play23 Publicado 17 de Abril del 2005 Denunciar Publicado 17 de Abril del 2005 Hola. ¿Alguien puede decirme los fallos que me ha dado el vagcom y a que pueden deberse? VAG-COM Version: Release 311.2-N Chassis Type: 8L - Audi A3/S3 Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56 Address 01 ------------------------------------------------------- Controller: 8N0 906 018 BP Component: 1.8L R4/5VT 0002 Coding: 10710 Shop #: WSC 01236 WAUZZZ8L831212284 AUZ7Z0C2313544 No fault code found. Address 03 ------------------------------------------------------- Controller: 8N0 907 379 E Component: ESP 20 CAN V005 Coding: 18448 Shop #: WSC 01236 No fault code found. Address 08 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8L0 920 932 N Component: KOMBI+WEGFAHRS. VDO D09 Coding: 01144 Shop #: WSC 03109 WAUZZZ8L831212284 AUZ7Z0C2313544 No fault code found. Address 22 ------------------------------------------------------- Controller: 02D 900 554 C Component: HALDEX LSC ECC 0010 1 Fault Found: 00526 - Brake Light Switch-F 27-10 - Implausible Signal - Intermittent Address 35 ------------------------------------------------------- Controller: 8D0 862 257 Component: ZV-Pumpe, DWA, Funk D16 Coding: 15215 Shop #: WSC 03109 No fault code found. Address 45 ------------------------------------------------------- Controller: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 55 ------------------------------------------------------- Controller: 4B0 907 357 Component: LEUCHTWEITEREGLER D004 Coding: 00014 Shop #: WSC 01236 No fault code found. Address 56 ------------------------------------------------------- Controller: 8L0 035 186 J Component: concert II GRO 0008 Coding: 00001 Shop #: WSC 01236 No fault code found. End ------------------------------------------------------- Muchas gracias. Un saludo. Responder
otto69 Publicado 17 de Abril del 2005 Denunciar Publicado 17 de Abril del 2005 En el Address 08 parece que ha tenido muchos errores de comunicación, seria bueno volver a pasar el test solo de ese modulo. Address 22 Controller: 02D 900 554 C Component: HALDEX LSC ECC 0010 1 Fault Found: 00526 - Brake Light Switch-F 27-10 - Implausible Signal - Intermittent Este de arriba controla el pulsador del pedal del freno de pie, puede estar defectuoso. Saludos, Odón. Responder
play23 Publicado 18 de Abril del 2005 Autor Denunciar Publicado 18 de Abril del 2005 Muchas gracias por tu respuesta. ¿Podrías decirme que es el pulsador del pedal del freno de pie? ¿Tiene que ver con las luces de freno? Un saludo. Responder
Mad-i Publicado 18 de Abril del 2005 Denunciar Publicado 18 de Abril del 2005 pulsador del pedal del freno de pie <_< Eiiinnn? Salu2. PD.- Odón, se te echó de menos en Ocaña. Responder
play23 Publicado 19 de Abril del 2005 Autor Denunciar Publicado 19 de Abril del 2005 Nadie más puede decirme que son esos fallos? Un saludo. Responder
