gaspacho Publicado 7 de Junio del 2017 Denunciar Publicado 7 de Junio del 2017 Monday,05,June,2017,17:30:57:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.1.3.0 (x64) Data version: 20170203 DS267.2 www.Ross-Tech.com Mileage: 69260km-43036mi Repair Order: Chassis Type: 8L - Audi A3/S3 (1997 > 2005) Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76 Mileage: 69260km-43036miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06A-906-033-AVU.lbl Part No: 06A 906 033 J Component: SIMOS33 1,6l 2V 00HS3488 Coding: 00211 Shop #: WSC 06435 VCID: 26442DDAC27C4D71B3-515A WAUZZZ8L************* AUZ************ 3 Faults Found: 17950 - Angle Sensor 1 for Throttle Actuator (G187) P1542 - 35-10 - Implausible Signal - Intermittent 17950 - Angle Sensor 1 for Throttle Actuator (G187) P1542 - 35-10 - Implausible Signal - Intermittent 16555 - Fuel Trim; Bank 1 P0171 - 35-00 - System Too Lean Readiness: 0000 1000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl Part No: 1C0 907 379 C Component: ABS FRONT MK60 0103 Coding: 0001025 Shop #: WSC 06435 000 00000 VCID: 2A5CD9EA8664691197-515A 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: Redir Fail! Part No: 8L0 820 043 H Component: A3 KLIMAAUTOMAT 0105 Coding: 01040 Shop #: WSC 06435 VCID: 2D56D2F6E78A7E2972-259E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8L0-959-655-AI8.lbl Part No: 8L0 959 655 J Component: Airbag Front+Seite 5008 Coding: 00104 Shop #: WSC 06435 VCID: 45868A565F3AA6699A-5178 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8L0-920-xxx-17.lbl Part No: 8L0 920 900 HØ Component: KOMBI+WEGFAHRS. M73 D54 Coding: 08142 Shop #: WSC 00000 VCID: 0818436228A87B01A1-4B18 Subsystem 1 - Part No: WAUZZZ8 Component: Z1A115259 AUZ5Z0A42Z512s WAUZZZ8Î********** AUZ**************** No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8D0 862 257 B Component: ZV-Pumpe, Funk D16 Coding: 14913 Shop #: WSC 06435 VCID: 2C50DFF2DC90772165-4F02 1 Fault Found: 01389 - Tailgate Open Switch (F124) 29-00 - Short to Ground End-------------------------(Elapsed Time: 03:47)-------------------------- Monday,05,June,2017,17:32:25:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.1.3.0 (x64) Data version: 20170203 DS267.2 www.Ross-Tech.com Mileage: 69260km-43036mi Repair Order: VCDS Release 17.1.3: SRI Reset Control Module Part Number: 8L0 920 900 HØ Labels: 8L0-920-xxx-17.lbl Component:KOMBI+WEGFAHRS. M73 D54, Coding:08142 Operation: Please select an operation ************************************************************************************************************************ Channel Description Unit Current val. New val. 02 Service Reminder Status 1 --- 40 Mileage since Service DIST x100 40 --- 41 Time since Service Days 735 --- 42 Min Mileage to Service DIST x1000 15 --- 43 Max Mileage to Service DIST x1000 177 --- 44 Max Time to Service Days 365 --- 45 Oil Quality 1 --- ************************************************************************************************************************ Responder
Carlisu84 Publicado 7 de Junio del 2017 Denunciar Publicado 7 de Junio del 2017 ese mismo error lo tengo yo ahora en el mio y creo que es debido al pedal del acelerador Responder
GoNzCiD Publicado 14 de Junio del 2017 Denunciar Publicado 14 de Junio del 2017 Yo empezaría por el sensor o el pedal como dice Carlisu84 Responder
gaspacho Publicado 8 de Julio del 2017 Autor Denunciar Publicado 8 de Julio del 2017 gracias Responder
