No sé exactamente si los valores del MMI serán los mismos pero para el RNS-E... Te pego trozos de info. de otro post que subí hace mucho y te marco en rojo lo interesante:
MÓDULO 56 ( Navigation System )
Adaptation -> Function 10
Channel 136 (Voice commands)
00005 - LHD (USA + Europe SW 0500+)
00013 - RHD (USA + Europe SW 0500+)
02632 - RHD (Europe SW < 0500)
03226 - LHD (Europe SW <0500)
MÓDULO 17 ( Instrument cluster )
Channel 62
+04 - Navigation
+23 - Bluetooth
MÓDULO 77 - Telephone ( Bluetooth )
Coding -> Function 07
0?xxxxx: Brand
0 = Audi
1 = Seat
0x?xxxx: Functions
0 = Basic (for RNS-E basic/Radio)
1 = Comfort (for RNS-E high/RNS-Low)
0xx?xxx: Steering Wheel
0 = No Multi-Function OR Standard Steering Wheel (Old Style without Menu Thumb Wheels)
1 = Modular Steering Wheel (New Style with Menu Thumb Wheels)
0xxx?xx: Installation List
1 = Diagnostics via CAN
2 = Multi-Function Steering Wheel, Diagnostics via CAN
3 = Head Unit (e.g. RNS-E), Diagnostics via CAN
4 = Multi-Function Steering Wheel, Head Unit (e.g. RNS-E), Diagnostics via CAN
5 = Diagnostics via K-Line
6 = Multi-Function Steering Wheel, Diagnostics via K-Line
7 = Head Unit (e.g. RNS-E), Diagnostics via K-Line
8 = Multi-Function Steering Wheel, Head Unit (e.g. RNS-E), Diagnostics via K-Line
0xxxx?x: Language (Voice Control)
0 = Voice Control OFF OR via external Device (e.g. RNS-E)
1 = German
2 = English (UK)
3 = French
4 = Italian
5 = Spanish
6 = Czech
7 = English (US)
8 = French (CA)
9 = Speaker dependent (Voice Commands inactive, Acoustic Name Selection active)
0xxxxx?: Language (Display)
0 = No Display
1 = German
2 = English (UK)
3 = French
4 = Italian
5 = Spanish
6 = Czech
7 = English (US)
8 = French (CA)
channel 133
1 - BT ACTIVATION
channel 134
0 - Handsfree over BT
channel 135
1234 - Bluetooth PIN
Échale un ojo a esos módulos a ver si te cuadran las cosas. Estaría bien que alguien con MMI pudiese echar un cable con la codificación...
Channel 62
+04 - Navigation
+23 - Bluetooth
0?xxxxx: Brand
0 = Audi
1 = Seat
0x?xxxx: Functions
1 = German
2 = English (UK)
3 = French
4 = Italian
5 = Spanish
6 = Czech
7 = English (US)
8 = French (CA)
0 = No Display
1 = German
2 = English (UK)
3 = French
4 = Italian
5 = Spanish
6 = Czech
7 = English (US)
8 = French (CA)
channel 133
1 - BT ACTIVATION
channel 134
channel 135
Buenas tardes antes que nada muchisimas gracias por tu ayuda.
He revisado las centralitas pero no tiene nada que ver ni la numeracion ni los codigos de adaptacion... es totalmente diferente. De todos modos me he parado entrando en adaptacion y coding de las centralitas que has nombrado y no encunetro nada de nada de voice control...
Entonces lo que he echo es entrar directamente a la centralita voice control y no me deja ni entrar al coding ni a adaptacion... imagino que sera por el security code. No me las deja marcar... Imagino que el problema sera de ahi.. porque en el resto no veo nada de voice control. Lo maximo que he visto ha sido el volante multifuncion que si esta activo en instruments de ahi que la tecla me la reconoce...
Buenas tardes. He estado trasteando mas con el coche haber si daba con el tema... y nada no logro hacerlo funcionar. Sigue dandome tecla vacia al pulsar la tecla del volante.
Por otro lado ya esta corregido el famoso fallo de la radio. No tenia puesto el telefono activo con lo que daba un fallo de adaptacion. CORREGIDO
He estado viendo que hay dos tipos de telefono el PR-9ZF y despues puedo seleccionar otro (PR-9ZF/9ZG/9W5) el tema esta que he puesto el primero el PR-9ZF de este modo el contro head deja de dar la averia.
Si pongo el segundo telefono vuelve a dar averia de la mima manera que sin el. Mi duda es la siguiente... No se supone que el telefono debajo del reposabrazos delantero MOTOROLA es bluetooth?? Me refiero a que dicha comunicacion con la centralita la realiza por ese metodo...
Por otro lado tambien se me ocurre una cosa... puede ser que el SDS no funcione por haber actualizado los mapas a 2012 del navegador? Esque es la unica cosa que habian actualizado porque el resto lo he echo yo y la tecla ya no respondia...
Ahora mismo el MMI lo tengo actualizado a la ultima version 5570. Lo unico que me ha quedado sin actualizar es el SDS debido a que necesito los cds de actualizacion uno a uno. Solo le he podido pasar la 2120 debido a que no tengo los sucesivos. Si intento meterle la 5570 del tiron me dice directorio no encontrado... en cambio si voy una a una me actualiza pero nose donde encontrar el resto de actualizaciones para ir una a una...
El SDS no se suele perder al actualizar los mapas. Puede perderse al actualizarse el firmware, pero no los mapas... Van por separado. Por lo demás, pues yo voy un poco perdido con los MMI :huh:
No se me ocurre mas de donde pueda venir... O bien es tema de actualizacion o bien tema de la propia centralita del voice control la cual no me deja ni tocar el coding ni tocar la adaptacion... Haber si alguien puede aclarar un poquito mas el tema
