MIGUELJTD Publicado 31 de Mayo del 2016 Denunciar Publicado 31 de Mayo del 2016 Buenas a todos necesito que me echeis un cable con los errores que me arroja el Vagcom con el climatizador que basicamente no va y otro error con el ABS para saber exactamente que son y ponerles remedio. Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No: 1K0 907 379 K Component: ESP FRONT MK60 0103 Coding: 0023174 Shop #: WSC 80093 222 69422 VCID: 3A712AA875A158CE9A7-806F1 Fault Found:01435 - Brake Pressure Sensor 1 (G201) 012 - Electrical Fault in Circuit - Intermittent-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 E HW: 8P0 820 043 E Component: KlimavollautomatH12 0150 Revision: 021236 Serial number: 8P0820043E Shop #: WSC 00000 000 00000 VCID: 2E5916F8B9E9846E36F-807B4 Faults Found:01274 - Air Flow Flap Positioning Motor (V71) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 3 Fault Frequency: 110 Reset counter: 48 Mileage: 162783 km Time Indication: 0 Date: 2016.02.01 Time: 01:05:34 Freeze Frame: Voltage: 14.20 V Temperature: 26.5°C (no units): 25.0 (no units): 65.0 Temperature: 20.0°C00796 - Fan for Interior Temp Sensor (V42) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 25 Reset counter: 45 Mileage: 148857 km Time Indication: 0 Date: 2015.02.08 Time: 17:53:04 Freeze Frame: Voltage: 12.30 V Temperature: 16.5°C01810 - Actuating Motor for Temperature Flap; Right (V159) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 88 Mileage: 168059 km Time Indication: 0 Date: 2016.05.31 Time: 18:22:15 Freeze Frame: Voltage: 12.30 V Temperature: 34.0°C (no units): 30.0 (no units): 29.0 Temperature: 22.0°C01273 - Fresh Air Blower (V2) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 9 Reset counter: 88 Mileage: 167295 km Time Indication: 0 Date: 2016.05.12 Time: 20:13:10 Freeze Frame: Temperature: 23.0°C Speed: 37.7 km/h (no units): 47.0 (no units): 139.0 Responder
brais Publicado 2 de Junio del 2016 Denunciar Publicado 2 de Junio del 2016 aqui puedes consultar el error y sus soluciones lo vas traduciendo por google y seguro que lo arreglas te digo lo del primer error http://wiki.ross-tech.com/wiki/index.php/01435 un saludo amigo Responder
MIGUELJTD Publicado 2 de Junio del 2016 Autor Denunciar Publicado 2 de Junio del 2016 Gracias, solo me sale el primero pero algo es algo. Responder
