Srmandril Publicado 30 de Noviembre del 2017 Denunciar Publicado 30 de Noviembre del 2017 Buenos días, hoy le he pasado el vagcom a mi coche para hacerle un autoscan, y me han saltado los siguientes errores: Address 01: Engine (MSTR-CDNC) Labels: 06H-907-115-CAB.clb Part No SW: 8K2 907 115 P HW: 8K2 907 115 D Component: 2.0l R4/4V TF H14 0002 Revision: E1H14--- Coding: 0104000C18070160 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM02TFS8K2907115P A01004 ROD: N/A VCID: 3C70EFB2B7F0E7A1F5-8068 No ASAM data for: "EV_ECM02TFS8K2907115P" (AU48) No fault code found. Readiness: 0000 0000 _____________________________________________________________________________________________________ Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 C HW: 8K0 907 063 C Component: BCM1 1.0 H22 0253 Revision: 04022001 Serial number: 00000000111609 Coding: 26005091403400010001000000001D0D4F1C030800010001000000 Shop #: WSC 03743 444 00001 VCID: 2F6AC8FE7E860C3940-807A Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 090908 H06 0070 Serial number: SWF08090096103 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 941 531 F HW: 8K0 941 531 F Component: E1 - LDS H07 0070 Serial number: 00000000003108080996 1 Fault Found: 03123 - Terminal 30 - 2 011 - Open Circuit - Intermittent ______________________________________________________________________________ Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 A HW: 8K0 907 064 A Component: BCM2 1.1 H80 0141 Revision: 00002001 Serial number: 0114305787 Coding: 01000620003900C0013001 Shop #: WSC 06325 000 00000 VCID: 2E54D5FA798C05314B-807A 1 Fault Found: 01565 - Luggage Compartment Light (W3) 009 - Open or Short to Ground - Intermittent ________________________________________________________________________________ Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 E HW: 8K0 907 801 E Component: EPB Audi B8 H05 0060 Revision: 00000003 Serial number: 00000000214257 Shop #: WSC 00000 000 00000 VCID: 316ECE8668B21AC956-8064 1 Fault Found: 03182 - Clutch Position Sensor (G476) 007 - Short to Ground - Intermittent ________________________________________________________________________________ Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 C HW: 8T1 035 186 C Component: Concert3 H02 0310 Revision: 00000004 Serial number: AUZ5Z6H1118903 Coding: 05000482040185008159070003 Shop #: WSC 03743 444 00001 VCID: 377AF09E86D6C4F918-8062 Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A Component: Display 1 Fault Found: 03138 - Input AUX IN 011 - Open Circuit No se si algunos de ellos se deben al cambio de las luces de interior de serie a tipo led, ya que se me fundió un fusible que tuve que cambiar... ¿Sabéis a que se deben y como poder arreglarlo antes de tener que pasar por el taller? Muchas gracias!! Responder
Srmandril Publicado 2 de Diciembre del 2017 Autor Denunciar Publicado 2 de Diciembre del 2017 ¿a nadie se le ocurre como poder arreglarlo? Responder
A4b8 Publicado 2 de Diciembre del 2017 Denunciar Publicado 2 de Diciembre del 2017 Hola. Yo no entiendo mucho de estos temas, pero puedes borrar los fallos y hacerle de nuevo un scaneo, si solo ha sido por el problemas de las bombillas, es posible que ya no salgan y los que te salgan si no se borran todos, pues si buscar más información para saber como solucionarlos y que importancia pueden tener. Suerte. Saludos... Responder
Srmandril Publicado 2 de Diciembre del 2017 Autor Denunciar Publicado 2 de Diciembre del 2017 gracias, probare eso de momento, si a alguien se le ocurre algo mas bienvenido sea! Responder
