Staik Publicado 2 de Junio del 2018 Denunciar Publicado 2 de Junio del 2018 Buenas tardes, tengo los siguientes errores al realizar un AUTO SCAN de un Audi A4 B8 2009 Adjunto lista. Saturday,02,June,2018,16:17:28:39744 Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 JM HW: 03L 906 022 B Component: R4 2.0l TDI H01 9978 Revision: 11H01--- Coding: 0104002C18072120 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM2T0DI03L906022JM A01011 ROD: N/A VCID: 79FE36A6F8421289AE-802C No ASAM data for: "EV_ECM2T0DI03L906022JM" (AU48) 8 Faults Found: 5293 - ROD - Unknown Error Code - 00 [040] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 31 Mileage: 193501 km Date: 2018.05.30 Time: 14:05:39 5294 - ROD - Unknown Error Code - 00 [032] Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 4 Mileage: 193289 km Date: 2018.05.25 Time: 11:13:17 5295 - ROD - Unknown Error Code - 00 [032] Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 193305 km Date: 2018.05.26 Time: 14:44:19 5296 - ROD - Unknown Error Code - 00 [172] MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 254 Mileage: 189021 km Date: 2018.03.30 Time: 23:50:37 5297 - ROD - Unknown Error Code - 00 [032] Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 8 Mileage: 193592 km Date: 2018.06.02 Time: 12:02:17 5286 - ROD - Unknown Error Code - 00 [096] Intermittent - Not Confirmed - Tested Since Memory Clear 9123 - ROD - Unknown Error Code - 00 [096] Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Mileage: 193617 km Date: 2018.06.02 Time: 13:32:04 9124 - ROD - Unknown Error Code - 00 [232] MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 30 Mileage: 193433 km Date: 2018.05.29 Time: 11:18:29 Readiness: 1 3 0 0 0 --------------------------------------------- y aparte me aparece esto en VAGCOM cuando finaliza el auto Scan, que falta estos archivos. Gracias. Responder
Carlisu84 Publicado 3 de Junio del 2018 Denunciar Publicado 3 de Junio del 2018 Parecen fallos esporádicos, has borrado y vuelto a pasar el vagcom? Responder
