ariam2001 Publicado 4 de Abril del 2016 Autor Denunciar Publicado 4 de Abril del 2016 Por otro lado, si lleva virtual cockpit ha de ser necesariamente mmi plus. Aunque no he preguntado al comercial ahora pienso que si era el plus, he abierto la guantera y he visto que además de las ranuras para las SD también tenía una para la SIM. Responder
Alfa159 Publicado 4 de Abril del 2016 Denunciar Publicado 4 de Abril del 2016 Carrazo el MIATA! Responder
lorquinoaudi Publicado 4 de Abril del 2016 Denunciar Publicado 4 de Abril del 2016 Esta es la traducción de la etiqueta: PRCode: 0G7 = Tiptronic PRCode: 0JH = Weight category front axle weight range 8 PRCode: 0YH = Weight range 8 installation control only no requirement forecast PRCode: 1BE = Sports suspension/shock absorption PRCode: 1KD = Disc brakes rear PRCode: 1LC = Disc brakes front PRCode: 1SA = Without additional engine guard PRCode: 2K6 = Reinforced bumpers PRCode: 2PF = Leather trimmed multi-function sports steering wheel PRCode: 3FA = Without roof insert (standard roof) PRCode: 3L3 = Manual height adjustment for front seats PRCode: 3NT = Rear seat bench/backrest in glass fiber PRCode: 3Y0 = Without roll-up sun screen PRCode: 4GF = Windshield in heat-insulating glass PRCode: 4KC = Side and rear windows in heat-insulatingglass PRCode: 4UF = Driver's and front passenger air bag with front passenger air bag deactivation PRCode: 4X3 = Side air bag front with curtain air bag PRCode: 5D1 = Carrier frequency 433.92 MHz-434.42 Mhz PRCode: 5RU = Right exterior mirror: convex (large viewing field) PRCode: 5SL = Left exterior mirror: aspherical PRCode: 5TG = Decorative aluminum inserts dulling PRCode: 6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated PRCode: 7K1 = Tire pressure warning light PRCode: 7MM = Emission standard EU6 plus PRCode: 7UG = Navigation system - High PRCode: 7X2 = Park distance control front and rear PRCode: 8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving) PRCode: 8Z4 = Moderate hot country PRCode: 9G3 = Alternator 120-180 A PRCode: 9S8 = Multi-function display/trip computer Medium without energy efficiency display PRCode: DE5 = 4-cyl. turbo dies. eng. 2.0 l/140 kW 4V TDI common rail Base engine is TD1 PRCode: E0A = No special edition PRCode: F0A = No special purpose vehicle standard equipment PRCode: J1N = Battery 420 A (75 Ah) PRCode: LZ7 = With marine transmission ZF 80A PRCode: N7K = Alcantara/leather seat covering PRCode: Q1D = Sports front seats PRCode: QI6 = Without service indicator PRCode: QZ7 = Power steering PRCode: TD1 = 4-cylinder diesel engine 2.0 L unit 04L.C PRCode: U5A = Instrument insert km/h speedometer PRCode: X3B = National sales program Spain (FBU) Pues el 1er codigo que pone tiptronic no debe de ser muy correcto cuando el coche trae s-tronic. Raro no? Responder
YagoA4avant Publicado 4 de Abril del 2016 Denunciar Publicado 4 de Abril del 2016 Por otro lado, si lleva virtual cockpit ha de ser necesariamente mmi plus. Aunque no he preguntado al comercial ahora pienso que si era el plus, he abierto la guantera y he visto que además de las ranuras para las SD también tenía una para la SIM. El mmi normal no lleva ranura para la sim? Entonces cómo se conecta el Audi connect safety y service? Responder
ariam2001 Publicado 4 de Abril del 2016 Autor Denunciar Publicado 4 de Abril del 2016 Esta es la traducción de la etiqueta: PRCode: 0G7 = Tiptronic PRCode: 0JH = Weight category front axle weight range 8 PRCode: 0YH = Weight range 8 installation control only no requirement forecast PRCode: 1BE = Sports suspension/shock absorption PRCode: 1KD = Disc brakes rear PRCode: 1LC = Disc brakes front PRCode: 1SA = Without additional engine guard PRCode: 2K6 = Reinforced bumpers PRCode: 2PF = Leather trimmed multi-function sports steering wheel PRCode: 3FA = Without roof insert (standard roof) PRCode: 3L3 = Manual height adjustment for front seats PRCode: 3NT = Rear seat bench/backrest in glass fiber PRCode: 3Y0 = Without roll-up sun screen PRCode: 4GF = Windshield in heat-insulating glass PRCode: 4KC = Side and rear windows in heat-insulatingglass PRCode: 4UF = Driver's and front passenger air bag with front passenger air bag deactivation PRCode: 4X3 = Side air bag front with curtain air bag PRCode: 5D1 = Carrier frequency 433.92 MHz-434.42 Mhz PRCode: 5RU = Right exterior mirror: convex (large viewing field) PRCode: 5SL = Left exterior mirror: aspherical PRCode: 5TG = Decorative aluminum inserts dulling PRCode: 6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated PRCode: 7K1 = Tire pressure warning light PRCode: 7MM = Emission standard EU6 plus PRCode: 7UG = Navigation system - High PRCode: 7X2 = Park distance control front and rear PRCode: 8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving) PRCode: 8Z4 = Moderate hot country PRCode: 9G3 = Alternator 120-180 A PRCode: 9S8 = Multi-function display/trip computer Medium without energy efficiency display PRCode: DE5 = 4-cyl. turbo dies. eng. 2.0 l/140 kW 4V TDI common rail Base engine is TD1 PRCode: E0A = No special edition PRCode: F0A = No special purpose vehicle standard equipment PRCode: J1N = Battery 420 A (75 Ah) PRCode: LZ7 = With marine transmission ZF 80A PRCode: N7K = Alcantara/leather seat covering PRCode: Q1D = Sports front seats PRCode: QI6 = Without service indicator PRCode: QZ7 = Power steering PRCode: TD1 = 4-cylinder diesel engine 2.0 L unit 04L.C PRCode: U5A = Instrument insert km/h speedometer PRCode: X3B = National sales program Spain (FBU) Pues el 1er codigo que pone tiptronic no debe de ser muy correcto cuando el coche trae s-tronic. Raro no? La página de dónde lo,saqué no estaba muy actualizada. Responder
Xuanki Publicado 4 de Abril del 2016 Denunciar Publicado 4 de Abril del 2016 Por otro lado, si lleva virtual cockpit ha de ser necesariamente mmi plus. Aunque no he preguntado al comercial ahora pienso que si era el plus, he abierto la guantera y he visto que además de las ranuras para las SD también tenía una para la SIM. El mmi normal no lleva ranura para la sim? Entonces cómo se conecta el Audi connect safety y service? Sí que tiene aunque no sea el plus, para ser exactos en la guantera lleva las dos ranuras para sd (una para el navegador), la ranura SIM y el cd. Responder
YagoA4avant Publicado 4 de Abril del 2016 Denunciar Publicado 4 de Abril del 2016 Por otro lado, si lleva virtual cockpit ha de ser necesariamente mmi plus. Aunque no he preguntado al comercial ahora pienso que si era el plus, he abierto la guantera y he visto que además de las ranuras para las SD también tenía una para la SIM. El mmi normal no lleva ranura para la sim? Entonces cómo se conecta el Audi connect safety y service? Sí que tiene aunque no sea el plus, para ser exactos en la guantera lleva las dos ranuras para sd (una para el navegador), la ranura SIM y el cd. Eso tenía entendido. Gracias. Responder
ariam2001 Publicado 4 de Abril del 2016 Autor Denunciar Publicado 4 de Abril del 2016 Por otro lado, si lleva virtual cockpit ha de ser necesariamente mmi plus. Aunque no he preguntado al comercial ahora pienso que si era el plus, he abierto la guantera y he visto que además de las ranuras para las SD también tenía una para la SIM. El mmi normal no lleva ranura para la sim? Entonces cómo se conecta el Audi connect safety y service? Sí que tiene aunque no sea el plus, para ser exactos en la guantera lleva las dos ranuras para sd (una para el navegador), la ranura SIM y el cd. Tenía una ranura para el cd en el medio de las dos ranuras de las SD. Responder
Xuanki Publicado 4 de Abril del 2016 Denunciar Publicado 4 de Abril del 2016 Por otro lado, si lleva virtual cockpit ha de ser necesariamente mmi plus. Aunque no he preguntado al comercial ahora pienso que si era el plus, he abierto la guantera y he visto que además de las ranuras para las SD también tenía una para la SIM. El mmi normal no lleva ranura para la sim? Entonces cómo se conecta el Audi connect safety y service? Sí que tiene aunque no sea el plus, para ser exactos en la guantera lleva las dos ranuras para sd (una para el navegador), la ranura SIM y el cd. Tenía una ranura para el cd en el medio de las dos ranuras de las SD. Ah si? El mío lleva la sim entre las dos sd y el cd justo encima de las tres anteriores. Habrá varias versiones. O quizás sea una unidad que llevase DVD? Responder
juan_ignacio Publicado 5 de Abril del 2016 Denunciar Publicado 5 de Abril del 2016 De los modelos preserie estos, hay que tener cuidado en que el precio PVP que le ponen es de cada extra por separado, dado que cuando les han fabricado, Audi España no tiene los paquetes o acabados sport, desing... o el que sea, por lo que el precio es mucho mas elevado que si le pides nuevo con paquetes de equipamiento. Responder
ariam2001 Publicado 5 de Abril del 2016 Autor Denunciar Publicado 5 de Abril del 2016 Perdón, lleva la sim entre las dos sd y el DVD o CD encima. Responder
