Alguien ha activado el activ lane asist ?
Tengo entendido que si se puede, haría falta la cámara en el parabrisas, és mí caso
Los del A4 lo han echo y he visto algo en el foro de ross tech para nuestro modelo, pero no logro entenderlo
AMBSC said:10-08-2016 11:38 PM
Hello!
I coded lane assist in my A6 post-facelift and I would like to give my 2 cents of experience to this tweak - it might help people who got the facelifted A6/A7:
1 - I followed all Mrclopec steps, except the green menu one;
2 - The tweak to turn the "green/hidden menu" doesn't work in facelifted A6/A7 - new MMI gen, if I'm not wrong. Anyway, that doesn't matter at all, because, even if you get to the hidden menu by other means, it's quite useless for this subject. The hidden menu doesn't play the same relevant role he did before. You won't be able to enable lane assist menu through it.
3 - That said, I´ve done this:
- Enter module 5F-Information Elect, 10 - adaptation
- ENG122227-ENG117506-Car_Functions_Adaptations.......Lane_Departure_War ning : activate
- ENG122227-ENG117508-Car_Functions_Adaptations.......Lane_Departure_War ning_over_threshold_high : activate
- ENG122229-ENG117740-Car_Function_List_BAP.......LDW_HCA_0x19 : activate
- ENG122229-ENG117741-Car_Function_List_BAP.......LDW_HCA_0x19_msg_bus : Terminal 15
Done that, the lane assist menu in the MMI is supposed to be there.
4 - For the ones like me who got module 82-Heads Up Display:
- 07-Coding, "Long Coding Helper"
- Byte 0, Bit 2 - check it
5 - 10-Park/Steer Assist module is not a must have for lane assist. Can´t tell exactly how the park assist side sensors help the lane assist function, but I remember I coded lane assist in my former GTI MK7, it had this module and, as far as I remember, the module was not coded. My A6 doesn´t have it, and lane assist is working.
A ver se alguien puede arrojar algo de luz
Salu2
  • Respuestas 49
La clave está aqui, pero no logro entenderlo
  • 4 meses más tarde...
En 4/2/2018 a las 15:22, picatchu dijo:
Gracias
Investigare un poco más
¿Sigues con el tema? la verdad es que me interesaría saber como instalarlo es uno de los sistemas de seguridad que me faltaría y creo que solo me haría falta instalar las manetas con el botón
saludos
hace 12 minutos, jota_allroad dijo:
saludos
Hola
Lo tengo apartado, lo siento
Salu2
