Gorka144 Publicado 20 de Febrero del 2020 Denunciar Publicado 20 de Febrero del 2020 Buenas tardes, Soy nuevo en este mundillo... Hoy un amigo me ha dejado su cable y al pasarlo me aparece el siguiente informe: Address 01: Engine Labels: 038-906-019-AVF.lbl Part No: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 5934 Coding: 00002 Shop #: WSC 63351 VCID: 6ADB2423168A324E2A7-4A3A WAUZZZ8E24A268949 AUZ6Z0D0089474 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 4529 Coding: 04255 Shop #: WSC 06435 VCID: E5C1D71F7F949D36875-5072 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AA Component: A4 Klimaautomat 1324 Coding: 00000 Shop #: WSC 63351 VCID: 60CF460BE0B6781EF43-5072 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 00001 Shop #: WSC 63351 VCID: 3561C75F0FB4ADB6775-4A3A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 63351 000 00000 VCID: 3E73D8736A826EEEA6F-5072 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 00011 Shop #: WSC 63351 VCID: 4385A98751600306C91-49D8 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 900 M Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 00101 Shop #: WSC 00482 VCID: 2E53E833EAE29E6E36F-5000 WAUZZZ8E24A268949 AUZ6Z0D0089474 No fault code found. ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0704 Coding: 00001 Shop #: WSC 00000 VCID: EBD5A1279970AB46D11-5000 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BC Component: Komfortgerát T3B 1412 Coding: 06730 Shop #: WSC 63351 VCID: 73E539474140F386991-49D8 Subsystem 1 - Part No: 8E1959801B Component: Tõrsteuer.FS BRM 0103 Subsystem 2 - Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0103 Subsystem 3 - Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0204 Subsystem 4 - Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0204 1 Fault Found: 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - End --------------------------------------------------------------------- Entiendo que tengo un fallo en "Alarm triggered by door…" ¿no? ¿Sabeis a que puede ser? He leído por el foro que se debe a la alarma, que puede ser por que ha saltado alguna vez. Por otra parte, este apartado Address 46: Central Conv. Aparecia en rojo... Repito que estoy muy perdido en esto. ¿Me podeis ayudar? Gracias. Un saludo. Responder
Carlisu84 Publicado 21 de Febrero del 2020 Denunciar Publicado 21 de Febrero del 2020 Bienvenido a ASI!! Si quieres haznos una presentacion de ese b6 para irnos conociendo y asi poder seguir un poco de como lo vas dejando Como se suele decir sin foto no hay coche xD hace 19 horas, Gorka144 dijo: Entiendo que tengo un fallo en "Alarm triggered by door…" ¿no? ¿Sabeis a que puede ser? He leído por el foro que se debe a la alarma, que puede ser por que ha saltado alguna vez Efectivamente ese fallo es porque la alarma salto una vez, seguro que si lo borras ya no aparece. hace 19 horas, Gorka144 dijo: Por otra parte, este apartado Address 46: Central Conv. Aparecia en rojo... cuando encuentra fallos en algun modulo lo destaca en rojo. Vamos que tienes el coche muy sano segun el vag Un saludo! Responder
