dani_zxz Publicado 6 de Abril del 2020 Denunciar Publicado 6 de Abril del 2020 Hola buenas, he conseguido quitar el modo trasporte pero me sigue saliendo el error en el freno de estacionamiento. He apagado y encendido el coche y e sigue apareciendo el simbolo del freno de mano con un rayo a cada lado. He pasado el Auto-Scan con el VCDS 17.1.3 y me sale el siguiente error: Monday,06,April,2020,19:02:58:39744 VCDS Version: Release 17.1.3 Running on Windows 10 x64 www.Ross-Tech.com Address 53: Parking Brake Labels: 8K0-907-801-V2.clb Control Module Part Number: 8K0 907 801 N HW: 8K0 907 801 J Component and/or Version: EPB-4 H03 0005 Software Coding: Work Shop Code: ASAM Dataset: EV_ParkiBrake 001028 (AU48) ROD: EV_ParkiBrake_VW51.rod VCID: 3A7CE9AABDC4D991E7-806E 3 Faults Found: 262656 - No Basic Setting B2010 00 [137] - - MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 79 Mileage: 92592 km Date: 2020.04.05 Time: 18:47:40 Voltage terminal 30: 12.2 V Internal Fault ID: 67 Vehicle speed: 0 km/h Network management state: normal Function light in parking brake button: On Red operating lamp: On Red warning lamp: OFF Green operating lamp: OFF Yellow warning lamp: OFF Terminal 15 status: On RWU: not active DSD: not active HTR: not active ECD: not active ACC requested apply: not active Auto Adjust: not active General Inspection Function: not active Internal Parking Brake state: static Status of parking brake button: Not operated Status ParkingBrake left: Set Status ParkingBrake right: Set 329728 - Function Restricted due to Missing Message(s) U1111 00 [137] - - MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 79 Mileage: 92592 km Date: 2020.04.05 Time: 18:58:30 Voltage terminal 30: 12.5 V Internal Fault ID: 94 Vehicle speed: 0 km/h Network management state: normal Function light in parking brake button: On Red operating lamp: On Red warning lamp: OFF Green operating lamp: OFF Yellow warning lamp: On Terminal 15 status: On RWU: not active DSD: not active HTR: not active ECD: not active ACC requested apply: not active Auto Adjust: not active General Inspection Function: not active Internal Parking Brake state: static Status of parking brake button: Not operated Status ParkingBrake left: Set Status ParkingBrake right: Set 329984 - Function Restricted due to Missing Message(s) U1111 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 79 Mileage: 92592 km Date: 2020.04.05 Time: 18:58:30 Voltage terminal 30: 12.5 V Internal Fault ID: 95 Vehicle speed: 0 km/h Network management state: normal Function light in parking brake button: On Red operating lamp: On Red warning lamp: OFF Green operating lamp: OFF Yellow warning lamp: On Terminal 15 status: On RWU: not active DSD: not active HTR: not active ECD: not active ACC requested apply: not active Auto Adjust: not active General Inspection Function: not active Internal Parking Brake state: static Status of parking brake button: Not operated Status ParkingBrake left: Set Status ParkingBrake right: Set He dado a borrar los DTC y nada, se me borran dos de los errores pero permanece el siguiente: No ASAM data for: "EV_parkiBrkae" (AU48) 1 Fault Found: 262656 - ROD - Unknown Error Code - 00 [137] MIL ON - Confirmed - Tested since memory clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 79 Mileage: 92592 km Date: 2020.04.05 Time: 18:47:40 Mi coche es un AUDI Q5 2.0TDI 150CV 2016. Solicito ayuda para borrar el error en el ordenador de abordo. Gracias y espero su respuesta. Un saludo. Responder
