VAG-COM Version: Release 303.1
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 H
Component: 1.8L R4/5VT G 0004
Coding: 10710
Shop #: WSC 01236
TRUZZZ8N421011247 AUZ5Z0A8170019
3 Faults Found:
16519 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit Malfunction
P0135 - 35-10 - - - Intermittent
17925 - Main Relay (J271): Electrical Malfunction
P1517 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
2 Faults Found:
00668 - Supply Voltage Terminal 30
16-10 - Signal Outside Specifications - Intermittent
00812 - Brake Pressure Release Solenoid (F84)
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00040
Shop #: WSC 01236
0 Faults Found:
Address 15 -------------------------------------------------------
Controller: 8N0 959 655 A
Component: Airbag Front+Seite 5000
Coding: 01102
Shop #: WSC 01236
1 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
Address 17 -------------------------------------------------------
Controller: 8N1 920 930 M
Component: KOMBI+WEGFAHRS. M73 D11
Coding: 05044
Shop #: WSC 27162
XXXXXXXXXXXXXXXXX
2 Faults Found:
53-10 - Supply Voltage Too Low - Intermittent
01304 - Radio
49-10 - No Communications - Intermittent
Address 22 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Address 35 -------------------------------------------------------
Controller: 8N8 962 267
Component: Zentralverrieg. D05
Coding: 06720
Shop #: WSC 01236
0 Faults Found:
Address 55 -------------------------------------------------------
Controller:
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 G
Component: concert II GRO 0006
Coding: 00000
Shop #: WSC 01236
1 Faults Found:
;):ywn:
el error de la radio s por q esta en modo safe------
cable usb (al fin funciana) jjj
Tiene toda la pinta de ser por que te has quedado sin batería o la has soltado para algo, borralos y mueve el coche y pasa otra vez el Vag-Com, yo creo que no se repetirán.
Un saludo y suerte
antes de realizar el test por primera vez, cambie la bateria, el caso es que ahora no se si el vag-con graba los errores como en un historial, para despues borrarlos cuando se cambian las piezas, por que pase del nuevo el test le di a borrar los errores y ya no salen, pero m queda la duda, si se borraron por q ya no los tiene o ahora ingnora cuando detecta ese error.
-antes del test tenia problema con la bateria.
-cambio la bateria y paso el test x 1 vez (aparecenlos errores q veis en el post)
repito el test varios veces con los mismo resultados ... No entiendo por q aparecen si ya tenia cambiada la bateria a no ser q memorice errores y cuando l conectas t salen :kss1::p
-paso ho de nuevo el test y borro errores.... (ahora lo paso una segunda vex y ya desaparecen) :kss1:
AHORA NO SE SI LO BORRE COMO SI FUERA UN TALLER o desaparecieron???
en fin un lio... :lol2::bsh1: help!! please..
