A6MOGRO Publicado 30 de Agosto del 2016 Denunciar Publicado 30 de Agosto del 2016 Hola a todos. Agradecería a los sabios en estos temas si me pudieran aclarar algo. Anteayer me guardé un log de la bomba inyectora en mi AKE y me salían estos datos: 4B2 907 401 B,, 2.5l/4VTEDC G000AG D01 , ,Group A:,'004,,,,Group B:, Not Running,,,,Group C:, Not Running ,,Engine speed,Spec. start,Actual start,Cold start valve,,,,,,,,,, ,TIME,3800-4200 rpm,10-14 *BTDC,8-16 *BTDC,,TIME,,,,,TIME,,,, Marker,STAMP, /min,, °BTDC, %,STAMP,,,,,STAMP,,,, ,0.14,835,Early,15.0,5.5,,,,,,,,,, ,0.51,835,Early,15.0,5.5,,,,,,,,,, ,0.87,835,Early,14.8,6.7,,,,,,,,,, ,1.24,835,Early,15.0,5.5,,,,,,,,,, ,1.60,835,Early,15.0,6.3,,,,,,,,,, ,1.97,835,Early,14.8,5.1,,,,,,,,,, ,2.33,835,Early,15.0,5.5,,,,,,,,,, ,2.69,835,Late,14.8,5.1,,,,,,,,,, ,3.06,835,Late,5.0,100.2,,,,,,,,,, ,3.42,858,Late,-1.2,100.2,,,,,,,,,, ,3.79,835,Late,-1.4,100.2,,,,,,,,,, ,4.15,835,Late,-1.4,100.2,,,,,,,,,, ,4.52,835,Late,-1.6,100.2,,,,,,,,,, ,4.88,835,Late,-1.6,100.2,,,,,,,,,, ,5.24,835,Late,-1.4,100.2,,,,,,,,,, ,5.61,835,Late,-1.6,100.2,,,,,,,,,, ,5.97,835,Late,-1.4,100.2,,,,,,,,,, ,6.34,835,Late,-1.4,100.2,,,,,,,,,, ,6.70,835,Late,-1.4,100.2,,,,,,,,,, ,7.07,835,Late,-1.4,100.2,,,,,,,,,, ,7.43,835,Late,-1.6,100.2,,,,,,,,,, ,7.80,835,Late,-1.4,100.2,,,,,,,,,, ,8.16,835,Late,-1.4,100.2,,,,,,,,,, ,8.53,835,Late,-1.6,100.2,,,,,,,,,, ,8.89,835,Late,-1.4,100.2,,,,,,,,,, ,9.25,835,Late,-1.4,100.2,,,,,,,,,, ,9.62,835,Late,-1.4,100.2,,,,,,,,,, ,9.98,835,Late,-1.4,100.2,,,,,,,,,, ,10.35,835,Late,-1.4,100.2,,,,,,,,,, ,10.71,835,Late,-1.4,100.2,,,,,,,,,, ,11.07,835,Late,-1.4,100.2,,,,,,,,,, ,11.44,835,Late,-1.4,100.2,,,,,,,,,, ,11.80,835,Late,-1.4,100.2,,,,,,,,,, ,12.17,835,Late,-1.6,100.2,,,,,,,,,, ,12.53,835,Late,-1.4,100.2,,,,,,,,,, ,12.90,835,Early,-1.4,100.2,,,,,,,,,, ,13.26,858,Early,7.0,5.5,,,,,,,,,, ,13.63,835,Early,9.8,11.8,,,,,,,,,, ,13.99,835,Early,12.0,9.9,,,,,,,,,, ,14.36,835,Early,13.8,3.6,,,,,,,,,, ,14.72,835,Early,14.6,3.9,,,,,,,,,, ,15.09,835,Early,15.2,5.1,,,,,,,,,, ,15.45,835,Early,15.2,6.3,,,,,,,,,, ,15.82,835,Early,14.8,6.3,,,,,,,,,, ,16.18,835,Early,14.8,6.7,,,,,,,,,, ,16.54,835,Early,14.8,6.3,,,,,,,,,, ,16.91,835,Early,15.0,6.3,,,,,,,,,, ,17.27,835,Early,14.8,5.9,,,,,,,,,, ,17.64,835,Early,15.0,6.7,,,,,,,,,, ,18.00,835,Early,14.8,6.7,,,,,,,,,, ,18.37,835,Early,15.0,7.1,,,,,,,,,, ,18.73,835,Early,14.8,6.3,,,,,,,,,, ,19.10,835,Early,14.8,5.5,,,,,,,,,, ,19.46,835,Early,15.0,5.9,,,,,,,,,, ,19.82,835,Early,14.8,6.3,,,,,,,,,, ,20.19,835,Early,15.0,5.9,,,,,,,,,, ,20.55,835,Early,15.0,6.7,,,,,,,,,, ,20.92,835,Early,14.8,6.3,,,,,,,,,, ,21.28,835,Early,15.2,6.3,,,,,,,,,, ,21.65,835,Early,15.0,6.3,,,,,,,,,, ,22.01,835,Early,14.8,5.5,,,,,,,,,, ,22.37,835,Early,15.2,6.7,,,,,,,,,, ,22.74,835,Early,14.8,5.5,,,,,,,,,, ,23.09,835,Late,15.0,6.3,,,,,,,,,, ,23.45,835,Late,2.6,100.2,,,,,,,,,, ,23.81,858,Late,-1.2,100.2,,,,,,,,,, ,24.18,835,Late,-1.2,100.2,,,,,,,,,, ,24.54,835,Late,-1.4,100.2,,,,,,,,,, ,24.90,835,Late,-1.2,100.2,,,,,,,,,, ,25.27,835,Late,-1.4,100.2,,,,,,,,,, ,25.63,835,Late,-1.4,100.2,,,,,,,,,, ,26.00,835,Late,-1.2,100.2,,,,,,,,,, ,26.36,835,Late,-1.4,100.2,,,,,,,,,, ,26.73,835,Late,-1.2,100.2,,,,,,,,,, ,27.09,835,Late,-1.4,100.2,,,,,,,,,, ,27.46,835,Late,-1.2,100.2,,,,,,,,,, ,27.82,835,Late,-1.4,100.2,,,,,,,,,, ,28.18,835,Late,-1.4,100.2,,,,,,,,,, ,28.55,835,Late,-1.2,100.2,,,,,,,,,, ,28.91,835,Late,-1.2,100.2,,,,,,,,,, ,29.28,835,Late,-1.2,100.2,,,,,,,,,, ,29.64,835,Late,-1.4,100.2,,,,,,,,,, ,30.01,835,Late,-1.2,100.2,,,,,,,,,, ,30.37,835,Late,-1.2,100.2,,,,,,,,,, ,30.73,835,Late,-1.2,100.2,,,,,,,,,, ,31.10,835,Late,-1.2,100.2,,,,,,,,,, ,31.46,835,Late,-1.2,100.2,,,,,,,,,, ,31.83,835,Late,-1.4,100.2,,,,,,,,,, ,32.19,835,Late,-1.2,100.2,,,,,,,,,, ,32.55,835,Late,-1.4,100.2,,,,,,,,,, ,32.89,835,Late,-1.2,100.2,,,,,,,,,, Por lo que os he podido leer en el foro, ¿ los valores de LATE no estarían por debajo de lo que debería? o está todo correcto. Si alguno de los valores está mal, ¿podría afectar al sonido de la bomba o al funcionamiento de esta? Decir que el coche lo utilizo muy poco, a veces ni gasto un tanque al mes y me gustaría ponerlo a punto para que me dure muchos años más. Arranca perfectamente en frío, no tanto en caliente, nada de humos ni cosas raras salvo que, a veces, cuando le da hace una pequeña sacudida y despues continua con el ralentí normal... y el consumo lo considero normal, vengo a hacer unos 850 kms por tanque. Muchas gracias a todos Responder
a34323 Publicado 30 de Agosto del 2016 Denunciar Publicado 30 de Agosto del 2016 Lo del arranque en caliente es normal en los vag. Cosas del desgaste del motor de arranque. Por otro lado, no podrías sacar gráfica de esos datos? porque yo sí que no sé interpretar datos. Responder
A6MOGRO Publicado 30 de Agosto del 2016 Autor Denunciar Publicado 30 de Agosto del 2016 Lo intento esta tarde y lo subo. Gracias por el interés. Responder
A6MOGRO Publicado 31 de Agosto del 2016 Autor Denunciar Publicado 31 de Agosto del 2016 Buenos días a todos. Creo que es esto lo que me pedía ayer a34323 de la gráfica. Si necesitáis algo más pedidlo. Responder
A6MOGRO Publicado 31 de Agosto del 2016 Autor Denunciar Publicado 31 de Agosto del 2016 Y otra Responder
a34323 Publicado 31 de Agosto del 2016 Denunciar Publicado 31 de Agosto del 2016 Está dentro del rango. En mi coche cuando le hice la distribución se me quedó como en tu coche. No la ajusté más. Responder
A6MOGRO Publicado 31 de Agosto del 2016 Autor Denunciar Publicado 31 de Agosto del 2016 Muchas gracias a34323 me quedo más tranquilo entonces. Saludos desde Cantabria Responder
