Hola a todos
Tras cascar mi centralita bluetooth que traía el coche de origen (fallo 014 defective), he instalado una que hace unos días le he comprado a un compañero del foro. Tras una primera pasada del vag com, me ha dado los siguientes errores:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 1010
7D-Aux. Heat -- Status: OK 0000
Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
   Part No SW: 8P0 820 043 M    HW: 8P0 820 043 M
   Component: KlimavollautomatH18 0300
   Revision: 370677      Serial number: 8P0820043M
   Shop #: WSC 06314 000 00000
   VCID: 36693E9841B9BCAE7EF-8063
1 Fault Found:
01301 - Control Module for Voice Recognition (J507)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 112
                    Mileage: 227556 km
                    Time Indication: 0
                    Date: 2017.07.29
                    Time: 00:01:41
             Freeze Frame:
                        ON
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H34 0070
   Coding: 0004042
   Shop #: WSC 03492 572 55179
   VCID: 41835D4418770B16DBD-8014
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           H07 0090
2 Faults Found:
01303 - Telephone Transceiver (R36)
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 J    HW: 1K0 907 951
   Component: J533__Gateway   H12 0160
   Revision:   H12       Serial number: 32001067288090
   Coding: 7D3F0BC207002102
   VCID: 2E5916F8B9E9846E36F-807B
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186 C    HW: 8P0 035 186 C
   Component: concert II EU   H52 0100
   Revision:      02S    Serial number: AUZ2Z3F4365832
   Coding: 0002425
   VCID: 32610288ADD1A08E527-8067
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 112
Address 77: Telephone        Labels: 8P0-862-335.lbl
   Part No SW: 8P0 862 335 H    HW: 8P0 862 335 H
   Component: FSE_255x BT     H25 0290
   Revision: 00000000    Serial number: 00000005005724
   Coding: 0001255
   Shop #: WSC 00000 000 00000
   VCID: 3B7F2FAC7A9B61C6811-806E
1 Fault Found:
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 124
Al cambiarle la codificación por la propia de mi coche (con volante multifunción y sin navegador) y al borrarle los fallos, me encuentro con que la centralita conecta con mi teléfono, vuelca la agenda, consigo activar el control por voz pulsando el botón derecho del volante, pero no me escuchan por el micrófono a los que llamo ni el asistente por voz. Al hacer un diagnóstico, mantengo el fallo del módulo 77 que, aunque borre, vuelve a aparecer
   Coding: 0001255
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 72
He de decir que solamente cambié el código para indicarle que no tenía rnse, que si tenía volante multifunción y poco más, sin cambiar el work shop code ni nada más. La centralita corresponde a la misma letra (H) que la que tenía mi coche en origen y la antena que le he puesto, es la que me ha enviado el compañero con la centralita.
Entrando con el vagcom en el módulo 77, he comprobado que al micrófono le llega voltaje (8 voltios), pero al comprobar el status del micro input, me indica 0.000A y no tengo la más mínima idea de si es producto de que no funciona el micrófono o si se debe a otra cuestión, porque parece que corriente le llega.
Hay alguno que le haya pasado? En caso de que el micro haya palmado, tengo que obligatoriamente comprarle un micrófono original de audi o podría instalarle otro?
Espero que alguien pueda echarme un cable con el fallo.
Carlos
Hola a todos. Actualizo las comprobaciones
He comprobado que el cable que va de la centralita al micrófono da continuidad en los dos cables (negro y verde). Una vez comprobado esto, he comprobado los cables que tiene el propio micrófono y dan continuidad, por lo que pienso que el micro no lo cierra y esto último podría ser por lo que el circuito está abierto. Puede ser o estoy dando palos de ciego?.
Puestos a pensar, es posible que haya algo mal en alguno de los módulos del coche (aunque no salte ningún fallos en ellos) y por eso me da este error en el módulo del teléfono?. Desconozco si esto podría ser así.
Espero toda ayuda que me podáis ofrecer.
Carlos
En 12/8/2017 a las 15:45, korny1976 dijo:
Open circuit puede significar circuito abierto año mejor alguno de los cables del micro q
Esta suelto o roto podría ser
He abierto el micro y parece que está todo bien. Empiezo a pensar que el micro está averiado a nivel interno (la placa). He leido bicheando por ahí que puede ser ocasionado por la polaridad, que estuviera invertida. Aunque esto último me extraña pues es una centralita igual a la que yo tenía (mismo código y letra).
A ver si a alguno se os ocurre alguna cosa por la que tirar.
Carlos
