Asturiano25 Publicado 1 de Mayo del 2015 Denunciar Compartir Publicado 1 de Mayo del 2015 Buenas, me an dejado un vagcom 12.12 y ya que no me funcionaban un par de cosas me puse a mirar con el, estos son los errores que detecte: Friday,01,May,2015,12:22:53:30570 VCDS Version: Release 12.12.3 (x64) Address 17: Instruments Labels: 8D0-919-0xx-17.lbl Control Module Part Number: 8D0 919 033 P Component and/or Version: B5-KOMBIINSTRUMENT__D11 Software Coding: 00142 Work Shop Code: WSC 54321 VCID: 356751960F361CB678B-5072 1 Fault Found: 00771 - Fuel Level Sensor (G) 30-10 - Open or Short to Plus - Intermittent ---------------------------------------------------------------------------------------- Friday,01,May,2015,12:41:55:30570 VCDS Version: Release 12.12.3 (x64) Address 15: Airbags Labels: 8A0-959-655.lbl Control Module Part Number: 8A0 959 655 B Component and/or Version: Airbag V AUDI D00 Software Coding: 00766 Work Shop Code: WSC 06313 VCID: 326D6A8AFE580B8E5D9-5072 1 Fault Found: 00588 - Airbag Igniter; Driver Side (N95) 32-00 - Resistance Too High ---------------------------------------------------------------------------------------------- Friday,01,May,2015,12:45:55:30570 VCDS Version: Release 12.12.3 (x64) Address 08: Auto HVAC Labels: Redir Fail! Control Module Part Number: 8D0 820 043 D Component and/or Version: A4-KLIMAVOLLAUTOMAT_D63 Software Coding: 00043 Work Shop Code: WSC 06313 VCID: 214F95C6ABBE8016B43-2566 Fault Codes have been Erased 1 Fault Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-00 - Blocked or No Voltage -------------------------------------------------------------------------------------------------- Friday,01,May,2015,12:55:48:30570 VCDS Version: Release 12.12.3 (x64) Address 01: Engine Labels: 058-907-55X-AEB1.LBL Control Module Part Number: 8D0 907 557 Component and/or Version: 1,8l R4/5VT MOTR HS D05 Software Coding: 04001 Work Shop Code: WSC 00000 VCID: EDD739F6A7E61476C0B-4A3A 1 Fault Found: 01262 - Solenoid Valve for Boost Pressure Control (N75) 26-00 - Output Open Readiness: N/A ------------------------------------------------------------------------------------------------------- si alguien sabe como se puede solucinar alguno de ellos se lo agradeceria. Un Saludo. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
jmholgadog04 Publicado 9 de Mayo del 2015 Denunciar Compartir Publicado 9 de Mayo del 2015 el 01262, es la valvula n75, la que comanda el turbo, la solucion es cambiarla. el 00771, es el aforador, solucion tambien cambiarlo. el 00588 borralo y si no vuelve a aparecer no le hagas caso. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Asturiano25 Publicado 24 de Mayo del 2015 Autor Denunciar Compartir Publicado 24 de Mayo del 2015 Gracias por las aclaraciones, cuando tenga un rato le cambiare el aforador y la valvula n75, por cierto dicha valvula que es lo que hace? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
