Est Publicado 24 de Agosto del 2015 Denunciar Compartir Publicado 24 de Agosto del 2015 Buenas, Esta mañana me ha legado el cable vag-com 12.12 y al hacerle el test, me arroja los siguientes resultados: Chassis Type: 8D - Audi A4 B5 (1995 > 2001) Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 Mileage: 255280km/158623miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 028 906 021 GN Component: 1,9l R4 EDC 00SG 1437 Coding: 00002 Shop #: WSC 06335 VCID: 61C9430FEBBC7116FBD-4A3A No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl Part No: 8E0 614 111 Component: ABS 5.3 FRONT D11 Shop #: BB 24303 VCID: DBB5F1E749D0DBC6211-5072 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl Part No: 8L0 820 043 B Component: A4 KLIMAVOLLAUTOMAT_D73 Coding: 04143 Shop #: WSC 06335 VCID: 275D1D17C518CF26F59-2598 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI7.lbl Part No: 8D0 959 655 C Component: Airbag 7 Audi DE2 Coding: 00102 Shop #: WSC 06335 VCID: 3663C05312B2A6AE7EF-5072 5 Faults Found: 01221 - Crash Sensor Side Airbag; Driver Side (G179) 36-10 - Open Circuit - Intermittent 01217 - Side Airbag Igniter; Driver Side (N199) 32-10 - Resistance Too High - Intermittent 65535 - Internal Control Module Memory Error 00-10 - - - Intermittent 01221 - Crash Sensor Side Airbag; Driver Side (G179) 44-10 - Short Circuit - Intermittent 01218 - Side Airbag Igniter; Passenger Side (N200) 33-10 - Resistance Too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-919-0xx-17.lbl Part No: 8D0 919 034 Component: B5-KOMBIINSTRUMENT D10 Coding: 00140 Shop #: WSC 19411 VCID: E6C3D0138292962E8EF-5000 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4A0-953-234.lbl Part No: 4A0 953 234 F Component: IMMO AUZ9Z0V3156139 D77 Coding: 00000 Shop #: WSC 00000 VCID: 2541171FBF14DD36C75-5072 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8LO 862 257 E Component: ZV-Pumpe Coding: 00000 Shop #: WSC 65535 VCID: 56A360D3B2F286AE9EF-4DD6 1 Fault Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - End --------------------------------------------------------------------- Por lo que puedo deducir, solamente tengo errores en el airbag, y la bomba de cierre centralizado, estoy en lo cierto? He consultado los códigos que salen, y me he encontrado con lo siguiente: 01217 04C1 - Detonador de airbag lateral, lado del conductor -N199 01218 04C2 - Detonador de airbag lateral, lado del acompañante -N200 01221 04C5 Sensor de impacto del airbag lateral del lado del conductor -G179 65535 - ¿? 01367 - Desconexión de la bomba del cierre centralizado Ahora vienen las grandes dudas, esto, podré solucionarlo yo? ... o necesita una visita al concesionario obligatoria? Gracias de antemano por la ayuda, Responder Enlace al comentario Compartir en otros sitios web More sharing options...
zeimon Publicado 24 de Agosto del 2015 Denunciar Compartir Publicado 24 de Agosto del 2015 Borra los fallos primero y vuelve a pasarlos. Si persisten si tendrás que mirar más cosas Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Est Publicado 24 de Agosto del 2015 Autor Denunciar Compartir Publicado 24 de Agosto del 2015 Pues, si con borrar los fallos te refieres a darle a la tecla "clear" que aparece una vez el programa realiza el test del coche, eso he hecho (imagino que con eso es suficiente, y que no es necesario realizar ninguna otra operación más concreta para borrarlos, así lo indicaban las instrucciones al menos), seguidamente he vuelto a realizar el test y me ha dado exactamente los mismos fallos ... lo de los airbags, no me extraña, por que según parece, son los de los asientos, y me consta que en mas de una ocasión se los han quitado (para limpiar bien el coche una vez, y para retapizar una oreja del asiento conductor, la otra), pero el de la bomba, es muy raro, por que funciona perfectamente, cierra y abre sin problemas ... :pardon: ... con un poco de suerte, me da la excusa perfecta para ponerle una con cierre a distancia jeje un saludo, y gracias una vez mas!! Responder Enlace al comentario Compartir en otros sitios web More sharing options...
GoNzCiD Publicado 24 de Agosto del 2015 Denunciar Compartir Publicado 24 de Agosto del 2015 Pues te toca revisar todas las conexiones del asiento... Respecto a la bomba, te esta indicando que tarda más de lo normal, alguna fuga de aire tienes... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Est Publicado 24 de Agosto del 2015 Autor Denunciar Compartir Publicado 24 de Agosto del 2015 pues nada ... a revisar toca, espero que no me de mucha lata... lo de la posible fuga de la bomba, entiendo que el aire se canaliza hasta las puertas no? ... espero que no me de mucha lata gracias por la ayuda! Responder Enlace al comentario Compartir en otros sitios web More sharing options...
GoNzCiD Publicado 26 de Agosto del 2015 Denunciar Compartir Publicado 26 de Agosto del 2015 Me temo que son dos cosas bastante tediosas, sobre todo si no sale el fallo pronto... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Est Publicado 27 de Agosto del 2015 Autor Denunciar Compartir Publicado 27 de Agosto del 2015 Bueno, pues creo que ya he localizado el fallo del airbag del lateral conductor ... así me he encontrado el conector... roto, y enchufado... los cables hacian contacto ... alguien podria decirme la referencia de esos terminales? me temo que tendre que cambiarlo un saludo!! Responder Enlace al comentario Compartir en otros sitios web More sharing options...
jhonysen Publicado 18 de Septiembre del 2015 Denunciar Compartir Publicado 18 de Septiembre del 2015 Suéldalos, es la mejor manera de que no te vuelva a dar error. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Est Publicado 19 de Septiembre del 2015 Autor Denunciar Compartir Publicado 19 de Septiembre del 2015 de momento los tengo desconectados, puesto que he cambiado los asientos por unos sport en cuero, y tienen distinta clavija para conectarlos, así que mientras averiguo el numero de serie de la susodicha y los conecto en condiciones, quedan de adorno los airbags de los asientos Responder Enlace al comentario Compartir en otros sitios web More sharing options...
A4B51.8T Publicado 23 de Septiembre del 2015 Denunciar Compartir Publicado 23 de Septiembre del 2015 El cierre mientras veas que todo va bien no te compliques la vida, no he visto ni un vag, sin tirar fallo de cierre jeje, y avisar de alarma cuando no la tiene.... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
