A3 tdi 2.0 Publicado 24 de Octubre del 2017 Denunciar Compartir Publicado 24 de Octubre del 2017 Hola compañeros, Mi A5 me está empezando a dar guerra... lo he conectado al VAG-COM y este es el resultado: ======================================================== Tuesday,24,October,2017,19:06:59:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.0.0 Data version: 20130910 VIN: WAUZZZ8T98Axxxxxxx License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 059-907-401-CAP.clb Control Module Part Number: 8K0 907 401 HW: 8K0 907 401 Component and/or Version: 3.0TDI EDC17 H01 0006 Software Coding: 01140023180F0118 Work Shop Code: WSC 06325 000 00000 ASAM Dataset: EV_ECM30LTDIA5 A01008 (AU48) VCID: E8DFDE2B1386805EBC3-80BD 3 Faults Found: 7156 - Intake Manifold Flap Position Sensor (Bank 1) P2015 00 [168] - Implausible Signal MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 35 Mileage: 174552 km Date: 2017.09.27 Time: 11:51:19 7157 - Intake Manifold Flap Position Sensor (Bank 2) P2020 00 [032] - Implausible Signal Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 6 Mileage: 175502 km Date: 2017.10.13 Time: 16:35:01 4984 - Glowplug for Cylinder 1 (Q10) P161A 00 [109] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 174495 km Date: 2017.09.26 Time: 08:59:08 Readiness: 1 1 0 0 0 =========================================================== donde creéis que está el problema? gracias!!! Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Tineo Publicado 24 de Octubre del 2017 Denunciar Compartir Publicado 24 de Octubre del 2017 Tiene pinta de chapaletas de admisión,. Comprueba holguras en la bancada 1 (lado copiloto) Responder Enlace al comentario Compartir en otros sitios web More sharing options...
A3 tdi 2.0 Publicado 11 de Noviembre del 2017 Autor Denunciar Compartir Publicado 11 de Noviembre del 2017 Buenas!! Bueno, 1 problema solucionado. Los errores referentes a las chapaletas de admisión creo que ya los he solucionado. Para eso he seguido el tutorial publicado por Jordituner en este post: Diré que para mi A5 (con código de motor CAPA) no ha sido nada sencillo sacar las bancadas ya que el espacio que hay es muy justo y además los tubos del refrigerante pasan por encima de ambas bancadas y molestan un poco, pero con paciencia todo se puede. Ahora en el Vag no hay ningún error de motor sobre las chapaletas pero sigue saliendo este: 1 Fault Found: 4984 - Glowplug for Cylinder 1 (Q10) P161A 00 [039] - Open Circuit Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 177803 km Date: 2017.11.11 Time: 10:42:40 Alguna idea de que es? Gracias por vuestra ayuda. saludos! Responder Enlace al comentario Compartir en otros sitios web More sharing options...
killers10 Publicado 2 de Diciembre del 2017 Denunciar Compartir Publicado 2 de Diciembre del 2017 En 11/11/2017 a las 15:21, A3 tdi 2.0 dijo: Buenas!! Bueno, 1 problema solucionado. Los errores referentes a las chapaletas de admisión creo que ya los he solucionado. Para eso he seguido el tutorial publicado por Jordituner en este post: Diré que para mi A5 (con código de motor CAPA) no ha sido nada sencillo sacar las bancadas ya que el espacio que hay es muy justo y además los tubos del refrigerante pasan por encima de ambas bancadas y molestan un poco, pero con paciencia todo se puede. Ahora en el Vag no hay ningún error de motor sobre las chapaletas pero sigue saliendo este: 1 Fault Found: 4984 - Glowplug for Cylinder 1 (Q10) P161A 00 [039] - Open Circuit Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 177803 km Date: 2017.11.11 Time: 10:42:40 Alguna idea de que es? Gracias por vuestra ayuda. saludos! Buenas noches, has conseguido subsanar el problema? A mi también se me ha encendido el testigo de avería de motor, junto al mensaje en el fis de start stop no disponible:error de sistema. El mio 2.0 tfsi 211 cv Responder Enlace al comentario Compartir en otros sitios web More sharing options...
josylup Publicado 3 de Diciembre del 2017 Denunciar Compartir Publicado 3 de Diciembre del 2017 En 11/11/2017 a las 16:21, A3 tdi 2.0 dijo: tienes el calentador del cilindro 1 estropeado. Tienes que sustituirlo. Un saludo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
A3 tdi 2.0 Publicado 3 de Enero del 2018 Autor Denunciar Compartir Publicado 3 de Enero del 2018 En 3/12/2017 a las 0:55, killers10 dijo: Buenas noches, has conseguido subsanar el problema? A mi también se me ha encendido el testigo de avería de motor, junto al mensaje en el fis de start stop no disponible:error de sistema. El mio 2.0 tfsi 211 cv Hola!! Disculpa no haber contestado antes, he estado bastante liado.... Si, se ha solucionado el problema, solo me queda cambiar uno de los calentadores... Un saludo, Responder Enlace al comentario Compartir en otros sitios web More sharing options...
