YOMELLAMOO Publicado 20 de Septiembre del 2015 Denunciar Publicado 20 de Septiembre del 2015 I have a Audi 2002 A6 with turn signal problem. It works sometime and other times it doesn't. I have replaced the emergency flasher relay and checked the fuses for the turn signals. When you put the arm forward in the high beam position it works briefly, All fuses for the signals appeared ok. I also sprayed a special electrical solution on the turning signal mechanism connections and there was no change. Can anyone give me an idea what to check next or what the problem could be? I suspect the turning signal mechanism is faulty, If that is the case. can anyone explain how to remove the tune signal mechanism. Responder
