ALGUIEN SAVE QUE SON ES
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGB) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 JP HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3175
Revision: --H01---
Coding: 0104002C18072118
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TDI03L906022JP A01004
ROD: EV_ECM20TDI03L906022JP.rod
VCID: 7CFDEA29F7F0469
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AC HW: 8K0 907 379 AC
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 164500
Shop #: WSC 02399 823 56573
VCID: 7AF1EC31F5C4789
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 BC HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0252
Revision: 00002001
Coding: 030100
VCID: 72E1C411ADB4009
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 T HW: 8T1 820 043 T
Component: KLIMA 1 ZONE H06 0140
Revision: A0000000 Serial number: 0113.05.081267
Coding: 34000000
VCID: 428154D1DD94F09
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 179
Mileage: 150238 km
Time Indication: 0
Date: 2008.02.08
Time: 00:01:39
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 A HW: 8K0 907 063 A
Component: BCM1 1.0 H21 0253
Revision: 02021001 Serial number: 00000000038810
Coding: 690040B10034A7000001000000005F5F0F1C020800000101000000
VCID: 2D5B176D740A1F1
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 200508 H06 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 C HW: 8K0 941 531 C
Component: E1 - LDS H07 0070
2 Faults Found:
03123 - Terminal 30 - 2
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 179
Mileage: 150238 km
Time Indication: 0
Date: 2015.04.06
Time: 12:36:00
01800 - Light Switch (E1)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 179
Mileage: 150238 km
Time Indication: 0
Date: 2015.04.06
Time: 12:41:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 B HW: 8K0 919 475
Component: PARKHILFE 4K H06 0010
Revision: 11001001 Serial number: 75340814404679
Coding: 000003
VCID: 387536398B48AA9
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD15KR1B
Coding: 30343434363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7D2A29B770869
Crash sensor for side airbag; driver side:
Serial number: 6334MSME3A226338A
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME3A2265226
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME6661291DL
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME68332D3FV
Crash sensor for front airbag; driver side:
Serial number: 63732SME66032907W
Crash sensor for front airbag; passenger side:
Serial number: 63832SME716E2237%
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 E HW: 8K0 953 568 E
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HEH000JN
Coding: 000006
VCID: 3C7D2A29BF70869
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 D HW: 8K0 920 900 D
Component: KOMBIINSTR. H16 0221
Revision: 00000000 Serial number: 8ZL199P58
Coding: 0F04080002000008010000
VCID: 2B5F19754A1E111
2 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 33
Mileage: 146138 km
Time Indication: 0
Date: 2014.08.23
Time: 10:48:03
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 172
Mileage: 149114 km
Time Indication: 0
Date: 2015.03.08
Time: 10:46:14
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G0843081B5
Coding: 000303
VCID: 468948C1F1BCCC9
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
2 Faults Found:
03041 - Energy Management Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 174
Mileage: 147974 km
Time Indication: 0
Date: 2014.10.26
Time: 05:08:00
00469 - Infotainment Databus in Single Wire Operation
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 178
Mileage: 149711 km
Time Indication: 0
Date: 2015.04.04
Time: 14:03:35
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007204136
Coding: 011C02204000410001
VCID: 3F875D25AE669D1
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0111615224
Coding: 011A0620003900400120010000000000
Shop #: WSC 00869 572 123183
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
1 Fault Found:
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 178
Mileage: 149711 km
Time Indication: 0
Date: 2015.04.05
Time: 17:11:09
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007191375
VCID: 3E792021A96C949
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000132863
Shop #: WSC 00000 000 00000
VCID: 30650E196338729
Address 56: Radio (J503) Labels: 8Tx-035-152-56.clb
Part No SW: 8T1 035 152 A HW: 8T1 035 152 A
Component: Chorus3 H01 0031
Revision: 00000001 Serial number: AUZ1Z2H0765272
Coding: 00000480040100000159070000
VCID: 2E591061790C649
1 Fault Found:
02259 - Information Display and Control Head (Front) (J685)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 3
Reset counter: 138
Mileage: 149711 km
Time Indication: 0
Date: 2015.04.04
Time: 13:33:10
Freeze Frame:
Bin. Bits: 001
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007199331
Coding: 010C02204000210001
VCID: FF079D256EE6DD1
1 Fault Found:
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 51
Reset counter: 139
Mileage: 146170 km
Time Indication: 0TOS FALLOS ; Y QUE TENGO QUE HACER ? GRACIAS
