fresco Publicado 9 de Febrero del 2018 Denunciar Publicado 9 de Febrero del 2018 hola buenas tardes hoy le he pesado el vag con para hacerle una auto scan. y me a salido un par de fallos a ver si me podéis ayudar VCDS Version: Release 12.12.3 (x64) Data version: 20140822 Friday,09,February,2018,13:54:52:30570 Chassis Type: 8D (8D - Audi A4/S4/RS4 B5 (1995 > 2001)) Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 VIN: WAUZZZ8DZ1A127904 Mileage: 256730km/159524miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06B-906-018-AWT.lbl Part No: 4B0 906 018 CG Component: 1.8L R4/5VT 0002 Coding: 11201 Shop #: WSC 63251 VCID: 68D9C8E20804B15E33D-5000 WAUZZZ8DZ1A095748 AUZ7Z0Y1628334 2 Faults Found: 17536 - Fuel Trim; Bank 1 (Mult) P1128 - 35-00 - System too Lean 17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat) P1296 - 35-00 - Readiness: 0010 1001 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl Part No: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D10 Shop #: BB 24334 VCID: 1C31A4328CDCADFE675-5072 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl Part No: 8D0 820 043 M Component: A4 KLIMAAUTOMAT D58 Coding: 00040 Shop #: WSC 63251 VCID: 2A5D72EAD688434EE59-2566 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI8.lbl Part No: 8D0 959 655 J Component: Airbag Front+Seite 1001 Coding: 01106 Shop #: WSC 63251 VCID: 3D7749B63706C4F6B0B-5072 3 Faults Found: 65535 - Internal Control Module Memory Error 00-10 - - - Intermittent 01218 - Side Airbag Igniter; Passenger Side (N200) 32-10 - Resistance Too High - Intermittent 00588 - Airbag Igniter; Driver Side (N95) 24-10 - Rear Pressure Reducing Time too Long - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-920-xxx-17.lbl Part No: 8D0 920 932 Component: B5-KOMBIINSTR. VDO D12 Coding: 00162 Shop #: WSC 02244 VCID: E5C741D67F162C3688B-5000 WAUZZZ8DZ1A127904 AUZ7Z0Y1741546 2 Faults Found: 01176 - Key 65-10 - Unauthorized - Intermittent 01177 - Engine Control Unit 49-00 - No Communications ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8D0 862 257 Component: ZV-Pumpe, DWA, Funk D16 Coding: 15179 Shop #: WSC 63251 VCID: EADD32EA9608034EA59-4E42 2 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00955 - Key 1 09-00 - Adaptation Limit Surpassed ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00102 Shop #: WSC 63251 VCID: E0C950C26034491E7BD-4A9C No fault code found. End --------------------------------------------------------------------- . Responder
duke80 Publicado 10 de Febrero del 2018 Denunciar Publicado 10 de Febrero del 2018 Borra todos los fallos, rueda un par de días y vuelve a sacar el log. Así sabemos cuales han sido fallos esporádicos y cuales son permanentes. Un saludo Responder
fresco Publicado 10 de Febrero del 2018 Autor Denunciar Publicado 10 de Febrero del 2018 Son los mismo .. hoy han vuelto salier, Responder
