Tineo Publicado 16 de Abril del 2019 Denunciar Publicado 16 de Abril del 2019 por lo que veo, hay nuevas actualizaciones válidas para todas las versiones de hardware... Android 6.0 System firmware update for HW1.0, 2.0, 3.0 * 2019.04.14: 1. Brightness control now can be customized: There are two brightness setup in Setting(Realsun Settings) 2. Music playback cracking is now suppressed. Must check and verify the Audio setup value after the update: Check the wiki's usage tips 3. Carinfo(All), Mainmenu Speedometer supports KM/H and MPH. To Setup, go to Setting(Realsun Settings), Speed Unit Settings 4. Carinfo(All), Mainmenu door indicator setup between LHD, RHD car can be now modified in Setting(Realsun Settings) 5. The function setup of Left Thumbwheel on the steering wheel can be now modified in Setting(Realsun Settings) 6. The main page's car image now can be customized: long press the Setting icon on the main page, then there will be a prompt to choose an image. The image must be PNG format, transparent background, 500x375px or below. 7. Translations have been updated. 8. System stability has been increased. 9. BT software module has been reviewed. *After the update, to prevent unexpected error, please do the factory restore from Setting, then, update all Google apps up to date from Play Store and then, must update Autoplay app from Apps by going to the app's Settings, 'Check updates'. Once Autoplay app update has been applied, go to setting and must reboot the system. *IF YOU NEGLECT TO UPDATE THE AUTOPLAY APP, THIS APP WILL CAUSE BLACK SCREEN AT FM/CD APP, AND FREQUENT RANDOM REBOOT. *YOU MUST UPDATE CANBUS FIRMWARE TO THE LATEST. DO NOT UPDATE MCU UNNECESSARILY. por lo que veo, cuestiones ligeras de ajustes y mejores configuraciones. Responder
danynosequemas Publicado 23 de Abril del 2019 Denunciar Publicado 23 de Abril del 2019 estoy leyendo el mensaje de daniel en la pagina de rsvnav y no entiendo muy bien al parecer con la ultima actualizacion puedes tener carplay sin necesidad de tener el movil conectado por cable??? luego dice que se esta testando un dongle para que haga esto mismamente y que puede estar listo en dos semanas?? quiere decir que el sofware esta listo pero que hace falta este dongle para que te funcione carplay sin conectar el movil por cable?? parece q el 7 pulgadas ahora esta barato 460$ y con esta funcion y la posibilidad de aztualizar a android 7 parece muy atractivo segun dice el mismo Daniel el dispositivo con caplay wireless mas barato del mundo yo estoy muy interesado por el tema del carplay alguien puede arrojar un poco de luz sobre el tema Responder
grabie Publicado 23 de Abril del 2019 Denunciar Publicado 23 de Abril del 2019 hace 1 hora, danynosequemas dijo: estoy leyendo el mensaje de daniel en la pagina de rsvnav y no entiendo muy bien al parecer con la ultima actualizacion puedes tener carplay sin necesidad de tener el movil conectado por cable??? luego dice que se esta testando un dongle para que haga esto mismamente y que puede estar listo en dos semanas?? quiere decir que el sofware esta listo pero que hace falta este dongle para que te funcione carplay sin conectar el movil por cable?? parece q el 7 pulgadas ahora esta barato 460$ y con esta funcion y la posibilidad de aztualizar a android 7 parece muy atractivo segun dice el mismo Daniel el dispositivo con caplay wireless mas barato del mundo yo estoy muy interesado por el tema del carplay alguien puede arrojar un poco de luz sobre el tema Creo entender que los "Standalone interface" y los "RSNAV Android system" (dos productos diferentes) ahora podrán funcionar en Carplay sin cables. Responder
Salmeron Publicado 25 de Abril del 2019 Denunciar Publicado 25 de Abril del 2019 En 23/4/2019 a las 12:18, grabie dijo: Creo entender que los "Standalone interface" y los "RSNAV Android system" (dos productos diferentes) ahora podrán funcionar en Carplay sin cables. Si, lo que dice es que para los primeros rsnav los que sacará es un dongle carplay wireless, vamos que conectaremos al usb y de ahi al movil sin cables Responder
danynosequemas Publicado 26 de Abril del 2019 Denunciar Publicado 26 de Abril del 2019 En 25/4/2019 a las 15:54, Salmeron dijo: Si, lo que dice es que para los primeros rsnav los que sacará es un dongle carplay wireless, vamos que conectaremos al usb y de ahi al movil sin cables si ahora en la pagina ya lo pone mas claro que habra una nueva version la 3.5 con carplay wireless y un donle para las versiones anteriores muchas ganas de que llegue Responder
grabie Publicado 27 de Abril del 2019 Denunciar Publicado 27 de Abril del 2019 Han sacado el parche para el android 7... con unas instrucciones de 11 páginas (nada más y nada menos). Con mi 7" de primera generación funcionando de lujo no pienso meterme en líos. Responder
Salmeron Publicado 30 de Abril del 2019 Denunciar Publicado 30 de Abril del 2019 En 27/4/2019 a las 18:53, grabie dijo: Han sacado el parche para el android 7... con unas instrucciones de 11 páginas (nada más y nada menos). Con mi 7" de primera generación funcionando de lujo no pienso meterme en líos. Ahora mismo es versión beta, no meto eso ni de coña, lo mismo cuando salga el fichero de actualización habitual (si es que se sigue haciendo así) Responder
paxama Publicado 30 de Abril del 2019 Denunciar Publicado 30 de Abril del 2019 (editado) Buenas chicos últimamente se me queda congelado el rsnav aleatoriamente y a partir de ahí me entra en un bucle y no pasa de la animación,vamos que sale la pantalla de aviso,empieza la animación y se resetea todo el rato,hay alguna manera de entrar en el recovery y hacerle el wipe data y factor reset? Luego cuando dejo el coche un rato para ya arranca el rsnav bien y funciona todo de lujo,hasta que se vuelve a congelar,ya he probado a formatearlo desde el menú y a darle al botón de reset que esta al lado de la pantalla. Saludos Editado 30 de Abril del 2019 por paxama Responder
TTenerife Publicado 14 de Mayo del 2019 Denunciar Publicado 14 de Mayo del 2019 En 30/4/2019 a las 14:47, paxama dijo: Buenas chicos últimamente se me queda congelado el rsnav aleatoriamente y a partir de ahí me entra en un bucle y no pasa de la animación,vamos que sale la pantalla de aviso,empieza la animación y se resetea todo el rato,hay alguna manera de entrar en el recovery y hacerle el wipe data y factor reset? Luego cuando dejo el coche un rato para ya arranca el rsnav bien y funciona todo de lujo,hasta que se vuelve a congelar,ya he probado a formatearlo desde el menú y a darle al botón de reset que esta al lado de la pantalla. Saludos Buenas noches Paxama, que sepas que ultimamente me pasa lo mismo que a ti, incluso de tanto resetearlo del menú, en una de ellas he perdido los bajos del audio, no sé, si sera problema del cable que va a la radio en la guantera, pero lo que si sé, es que me acabo de descargar todos los archivos para instalar Android 7.0, asi que estos días os diré algo. Yo poseo un HW 1.0 como la mayoria de todos, ya que el 2.0 y 3.0 han salido recientes. Si tiene que morir, pues que muera, y ya pasamos al 3.5 que tiene Wireless Carplay sin Dongle, por ahora probameros así Responder
TTenerife Publicado 14 de Mayo del 2019 Denunciar Publicado 14 de Mayo del 2019 Una vez ya me murió el aparato intentando actualizar, y despues de horas y horas revisando todo, resulta que fue el cable USB que era de los chinos. Pero ahora no tengo miedo asi que voy a leerme con calma las 11 paginas, ya que depende de cada modelo y cada version , lleva su historia, pero en realidad no se ve muy complicado, es casi lo mismo que formatear un Tablet, pero mas incómodo con el coche , el portatil, cables y nervios¡¡¡¡¡ . Lo del dongle Wireless , el primero que lo compre que avise como va , ya que me temo que a mi por ejemplo me iba casi de lujo, pero de vez en cuando petaba un poco con Lag ( retardo ), espero equivocarme y que pulan el Android 7.0 , por que estar enchufando todo el rato y quitando es medio coñazo, por lo menos para mi que puse el USB en la guantera para no tocar el movil mientras conduzco, ( Imposible , lo sabeis perfectamente ) Yo tengo un 10.25 Version HW 1.0 Meteré todo con Flash tool, creo que luego algo para recuperar el IMEI, y seguramente CAN_ BUS y MCU Deseadme suerte¡¡¡¡¡¡¡¡¡¡¡¡ Saludos a todos Responder
TTenerife Publicado 14 de Mayo del 2019 Denunciar Publicado 14 de Mayo del 2019 En 30/4/2019 a las 8:55, Salmeron dijo: Ahora mismo es versión beta, no meto eso ni de coña, lo mismo cuando salga el fichero de actualización habitual (si es que se sigue haciendo así) No saldrá, lo que estan haciendo es vender ya directamente con Android 7.0, quizas lo que me da un poco de respeto, es lo del IMEI, pero nada , espero que en un par de dias pueda subir fotos finalizado, y que de una vez se terminen los cuelgues, llevo una semana con la pantalla de inicicio Congelada, y al dia siguiente funciona como si no hubiese pasado nada. Responder
TTenerife Publicado 15 de Mayo del 2019 Denunciar Publicado 15 de Mayo del 2019 Por ahora , Rsnav muerto , habré intentado como 10 veces con todos los Firmware que hay disponible en wiki rsmav , creo que lo mejor será esperar el 3.5 con CarPlay wireless integrado o a las malas comprar placa Hw 3.0 con todo ya instalado y sin perder modem , Si alguien quiere aportar algo será de gran ayuda , se quedó en CAUTION y de ahí no pasa , me deja instalar todos los Firmware pero nada !!! Saludos Responder
TTenerife Publicado 20 de Mayo del 2019 Denunciar Publicado 20 de Mayo del 2019 Lo Solucioné por fin, quien necesite ayuda que me lo pida, Actualizado todo, CAN BUS, MCU y Android 7.0 + Update file, Al final , culpa de todo del modem 3G/4G ( le quite la tarjeta SIM que llevaba puesta y se acabo el problema que me estaba volviendo loco, llevo dos dias dandole caña para no hacerme ilusiones, y va bastante bien, ahora en vez del reloj sale el coche con puertas y cinturones, y el Velocimetro en KM/H , mas todas las opciones de Android 7.0 , 42 segundos en arrancar en frio con un HW 1.0 con 2GB de RAM Responder
TTenerife Publicado 20 de Mayo del 2019 Denunciar Publicado 20 de Mayo del 2019 Semana que viene me llega el Wireless Carplay , y os digo como va, esta es mi principal razon por la que me compre el equipo, entrar al coche y Carplay automatico, esperemos que no tenga demasido LAG o similar, ya que tengo carga inalambrica y lo dejo en su sitio , carga a la vez que se conecta sin ningun tipo de cables Responder
Tineo Publicado 21 de Mayo del 2019 Denunciar Publicado 21 de Mayo del 2019 hace 19 horas, TTenerife dijo: ...Al final , culpa de todo del modem 3G/4G ( le quite la tarjeta SIM que llevaba puesta y se acabo el problema que me estaba volviendo loco, un usb colgado puede liarla parda en cualquier dispositivo. Me alegra que esté superado el problema Responder
