Xingular Publicado 13 de Mayo del 2005 Denunciar Publicado 13 de Mayo del 2005 (editado) The new Audi A6 Avant has just entered the market and H&R can already offer several suspension components for the stationwagon. Wether the car should be lowered by high tension sport springs or a height adjustable coil over or you want an increasing stability with H&R stabilizers or wether a better the handling shall be improved by wheel spacers - H&R offers a lot of modifications for the new car from Ingolstadt. All H&R suspension components are developed and produced by ISO 9001 and are TÜV approved. Sport springs: Partnumber: Type: Lowering: 29200-3 | 4F, up to 1215kg FA-weight | 40mm 29200-4 | 4F, from 1216kg FA-weight | 40mm Stabilizer: Partnumber: Type: Diameter: 33201-1 | 4F | FA: 32mm / RA: 25mm 2-way adjustable Height adjustable coil over: Partnumber: Type: Lowering: 29201-2 | 4F | FA: 30-70mm RA: 30-60mm TRAK+ wheel spacers: Partnumber: System: Widening per axle: 1055571 | DR | 10mm 1655571 | DR | 16mm 2055571 | DR | 20mm 2455571 | DR | 24mm 3055571 | DR | 30mm 4055571 | DR | 40mm 40555712 | DRA | 40mm 5055571 | DRA | 50mm 6055571 | DRA | 60mm Y VAYA LLANTAS!!! :clap1: B) Editado 13 de Mayo del 2005 por Xingular Responder
sildenafilo Publicado 14 de Mayo del 2005 Denunciar Publicado 14 de Mayo del 2005 no entiendo ni papa, lo mío no es el ingles. Respecto a a las llantas, me parecen las BBS CK, que por cierto solo las hay en 19 ó 20 pulgadas. Lástima que no haya en 18, si no serían seguramente las elegidas para cambiarselas al mío. Responder
