Carfersel Publicado 14 de Mayo del 2016 Denunciar Compartir Publicado 14 de Mayo del 2016 hola muy buenas noches, resulta que esta tarde hice un scan al coche y me salieron varios códigos de error exactamente estos 05-Acc/Start Auth. -- Status: Malfunction 0010 Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 BD HW: 8K0 907 064 D Component: BCM2 1.1 H70 0251 Revision: 00002001 Coding: 070100 Shop #: WSC 02399 823 56573 VCID: 73E53947D240F386991-8026 Subsystem 1 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C Component: ELVAUDIB8 H35 0039 1 Fault Found: 00956 - Key 2 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 17 Reset counter: 157 Mileage: 104968 km Time Indication: 0 Date: 2015.11.08 Time: 13:50:57 07-Control Head -- Status: Malfunction 0010 Address 07: Control Head Cannot be reached 19-CAN Gateway -- Status: Malfunction 0010 Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 G HW: 8T0 907 468 G Component: GW-BEM 5CAN-M H08 0084 Revision: FB102034 Serial number: 3400F07913807E Coding: 000003 Shop #: WSC 78896 024 535012 VCID: 4581B79FCC543D36E75-8010 Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181 Component: J367-BDM H06 0150 1 Fault Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 179 Mileage: 90850 km Time Indication: 0 Date: 2014.03.19 Time: 10:38:44 36-Seat Mem. Drvr -- Status: Malfunction 0010 Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb Part No SW: 8K0 959 760 A HW: 8K0 959 760 A Component: MEM-FS H04 0042 Revision: AA000000 Serial number: 00001001035375 Coding: C0581B000F0044110000 Shop #: WSC 02399 823 56573 VCID: 387FCE6B8BA650DE6C3-806D 1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 98528 km Time Indication: 0 Date: 2015.03.31 Time: 12:11:40 46-Central Conv. -- Status: Malfunction 0010 Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 BD HW: 8K0 907 064 D Component: BCM2 1.1 H70 0251 Revision: 00002001 Serial number: 0106755070 Coding: 011A0E20003904C10130010000000000 Shop #: WSC 04450 572 75257 VCID: 73E53947D240F386991-8026 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0030 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 1 Fault Found: 01134 - Alarm Horn (H12) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 106 Mileage: 105140 km Time Indication: 0 Date: 2015.11.22 Time: 19:57:27 52-Door Elect, Pass. -- Status: Malfunction 0010 Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 B HW: 8K0 959 792 Component: TSG BF H09 0170 Revision: Serial number: 0000006653658 Coding: 011C12205E00410001 Shop #: WSC 02399 823 56573 VCID: 3E73D873A9826EEEA6F-806B 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 181 Mileage: 106487 km Time Indication: 0 Date: 2016.03.27 Time: 10:19:08 Muchísimas gracias, y a ver si alguien me puede decir que es, mae mía, que me tiene mosca un saludo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Carfersel Publicado 14 de Mayo del 2016 Autor Denunciar Compartir Publicado 14 de Mayo del 2016 He de decir que la centralita del teléfono la tengo fundida y creo que me la desconectaron en el conce gracias Responder Enlace al comentario Compartir en otros sitios web More sharing options...
korny1976 Publicado 14 de Mayo del 2016 Denunciar Compartir Publicado 14 de Mayo del 2016 Y la del modulo 46 alarm horn 014 defective tambien creo qesta averiada Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Tineo Publicado 16 de Mayo del 2016 Denunciar Compartir Publicado 16 de Mayo del 2016 Salvo el asunto de Control Head que parece chungo,son errores muy antiguos. Borralos y pasa scan de nuevo. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Carfersel Publicado 16 de Mayo del 2016 Autor Denunciar Compartir Publicado 16 de Mayo del 2016 Salvo el asunto de Control Head que parece chungo,son errores muy antiguos. Borralos y pasa scan de nuevo.Es chungo? Q significa lo de control head???Muchas gracias Un saludo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Tineo Publicado 16 de Mayo del 2016 Denunciar Compartir Publicado 16 de Mayo del 2016 Salvo el asunto de Control Head que parece chungo,son errores muy antiguos. Borralos y pasa scan de nuevo.Es chungo? Q significa lo de control head???Muchas gracias Un saludo vaya, me he pasado con lo de chungo, Control head es el modulo que gobierna el MMI, si no tiene acceso a ese módulo instalado puede ser solamente un fusible cascado, para empezar borra todos los errores Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Carfersel Publicado 16 de Mayo del 2016 Autor Denunciar Compartir Publicado 16 de Mayo del 2016 Salvo el asunto de Control Head que parece chungo,son errores muy antiguos. Borralos y pasa scan de nuevo.Es chungo? Q significa lo de control head???Muchas gracias Un saludo vaya, me he pasado con lo de chungo, Control head es el modulo que gobierna el MMI, si no tiene acceso a ese módulo instalado puede ser solamente un fusible cascado, para empezar borra todos los errores De acuerdo, ahora lo hare, y una pregunta, se puede hacer un scan y borrado con el vag y el motor arrancado? Muchísimas gracias. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Jo_Coleguita Publicado 16 de Mayo del 2016 Denunciar Compartir Publicado 16 de Mayo del 2016 Salvo el asunto de Control Head que parece chungo,son errores muy antiguos. Borralos y pasa scan de nuevo.Es chungo? Q significa lo de control head???Muchas gracias Un saludo vaya, me he pasado con lo de chungo, Control head es el modulo que gobierna el MMI, si no tiene acceso a ese módulo instalado puede ser solamente un fusible cascado, para empezar borra todos los errores De acuerdo, ahora lo hare, y una pregunta, se puede hacer un scan y borrado con el vag y el motor arrancado? Muchísimas gracias. Que me corrijan si me equivoco, pero lo suyo es hacerlo con el contacto puesto, sin arrancarlo. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Carfersel Publicado 16 de Mayo del 2016 Autor Denunciar Compartir Publicado 16 de Mayo del 2016 hola muy buenas noches, al final lo hice con el motor arrancado y borre los errores como me dijo tineo, ahora solo me ha dado dos errores, la de la bocina de la alarma como bien me dijo korny1976 y me salió esto: Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb Part No SW: 8T0 035 730 HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 331JN077514073 Coding: 0000004 Shop #: WSC 00445 572 175257 VCID: EED3A833F9625E6EF6F-80BB Subsystem 1 - Part No: 8T0 919 609 C Component: E0380 BedienteilH07 0100 Subsystem 2 - Serial number: 00000000022781 Subsystem 3 - Serial number: 0111.10.070000000100010179ˇ Subsystem 4 - Serial number: 010179ˇ 1 Fault Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 151 Mileage: 107177 km Time Indication: 0 Date: 2016.05.16 Time: 20:26:21 ------------------------------------------------------------------------------- buenas noches y un saludo gracias Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Tineo Publicado 16 de Mayo del 2016 Denunciar Compartir Publicado 16 de Mayo del 2016 Esta relacionado con el modulo bt que tienes desconectado: o codificas como que no lo tienes instalado o sustituyes ese módulo por uno que funcione. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Carfersel Publicado 17 de Mayo del 2016 Autor Denunciar Compartir Publicado 17 de Mayo del 2016 Muchísimas gracias por la ayuda. Un saludo a todos Responder Enlace al comentario Compartir en otros sitios web More sharing options...
