PsyA3 Publicado 4 de Marzo del 2016 Denunciar Compartir Publicado 4 de Marzo del 2016 Le he pasado el vagcom y me han salido errores que a mi juicio son chungos, chungos (el de la unidad de control) Me pongo a temblar? VAG-COM Version: Release 311.2-NChassis Type: 4B - Audi A6 C5Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56Address 01 ------------------------------------------------------- Controller: 3B0 907 552 AN Component: 2.4L V6/5V 0001 Coding: 11702 Shop #: WSC 02325 WAUZZZ4BXXXXXXXX AUZ7ZXXXXXXXXX2 Faults Found:16804 - Catalyst System: Bank 1: Efficiency Below Threshold P0420 - 35-10 - - - Intermittent16518 - Oxygen (Lambda) Sensor B1 S1: No Activity P0134 - 35-10 - - - IntermittentReadiness: 0000 0000Address 03 ------------------------------------------------------- Controller: 8D0 907 389 E Component: ABS/ESP allrad D46 Coding: 06295 Shop #: WSC 02325No fault code found.Address 08 ------------------------------------------------------- Controller: 4B0 820 043 H Component: A6-Klimavollautomat D64 Coding: 00060 Shop #: WSC 02325No fault code found.Skipping Address 15-AirbagsAddress 17 ------------------------------------------------------- Controller: 4B0 920 932 R Component: C5-KOMBIINSTR. VDO D12 Coding: 00162 Shop #: WSC 00222 WAUZZZ4BZ1N057023 AUZ7Z0Y15789321 Fault Found:01177 - Engine Control Unit 49-00 - No CommunicationsAddress 35 ------------------------------------------------------- Controller: 4B0 962 258 E Component: Zentralverrieg.,DWA D33 Coding: 06731 Shop #: WSC 023258 Faults Found:01366 - Opened Due to Crash Signal 35-00 - -01374 - Alarm triggered by Terminal 15 35-00 - -00956 - Key 2 09-10 - Adaptation Limit Surpassed - Intermittent01562 - Right Rear Door 59-10 - Can't Unlock - Intermittent01561 - Left Rear Door 60-00 - Won't Safe01559 - Drivers Door 61-00 - Won't De-Safe01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent01573 - Alarm triggered by Door Contact Switch: Left Rear 35-00 - -Address 45 ------------------------------------------------------- Controller: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00002 Shop #: WSC 023252 Faults Found:01377 - Ultra Sonic Sensor for Alarm System: Left (G170) 31-00 - Open or Short to Ground01378 - Ultra Sonic Sensor for Alarm System: Right (G171) 31-00 - Open or Short to Ground Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Tazrider Publicado 4 de Marzo del 2016 Denunciar Compartir Publicado 4 de Marzo del 2016 Ufff hacia mucho que no veia tantos errores... Una duda, has borrado los errores y has vuelto a pasar el vagcom Lo mismo los tenias ya de antes y ahora no te salen... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
PsyA3 Publicado 5 de Marzo del 2016 Autor Denunciar Compartir Publicado 5 de Marzo del 2016 Hoy pruebo de nuevo. Los que confirmado si vuelven aparecer, los de sonda lambda y catalizador. Voy a ir preparando la billetera...... Enviado desde mi LG-H815 mediante Tapatalk Responder Enlace al comentario Compartir en otros sitios web More sharing options...
