fercontra Publicado 17 de Julio del 2015 Denunciar Compartir Publicado 17 de Julio del 2015 Hola a todos, acabo de recibir el cable para realizar diagnosticos de mi TT 2007. El resultado es este. A ver si alguien me puede ayudar a traducir un poco lo que significa. Gracias!! Friday,17,July,2015,16:37:20:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 (x64) Data version: 20130910 VIN: TRUZZZ8J071001075 License Plate: 01 Mileage: 137630km-85519mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8J (8N - Audi TT (1999 > 2007)) Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77 VIN: TRUZZZ8J071001075 Mileage: 137630km/85519miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Part No SW: 8J0 907 115 HW: 8J0 907 115 Component: 2.0l R4/4V TFSI 0020 Revision: --H14--- Serial number: AUX7Z0F5FNE0F8 Coding: 0113000318070160 Shop #: WSC 00234 572 18146 VCID: E9D9DB2FC08CB956A3D-80BC 1 Fault Found: 000010 - Camshaft Positioner (Bank 1 Intake) P000A - 008 - Slow Response - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 136129 km Time Indication: 0 Date: 2015.07.04 Time: 08:49:29 Freeze Frame: RPM: 2915 /min Load: 37.6 % Speed: 116.0 km/h Temperature: 96.0°C Temperature: 23.0°C Absolute Pres.: 910.0 mbar Voltage: 13.970 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8J0-614-517.clb Part No SW: 8J0 614 517 HW: 8J0 614 517 Component: ESP MK60E1 0130 Revision: 00H51001 Coding: 0017424 Shop #: WSC 01236 785 00200 VCID: EADBA423C58AB24EAA7-80BF No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 8J0 820 043 R HW: 8J0 820 043 R Component: J255 Klima 1 Zone 0050 Revision: 00H07001 Serial number: 00000001002271 Coding: 1572868 Shop #: WSC 01236 785 00200 VCID: 3561C75F5CB4ADB6775-8060 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8J0-959-655.lbl Part No SW: 8J0 959 655 HW: 8J0 959 655 Component: -n Airbag 9.43 H02 0010 Revision: 93H02001 Serial number: 0036K00014VM Coding: 0011630 Shop #: WSC 01236 785 00200 VCID: F9F98B6FB02C09D653D-80AC Subsystem 1 - Serial number: 6332DRB40356112EF Subsystem 2 - Serial number: 6342DRB40351079BK Subsystem 3 - Serial number: 63729RB4009C1A24L No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8J0-920-xxx-17-MY7.lbl Part No SW: 8J0 920 930 C HW: 8J0 920 930 C Component: KOMBIINSTR. VDO H18 0050 Revision: D0H18001 Serial number: 2245F001001129 Coding: 0020118 Shop #: WSC 00485 572 88463 VCID: 2C57E23B8FFEEC7E18B-8079 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 G Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000009 Shop #: WSC 01236 785 00200 VCID: 3E73D87369826EEEA6F-806B No fault code found. End --------------------------------------------------------------------- Responder Enlace al comentario Compartir en otros sitios web More sharing options...
