hola a todos , despues de kitar la proteccion de componentes ... me encuentro con estos errores
Address 13: Auto Dist. Reg Labels: None
Control Module Part Number: 5Q0 907 572 A HW: 5Q0 907 572 A
Component and/or Version: ACC Bosch MQB H03 0141
Software Coding: 00000400FE0339
Work Shop Code: WSC 03677 002 104857
ASAM Dataset: EV_ACCMRRBoschVW372 001013 (SE37)
VCID: 3561C75F94B4ADB6775-8060
4 Faults Found:
1058 - Databus
U1123 00 [009] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 13759 km
Date: 2015.02.17
Time: 21:35:33
1039 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 13759 km
Date: 2015.02.17
Time: 21:35:33
0111 - Dynamometer Mode Detected
C10A7 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 29
Mileage: 13759 km
Date: 2015.02.17
Time: 21:36:54
1807 - Function restriction
C10C2 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 13759 km
Date: 2015.02.17
Time: 21:35:33
Tuesday,17,February,2015,21:49:18:62939
VCDS Version: Release 12.12.0
Address 01: Engine Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 021 M HW: 04L 907 309 B
Component and/or Version: R4 1,6L EDC H22 6545
Software Coding: 01110012036401090000
Work Shop Code: WSC 00049 770 00125
ASAM Dataset: EV_ECM16TDI01104L906021M 002011 (SE37)
VCID: 2F6DF53776E897663D9-807A
2 Faults Found:
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 13759 km
Date: 2015.02.17
Time: 21:46:33
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 13759 km
Date: 2015.02.17
Time: 21:46:32
Readiness: 0 0 0 0 1
me podeis ayudar a interpretarlos? cual seria la solucion??
lo que se es que tengo que cambiar los sensores de ABS , con lo cual alguno de estos errores indique este fallo
gracias de antemano
