Hola buenas, llevo un par de días que se enciende el chivato del ABS a veces... Pues bueno,  aprovechando que tenia que quitarle el tema de service INSP le he pasado el vag-com. Resulta que el chivato salta por alguna conexión que no llega, es decir, un mal contacto de algún cablecillo supongo...
Os dejo por aquí el log.
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 907 401 P 2
Component: 2.5l/4VT EDC 0000SG D60
Coding: 01002
Shop #: WSC 02325
4 Faults Found:
00575 - Intake Manifold Pressure
08-10 - Control Limit Surpassed - Intermittent
00522 - Engine Coolant Temperature Sensor (G62)
30-10 - Open or Short to B+ - Intermittent
00519 - Intake Manifold Pressure Sensor (G71)
31-00 - Open or Short to Ground
18259 - Powertrain Data Bus: Missing Message from ABS Controller
P1851 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D00
Coding: 00012
Shop #: WSC 02325
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 P
Component: A6-Klimavollautomat D62
Coding: 00063
Shop #: WSC 02325
4 Faults Found:
00779 - Outside Air Temp Sensor (G17)
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Skipping Address 15-Airbags
VAG-COM
Self-Diagnosis Log
Thursday, 21 December 2017, 15:29:13
Page 2
VIN Number: License Plate:
Address 17 -------------------------------------------------------
Controller: 4B0 919 881 X
Component: C5-KOMBIINSTR. VDO D19
Coding: 05160
Shop #: WSC 23904
IMMO-IDENTNR: AUZ7Z0H2814329
No fault code found.
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 E
Component: Zentralverrieg.,DWA D32
Coding: 04683
Shop #: WSC 02325
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02325
End -------------------------------------------------------
Pues bien, alguien ha tenido este fallo? He visto este post en otro foro, parece que puede ser la solución... Enlace
Opiniones por favor, puede ser eso o no? Alguien lo ha hecho antes, el brico digo.
Muchas gracias ASI!
PD: Si veis algo mas en el log que sea alarmante decirme jeje
