door
61-00 - Won't De-Safe
01334 - Door Control Module; Rear Right (J389)
80-00 - Single-Wire Operation
01804 - Door Warning Lamp; Rear Right (W38)
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End ---------------------------------------------------------------------
Editado por Serjio
Borrar nº bastidor
Hay un problema en el cableado de la puerta trasera derecha a la centralita confort..Es posible que haya habido algún golpe en esa puerta y no lo hayan arreglado bien, o algún cable esta defectuoso
es la cerradura ahora lo que me sucede es otro caso que me he dado cuenta ahora con el invierno y es que el la calefacción me sale el aire templado pero cuando subo de vueltas me sale caliente, alguna idea?
