raulbs Publicado 10 de Mayo del 2016 Denunciar Publicado 10 de Mayo del 2016 Este es un log que tenía a mano de hace un tiempo, a ver si localizamos donde lo indica: VCDS Version: Release 908.0 Data version: 20090911 Sunday,22,November,2015,17:29:06:13314 Chassis Type: 4F0 Scan: 01 03 05 08 09 15 16 17 19 42 46 4F 52 53 55 56 5F 62 72 76 VI: Mileage: 181900km/113027miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 FG HW: 03L 906 022 FG Component: R4 2,0L EDC H04 6420 Revision: 11H04--- Serial number: Coding: 0105002C18072120 Shop #: WSC 02325 785 00200 ASAM Dataset: EV_ECM20TDI03L906022FG A01007 No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT Component: ESP8 front H03 0060 Revision: 00000000 Serial number: 00000000000000 Coding: 0020859 Shop #: WSC 02325 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 B HW: 4F0 905 852 D Component: FBSAUDIC6 ELV H05 0100 Revision: 00H05000 Serial number: 10602601577126 Coding: 0000001 Shop #: WSC 02323 785 00200 Part No: 4F0 910 132 D Component: FBSAUDIC6 EZS H03 0020 Part No: 4F0 910 220 D Component: FBSAUDIC6 IDG H01 0054 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 B HW: 4F1 820 043 AK Component: KLIMABETAETIGUNGH30 0080 Revision: 00000076 Serial number: 00000030541911 Coding: 0000020 Shop #: WSC 02325 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 N HW: 4F0 907 279 Component: ILM Fahrer H22 0320 Revision: 00000000 Serial number: 4F0907279 Coding: 0003121 Shop #: WSC 02335 785 00200 Part No: 4F1 910 113 D Component: Wischer AudiC6 H10 0040 Coding: 00056595 Shop #: WSC 02335 Part No: 8K0 910 557 Component: REGENLICHTSENSORH04 0003 Coding: 00146221 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: None Part No SW: 4F0 910 655 Q HW: 4F0 959 655 G Component: Airbag AU1042 H07 0200 Revision: -------- Serial number: 003F9002ZAH5 Coding: 30314236303630303032554A304C34463053 Shop #: WSC 02323 785 00200 ASAM Dataset: EV_Airba10AURB4 001001 ROD: EV_Airba10AURB4.rod No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 A HW: 4F0 953 549 D Component: J0527 0530 Revision: 00H05000 Serial number: 90025101210426 Coding: 0002041 Shop #: WSC 02323 785 00200 Part No: XXXXXXXXXXX Component: E0221 H02 0100 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb Part No SW: 4F0 920 933 Q HW: 4F0 920 933 Q Component: KOMBIINSTR. H09 0147 Revision: 00000000 Serial number: DHK08H35A Coding: 0374090502000008050100 Shop #: WSC 02391 823 56573 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb Part No SW: 4F0 907 468 M HW: 4F0 907 468 F Component: GW-BEM 4CAN-M H06 0035 Revision: LB100029 Serial number: 2900L105030091 Coding: 000B03 Shop #: WSC 02391 823 56573 Part No SW: 8K0 915 181 C HW: 8K0 915 181 C Component: J367-BDM H07 0125 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb Part No SW: 4F0 959 793 R HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000104187872 Coding: 011C06204040410001 Shop #: WSC 02391 823 56573 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 N HW: 4F0 907 289 N Component: Komfortgeraet H29 0250 Revision: 02500029 Serial number: 01298937210000 Coding: 0131313 Shop #: WSC 02335 785 00200 Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 Part No: 4F0 910 177 Component: Innenraumueberw.H01 0020 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 A Component: ILM Beifahrer H13 0100 Revision: Serial number: 00000000711237 Coding: 0001104 Shop #: WSC 02323 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb Part No SW: 4F0 959 792 R HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000104189301 Coding: 011C06204040410001 Shop #: WSC 02391 823 56573 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 D HW: 4F0 907 801 B Component: EPB CEFC0090 H05 0090 Revision: --H05--- Coding: 0000111 Shop #: WSC 02145 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 H Component: Dynamische LWR H02 0010 Revision: 00000001 Serial number: Coding: 0000003 Shop #: WSC 02325 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio ® Labels: None Part No SW: 4F0 035 056 K HW: 4F0 035 056 Component: Radio U STD H45 0074 Revision: AB001007 Serial number: 342ET0A7806702 Coding: 010003020100000000 Shop #: WSC 02391 823 56573 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: Redir Fail! Part No SW: 4E0 035 670 K HW: 4E0 035 670 C Component: H-BNT-EU H47 0187 Revision: -------- Serial number: 453EQ0A7530900 Coding: 01010000000283ED0100070DEF6300030000 Shop #: WSC 02391 823 56573 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb Part No SW: 4F0 959 795 M HW: 8K0 959 795 B Component: TSG HL H10 0251 Revision: Serial number: 0000104138007 Coding: 010804204040220001 Shop #: WSC 02391 823 56573 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb Part No SW: 4F0 959 795 M HW: 8K0 959 795 B Component: TSG HR H10 0251 Revision: Serial number: 0000104138008 Coding: 010804204040220001 Shop #: WSC 02391 823 56573 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4L0 910 283 B HW: 4L0 919 283 B Component: Parkhilfe 4-Kan H02 0500 Revision: 00H02000 Serial number: 12331012500629 Coding: 0200006 Shop #: WSC 02323 785 00200 No fault code found. End ---------------------------------------------------------------------
alagar27 Publicado 10 de Mayo del 2016 Denunciar Publicado 10 de Mayo del 2016 Dinos el modelo de coche raulbs tambien para asi poder comparar Enviado desde mi SM-G935F mediante Tapatalk
raulbs Publicado 10 de Mayo del 2016 Denunciar Publicado 10 de Mayo del 2016 (editado) Por cierto, es un A6 2.0 de 170 cv, es que mi subforo está muy parado con este tema. En breve tengo que hacer la distribución, las revisiones normales se las hago yo pero la distribución siempre he ido al conce, me lo pensaré Editado 10 de Mayo del 2016 por raulbs
alagar27 Publicado 10 de Mayo del 2016 Denunciar Publicado 10 de Mayo del 2016 Ok gracias Enviado desde mi SM-G935F mediante Tapatalk
TRULIS Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 Ya tengo la carita de José Balcarce, dgt, me parece vergonzoso que la dgt se preste a entrar en el juego a sabiendas de q no te garantizan la reparación óptima. En fin..dos folios muy tristes.
MIMIAUDI Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 Ya tengo la carita de José Balcarce, dgt, me parece vergonzoso que la dgt se preste a entrar en el juego a sabiendas de q no te garantizan la reparación óptima. En fin..dos folios muy tristes. A ver señores que no lleve a confusion. Esa no es una carta oficial de la dgt ya que esas vienen certificadas. Lo que ocurre es que nuestra marca premium no tiene manera de saber donde esta y a quien pertenece cada uno de los coches afectados y para ello recurre a la dgt que si tiene dicho registro, ni mas ni menos.
TRULIS Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 Ya tengo la carita de José Balcarce, dgt, me parece vergonzoso que la dgt se preste a entrar en el juego a sabiendas de q no te garantizan la reparación óptima. En fin..dos folios muy tristes. A ver señores que no lleve a confusion. Esa no es una carta oficial de la dgt ya que esas vienen certificadas. Lo que ocurre es que nuestra marca premium no tiene manera de saber donde esta y a quien pertenece cada uno de los coches afectados y para ello recurre a la dgt que si tiene dicho registro, ni mas ni menos. A ver, el membrete es de la dgt, la dirección remitente Josefa varcalcel, una sede de la dgt, yo lo que he dicho es que la dgt se presta a entrar el el juego al permitir el envío de cartas con sus datos, es decir la dgt es conciente del envío de esas cartas, del contenido y de como se envian, eso esta todo autorizado, una vergüenza vamos
fali62 Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 alguien puede poner el enlace a la pagina para comprobar las campañas pendientes?
raulbs Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 alguien puede poner el enlace a la pagina para comprobar las campañas pendientes? Aquí tienes: http://www.audi.de/de/brand/de/kundenbereich.html#page=/de/brand/de/kundenbereich/weitere-informationen.html&layer=/de/brand/de/kundenbereich/weitere-informationen/layer/rueckrufaktionen.html
ALL70 Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 No he visto todavía el log de algún coche que haya pasado la campaña así que no lo puedo confirmar 100%, pero usando el log que ha puesto el amigo raulbs os digo que información se ve: Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clbPart No SW: 03L 906 022 FG HW: 03L 906 022 FGComponent: R4 2,0L EDC H04 6420 Revision: 11H04--- Serial number: El número en azul es el software que lleva el módulo y el número en rojo es el que cambia según se tenga una versión u otra. Tras la actualización ahí va a poner 9977, eso parece que se cumple para un montón de centralitas que he mirado. A ver si un log de alguien que ya la haya pasado nos lo confirma.
fali62 Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 alguien puede poner el enlace a la pagina para comprobar las campañas pendientes? Aquí tienes: http://www.audi.de/de/brand/de/kundenbereich.html#page=/de/brand/de/kundenbereich/weitere-informationen.html&layer=/de/brand/de/kundenbereich/weitere-informationen/layer/rueckrufaktionen.html Gracias. me aparecen dos campañas: 23Q4 A- Diesel Abgas EA189 - Nur Vorschau! 23Q7 A- Diesel Abgas EA189
MIMIAUDI Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 Ya tengo la carita de José Balcarce, dgt, me parece vergonzoso que la dgt se preste a entrar en el juego a sabiendas de q no te garantizan la reparación óptima. En fin..dos folios muy tristes. A ver señores que no lleve a confusion. Esa no es una carta oficial de la dgt ya que esas vienen certificadas. Lo que ocurre es que nuestra marca premium no tiene manera de saber donde esta y a quien pertenece cada uno de los coches afectados y para ello recurre a la dgt que si tiene dicho registro, ni mas ni menos. A ver, el membrete es de la dgt, la dirección remitente Josefa varcalcel, una sede de la dgt, yo lo que he dicho es que la dgt se presta a entrar el el juego al permitir el envío de cartas con sus datos, es decir la dgt es conciente del envío de esas cartas, del contenido y de como se envian, eso esta todo autorizado, una vergüenza vamos Si la carta viene desde la dgt que es quien tiene los datos del vehiculo tendra que venir membrete y firma ¿no? Simplemente informaba por que viene asi...
pandaa4 Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 Yo había recibido la carta de audi hace tiempo y ayer me llego otra con el sobre de la dgt y con una carta con dos hojas una recomendando que se realice la actualizacion y la otra igual que la que me mando audi. Vamos que creo que se están poniendo desacuerdo entre ellos para luego poder decir quien la ha hecho y quien no...... Aunque no sea certificada esto seguro que viene para tenernos cojidos de los huevos en el futuro. Cada vez me duele mas haber elegido el grupo Volkswagen como el fabricante de la mayoría de los coches que he tenido y siempre haberlo recomendado. Soy de los que con un poco de suerte no volveré a comprar coches de este grupo. Creo que poco a poco no nos quedara otra que pasar por el aro y actualizar, se gane o se pierda consumo potencia o lo que sea y solo podremos patalear........
maalni Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 Otro que recibe la segunda carta pidiendo que yo me ponga en contacto con el taller para pasar dicha campaña tiene narices que encima pretendan que seamos nosotros los que llamemos y se la demos todo servido en bandeja Enviado desde mi SM-G920F mediante Tapatalk
unaicastellanos Publicado 11 de Mayo del 2016 Denunciar Publicado 11 de Mayo del 2016 Yo estaba alargando la revisión de los 60.000km para ver como evolucionaba esto. Tenía un poco de margen porque como soy un poco maniatico y 30.000km me parecen excesivos, yo se las hago cada 25.000km. Pero el sábado me dieron un golpe por detrás. En San Sebastián, tanto el concesionario de VW como el de Audi, para temas de chapa te mandan a otro taller (del mismo dueño) que es más especializado en vehículos comerciales, coches de ocasión y chapa y pintura. Lo llevé sin miedo a que me dijeran nada de las campañas, ya que no iba al taller oficial de Audi e iba a reparar el parachoques y portón traseros... Pues me soltaron lo de las campañas y bastante insistentes. Les dije que no las hicieran. Me respondieron que ellos tenían obligación de hacer las campañas a no ser que se lo dejara por firmado. Le dije lo que leí por aquí: que VW me diera por firmado que ni la potencia, ni el consumo, ni la vida útil del coche se iban a ver afectados y que no les pondría ninguna pega en que me hicieran la campaña. Me dijeron que VW no les ha dicho de seguir ese protocolo. Ahí le reclame que si VW lleva engañando 8 años a su cliente y no quiere firmar nada, porque es el engañado cliente el que tiene que firmar algo? Le expliqué que no me estaba oponiendo a hacérselo nunca al coche y le intenté explicar mi situación: - Han salido pruebas de que a los Amarok se les incrementaba el consumo. - Las actualizaciones del Passat se congelaron porque se sospechaba que el consumo aumentaba - VW/Audi no me aseguran por escrito que las características del coche no se vean afectadas Que una vez 200.000 coches hayan actualizado y no se vea afectado nada, que dejaría que me lo actualizaran, pero por ahora que no. Pues nada, no llegué a convencerla, ella en sus 13 de que tenía que firmar el papel o me lo hacían. Así que ya sabéis, ni acercaros por un taller del grupo VAG! que estos son capaces de meteros la actualización hasta por wifi si os acercais!! jajajaja.
