Buenas,estaba indagando por los foroa y el otro dia pregunte por el hold assist,e visto que hay una modificacion para el arranque en pendiente,para hacerlo mas sensible o que tenga mas retardo.No se si es compatible con nuestros modelos.Yo lo dejo ahi,a la esoara de vuestros comentarios.Esta en ingles.
Sensitivity hill start assistant
We can modify the way the wizard acts hill start adapting to our needs or habits.
1 - Module 03 - Electronic brake. Code (40168/20103)
2 - Adaptation
3 - Select - Start Assist slope
4 - Activate one of the three options:
- Normal (default)
- Advance
- Time delay
Tilt hill start assistant
With this modification we can change when we want to be activated depending on the steepness of the slope.
2 - Adaptation
3 - Select - Start Assist slope, slope limit
4 - Change the value you want.
A higher value more inclination required for activation
Default 3%
