Nono64 Publicado 5 de Octubre del 2015 Denunciar Publicado 5 de Octubre del 2015 Buenos días para todos, les escribo desde Argentina, tengo un problema con la suspensión de mi Allroad y no logramos solucionarlo!! Les adjunto imagen de la pantalla del scaner. Espero alguno pueda ayudarme!! Muchas gracias Responder
a34323 Publicado 5 de Octubre del 2015 Denunciar Publicado 5 de Octubre del 2015 Yo lo que veo es que te falla el sensor de nivel trasero derecho. Error 775: 00775 - Level Control System Sensor; Rear Right (G77) 00775 - Level Control System Sensor; Rear Right (G77): Implausible Signal Possible SymptomsMalfunction Indicator Light (MIL) activePossible CausesCommunication Problem between Level Control Module (J197) and Headlight Aim Control Module Wiring/Connectors from/to Level Control Module (J197) faulty Possible SolutionsCheck Communication Problem between Level Control Module (J197) and Headlight Aim Control Module Check Wiring/Connectors from/to Level Control Module (J197) Special NotesIf the Vehicle had been lifted and one or both axles rebounded while Ignition ON or the Sensor disconnected while Ignition ONIgnore/Clear Fault Code ERROR 1400: 01400 - Suspension Level Control 01400 - Suspension Level Control: Control Limit Not Reached Possible SymptomsMalfunction Indicator Light (MIL) ONPossible CausesLeakage Excess Temperature Shut Off Possible SolutionsCheck System for LeaksSee Factory Repair Manual for Details Let the System cool down before any further Attempts ERROR 1577 01577 - Turn-Off due to Over-Temp: Upper Limit Exceeded Possible SymptomsAir Ride Suspension bleeds downPossible CausesAir leak in Air Ride Suspension SystemPossible SolutionsLocate and repair air leakSpecial NotesOn vehicles with Air Ride Suspension, a leak in the system will cause the Air Compressor Motor to run too long and flag this code.This code can also be flagged in other control modules, Headlight Range Control for example. In these cases, it can be a failed motor or mechanical binding. Responder
