alguno me puede decir algosobre estas averias en mi A6 3.2 FSI
5 Faults Found:
008196 - Intake Manifold Flap; Bank 1
P2004 - 007 - Stuck Open
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 165
Reset counter: 40
Mileage: 172721 km
Time Indication: 0
Date: 2016.12.28
Time: 18:08:37
Freeze Frame:
RPM: 768 /min
Mass Air / Rev.: 196.2 mg/str
Temperature: 51.0°C
Idle
Voltage: 4.160 V
Speed: 5.0 km/h
008197 - Intake Manifold Flap; Bank 2
P2005 - 007 - Stuck Open
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 172721 km
Time Indication: 0
Date: 2016.12.28
Time: 18:08:37
Freeze Frame:
RPM: 768 /min
Temperature: 51.0°C
Idle
Voltage: 3.840 V
Speed: 5.0 km/h
004133 - Fuel Pressure Regulation Valve (N276)
P1025 - 006 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 98
Reset counter: 40
Mileage: 172722 km
Time Indication: 0
Date: 2016.12.28
Time: 18:12:55
Freeze Frame:
RPM: 1504 /min
Mass Air / Rev.: 446.9 mg/str
Temperature: 88.5°C
Part Throttle
Pressure: 55.3 bar
Speed: 43.0 km/h
012555 - Low Pressure Fuel regulation
P310B - 006 - Fuel Pressure Outside Specification - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 21
Mileage: 173016 km
Time Indication: 0
Date: 2016.12.30
Time: 13:57:24
Freeze Frame:
RPM: 1152 /min
Mass Air / Rev.: 92.7 mg/str
Temperature: 91.5°C
Idle
Pressure: 6.3 bar
Speed: 10.0 km/h
008304 - Intake Manifold Tuning Valve (Bank 1)
P2070 - 006 - Stuck Open - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 39
Mileage: 173420 km
Time Indication: 0
Date: 2017.01.02
Time: 11:39:50
Freeze Frame:
RPM: 960 /min
Mass Air / Rev.: 277.9 mg/str
Temperature: 12.0°C
Idle
Absolute Pres.: 606.5 mbar
Speed: 3.0 km/h
Readiness: 0000 0000
Gracias anticipadas
Hola a todos: por fin me llego el vag-com, también con versión española, estaba impaciente por hacerle un chequeo general y me dio 2 averías detectadas que son estas: dirección 07: 01317 - unidad de control en el cuadro de instrumentos (j285)
004 - sin señal/comunicación - intermitente
Cuadro congelado:
Estado de avería: 00100100
Prioridad de avería: 5
Frecuencia de avería: 1
Respetemos del contador: 255
Indicación de tiempo: 0
Cuadro congelado: Bin. Bits:0000010
Dirección 09: central eléctrica:
2 averías detectadas: 00003 - unidad de control: 014 - defectuoso/a/S
Cuadro congelado:
Estado de avería: 01111110
Prioridad de avería: 2
Frecuencia de avería: 2
Reseteos del contador: 118
Kiletraje: 179.924 kms
Fecha: 2013.04.23
Tiempo: 09:57:00
02382 - sensor de detección de la luz (G399)
Cuadro congelado:
Estado de la avería: 01101110
Prioridad avería: 2
Frecuencia avería: 65
Reseteos contador: 118
Kilómetros: 221.916 km
Fecha: 2017.01.02
Tiempo: 07:41:00
Kilómetros actuales: 222.133
Qué puedo a hacer con estas averías y su solución.
Agradezco las ayudas que me podáis hechar. Gracias
Hola a todos: me gustaría saber de dos averías detectadas en mi Audi A6 c6 4F2, he hecho una verificación con el Vag-Com español y me ha dado esto:
Dirección 09: Central eléctr. Etiquetas: EST\4F0-910-279.clb
N°. de Parte SW: 4F0 910 279 B HW: 4F0 907 279 B
Componente: ILM Fahrer H14 0080
Versión: 00000000 N° de Serie: 4F0907279
Codificación: 0000101
Nº Taller: WSC 02335 785 00200
VCID: 2858610B9BA0C76106F-807D
Subsistema 1 - N°. de Parte: 4F1 910 113 Etiquetas: EST\1KX-955-119.CLB
Componente: Wischer AudiC6 H05 0150
Codificación: 00062736
Subsistema 2 - N°. de Parte: 4E0 910 557 Etiquetas: EST\8K0-955-559.CLB
Componente: REGENLICHTSENSORH10 0040
Codificación: 00137492
2 Averías detectadas:
00003 - Unidad de control
014 - Defectuoso/a/s
Cuadro Congelado:
Estado de Avería: 01111110
Prioridad de Avería: 2
Frecuencia de Avería: 2
Reseteos del Contador: 123
Kilometraje: 179924 km
Indicación de Tiempo: 0
Fecha: 2013.04.23
Tiempo: 09:57:00
02382 - Sensor de detección de la luz (G399)
Cuadro Congelado:
Estado de Avería: 01101110
Frecuencia de Avería: 4
Kilometraje: 222152 km
Fecha: 2017.02.20
Tiempo: 00:14:00
Muchas gracias de antemano. Saludos al foro.
Aparentemente el coche va bien y no le he notado nada raro y visible, así qué no se que puede ser esta avería, lo único que no funciona es el detector de lluvia que se encuentra creo en el espejo retrovisor interior y la luz del parasol lado conductor.
