golfinho Publicado 24 de Mayo del 2005 Denunciar Publicado 24 de Mayo del 2005 Os pongo el texto en inglés, si alguien tiene dificultades lo intento traducir: Tools/accessories needed: Flexible surface primer ($6) Spray paint (paint code LY7W for light metallic silver) ($20) Clear coat ($5) *I picked up the first three from levine auto supply in Connecticut via their website!* kitchen sponge with scrubby side isopropyl rubbing alcohol very fine-grit sandpaper (i used 2000 grit wet/dry, found at pep boys) masking tape (for manual transmission plate) vaseline or electrical tape (for tip plate) Remove the plate from the car - it's clipped in, so just pull straight up from "front" of the plate (near the e-brake). If you have a manual transmission, remove the shift knob by unscrewing, then remove the plate. After this, remove the shift boot and its surrounding piece by pressing its clips towards the center of the shift boot (from the bottom of the plate) and it should come right off. Thanks Yippers for the heads-up ;-) Clean the thing off. Mine had some pretty nasty sh!t on it. Remove the paint. This is the hardest and most manual process. You have to remove that rubberized paint... I used a few paper towels and some rubbing alcohol to strip it down to the plastic, then I went to town with the scrubby side of the sponge. The scrubby side won't harm the plastic underneath, and even if it does leave minor surface scratches, the wet-dry sandpaper can easily take care of that. Scrub ALL of it off, and if you are not sure if it is gone from certain parts, it's time to wet-dry sand. I used the rubbing alcohol as a minor lubricant, but don't use too much otherwise the scrubber isn't abrasive enough to remove the paint. Wet-dry sand the entire area. This ensures that the rubberized paint is gone. I didn't completely remove the rubberized paint, and god did my first spray of primer look AWFUL. So make sure you get it all off!! Will save lots of time later on. Dry the area, and then mask off the chrome trim ring (manual) or the rubber trim ring (tip). I used vaseline on the rubber trim ring.. hopefully the results will be satisfactory ;-) Once you're satisfied with your masking job, it's time to prime. I recommend spraying somewhere with a LOT of ventilation. But do NOT spray anywhere NEAR your car, or any other item of value that has a finish to it. The primer/paint/clear coat sucks its way onto that stuff. I put two to three light, even coats of primer on, waiting 20 minutes between coats. Paint. I used four to five coats of base coat, waiting about 20-30 minutes in between sprays. Wet-sand any overspray and allow to dry before spraying again. Clear coat. I used three to four coats of clear coat, with 20-30 min utes between coats. Nice, even light coats are better than one heavy coat. Let it dry, and that's it. Responder
COHBA Publicado 24 de Mayo del 2005 Denunciar Publicado 24 de Mayo del 2005 Chulo, siempre y cuando dure, cosa que dudo. Responder
pikolo Publicado 24 de Mayo del 2005 Denunciar Publicado 24 de Mayo del 2005 La verdad es que no queda mal, pero prefiero la madera o la fibra. :drool: Responder
fermoa4 Publicado 24 de Mayo del 2005 Denunciar Publicado 24 de Mayo del 2005 asi lo tengo yo en mi a4 y durar si dura os lo aseguro y queda muy bien :drool: Responder
golfinho Publicado 24 de Mayo del 2005 Autor Denunciar Publicado 24 de Mayo del 2005 Para los que les interesa el link original: Enlace Sobre la durabilidad, pues lo desconozco, pero con que dure un poco más que la imprimación que viene de fábrica (joer es que yo tengo muxas piezas peladas chicos......) Saludos Responder
myploira Publicado 24 de Mayo del 2005 Denunciar Publicado 24 de Mayo del 2005 si queda como en las fotos parece un acabado original y de chapuza nada de nada salu2 Responder
txispis Publicado 24 de Mayo del 2005 Denunciar Publicado 24 de Mayo del 2005 Siempre al final te queda la opción cara si no te convence golfi... o si sale mal. Ademas tu ya sabes que siempre nos quedará ebay :drool: saludos Responder
Xingular Publicado 24 de Mayo del 2005 Denunciar Publicado 24 de Mayo del 2005 queda muy bien! Responder
fermoa4 Publicado 25 de Mayo del 2005 Denunciar Publicado 25 de Mayo del 2005 jod**,estaba pensando,como se parece a la mia del a4 b5,c*** es que esa foto es de un a4 y no de un a6 :blink: :blink: :blink: :blink: Responder
golfinho Publicado 25 de Mayo del 2005 Autor Denunciar Publicado 25 de Mayo del 2005 Jajajaj, si, perdón, aunque está en el foro de A6 la foto se corresponde con un A4¡¡¡¡ Responder
