mr_ilio Publicado 25 de Enero del 2015 Denunciar Compartir Publicado 25 de Enero del 2015 (editado) Muy buenas tardes, pues he decidio hoy pasar el vagcom para ver que fallos tenia y bueno me he llevado la sorpresa de que hay varios modulos con fallos sobre todo el 46, alguna solucion?? Muchas gracias. Sunday,25,January,2015,18:49:47:65217VCDS -- Windows Based VAG/VAS EmulatorVCDS Version: 12.12.0.0Data version: 20130910VIN: WAUZZZ8E************* License Plate:Mileage: 209370km-130096mi Repair Order:----------------------------------------------------------------------------------------------------------------------------------------------------------------Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77VIN: WAUZZZ8E********* Mileage: 209370km/130096miles-------------------------------------------------------------------------------Address 01: Engine Labels: Redir Fail! Part No SW: 8E0 909 518 M HW: 8E0 909 018 Component: 1.8L R4/5VT 0002 Coding: 0011701 Shop #: WSC 63351 000 00000 VCID: 3A712AA876A158CE9A7-5000No fault code found.-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 A Component: ABS/ESP allrad 1726 Coding: 04275 Shop #: WSC 06435 VCID: 2649EED8C219CC2ECEF-50721 Fault Found:01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-10 - - - Intermittent-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AA Component: A4 Klimaautomat 1323 Coding: 00000 Shop #: WSC 00000 VCID: 60C5B8C0E0BD621EF43-5072No fault code found.-------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00011 Shop #: WSC 63351 VCID: 346D049004C5AEBE40B-4A3ANo fault code found.-------------------------------------------------------------------------------Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 Component: Airbag 8.4E 5001 Coding: 0010602 Shop #: WSC 63351 000 00000 VCID: F4ED449094456EBE00B-5000No fault code found.-------------------------------------------------------------------------------Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00011 Shop #: WSC 63351 VCID: 36693E9812B9BCAE7EF-4A3ANo fault code found.-------------------------------------------------------------------------------Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 900 H Component: KOMBI+WEGFAHRS. RB4 D26 Coding: 01100 Shop #: WSC 00000 VCID: 2953E5E4D307E356E3D-5000 WAUZZZ8E********* AUZ6Z0A0366946No fault code found.-------------------------------------------------------------------------------Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0604 Coding: 00001 Shop #: WSC 00000 VCID: EBDF5FEC997BB146D11-5000No fault code found.-------------------------------------------------------------------------------Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 AH Component: Komfortgerát T1B 0617 Coding: 07754 Shop #: WSC 63351 VCID: 77F7F39C553385A6A59-49D8 Subsystem 1 - Part No: 8E1959801B Component: Tõrsteuer.FS BRM 0002 Subsystem 2 - Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0002 Subsystem 3 - Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0002 Subsystem 4 - Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0002 9 Faults Found:01616 - Signal Wire to Interior Monitor 49-10 - No Communications - Intermittent01370 - Alarm triggered by Interior Monitoring 35-00 - -00943 - Heated Exterior Mirror; Driver Side (Z4) 57-10 - Electric Circuit Failure - Intermittent01811 - Supply Voltage for Door Controller; Drivers Side (J386) 37-10 - Faulty - Intermittent01331 - Door Control Module; Driver Side (J386) 49-10 - No Communications - Intermittent01562 - Rear Right Door 61-00 - Won't De-Safe01334 - Door Control Module; Rear Right (J389) 80-00 - Single-Wire Operation01804 - Door Warning Lamp; Rear Right (W38) 57-10 - Electric Circuit Failure - Intermittent01814 - Supply Voltage for Door Controller; Rear Right (J389) 37-10 - Faulty - IntermittentEnd --------------------------------------------------------------------- Editado 25 de Enero del 2015 por Serjio Borrar nº bastidor Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Carlisu84 Publicado 25 de Enero del 2015 Denunciar Compartir Publicado 25 de Enero del 2015 has borrado los fallos y has vuelto a escanear? muchos de ellos pone que son intermitentes por lo que es probable que no sean fallos en si. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Serjio Publicado 25 de Enero del 2015 Denunciar Compartir Publicado 25 de Enero del 2015 has borrado los fallos y has vuelto a escanear? muchos de ellos pone que son intermitentes por lo que es probable que no sean fallos en si. Estoy contigo en lo dicho Responder Enlace al comentario Compartir en otros sitios web More sharing options...
COLLECTED Publicado 26 de Enero del 2015 Denunciar Compartir Publicado 26 de Enero del 2015 Hay un problema en el cableado de la puerta trasera derecha a la centralita confort..Es posible que haya habido algún golpe en esa puerta y no lo hayan arreglado bien, o algún cable esta defectuoso Responder Enlace al comentario Compartir en otros sitios web More sharing options...
mr_ilio Publicado 31 de Enero del 2015 Autor Denunciar Compartir Publicado 31 de Enero del 2015 he borrado unos cuantos... A lo de la puerta trasera derecha será el cable o directamente la cerradura que esta mal? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Serjio Publicado 1 de Febrero del 2015 Denunciar Compartir Publicado 1 de Febrero del 2015 Diría que la cerradura, pero antes prueba a los cables por si las moscas... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
mr_ilio Publicado 7 de Febrero del 2015 Autor Denunciar Compartir Publicado 7 de Febrero del 2015 es la cerradura ahora lo que me sucede es otro caso que me he dado cuenta ahora con el invierno y es que el la calefacción me sale el aire templado pero cuando subo de vueltas me sale caliente, alguna idea? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Serjio Publicado 9 de Febrero del 2015 Denunciar Compartir Publicado 9 de Febrero del 2015 Radiador de la calefacción Ha sido un tema bastante tratado, incluso Chirrito realizo un brico (esta colgado en la sección de bricos) Responder Enlace al comentario Compartir en otros sitios web More sharing options...
mr_ilio Publicado 10 de Febrero del 2015 Autor Denunciar Compartir Publicado 10 de Febrero del 2015 te refieres a lo del brico ese con vinagre? Funcionará eso? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Serjio Publicado 10 de Febrero del 2015 Denunciar Compartir Publicado 10 de Febrero del 2015 A ese me refiero. A bastantes les ha funcionado... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
