RafaTT Publicado 28 de Mayo del 2005 Denunciar Compartir Publicado 28 de Mayo del 2005 VAG-COM Version: Release 303.1 Chassis Type: 8N - Audi TT Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56 Address 01 ------------------------------------------------------- Controller: 8N0 906 018 H Component: 1.8L R4/5VT G 0004 Coding: 10710 Shop #: WSC 01236 TRUZZZ8N421011247 AUZ5Z0A8170019 3 Faults Found: 16519 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit Malfunction P0135 - 35-10 - - - Intermittent 17925 - Main Relay (J271): Electrical Malfunction P1517 - 35-10 - - - Intermittent 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent Readiness: 0000 0000 Address 03 ------------------------------------------------------- Controller: 8N0 907 379 E Component: ESP 20 CAN V005 Coding: 18446 Shop #: WSC 01236 2 Faults Found: 00668 - Supply Voltage Terminal 30 16-10 - Signal Outside Specifications - Intermittent 00812 - Brake Pressure Release Solenoid (F84) 35-10 - - - Intermittent Address 08 ------------------------------------------------------- Controller: 8N0 820 043 A Component: TT-KLIMAVOLLAUTOMAT D03 Coding: 00040 Shop #: WSC 01236 0 Faults Found: Address 15 ------------------------------------------------------- Controller: 8N0 959 655 A Component: Airbag Front+Seite 5000 Coding: 01102 Shop #: WSC 01236 1 Faults Found: 00532 - Supply Voltage B+ 07-10 - Signal to Low - Intermittent Address 17 ------------------------------------------------------- Controller: 8N1 920 930 M Component: KOMBI+WEGFAHRS. M73 D11 Coding: 05044 Shop #: WSC 27162 XXXXXXXXXXXXXXXXX 2 Faults Found: 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent 01304 - Radio 49-10 - No Communications - Intermittent Address 22 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Address 35 ------------------------------------------------------- Controller: 8N8 962 267 Component: Zentralverrieg. D05 Coding: 06720 Shop #: WSC 01236 0 Faults Found: Address 55 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Address 56 ------------------------------------------------------- Controller: 4B0 035 186 G Component: concert II GRO 0006 Coding: 00000 Shop #: WSC 01236 1 Faults Found: 00668 - Supply Voltage Terminal 30 07-10 - Signal to Low - Intermittent el error de la radio s por q esta en modo safe------ cable usb (al fin funciana) jjj Responder Enlace al comentario Compartir en otros sitios web More sharing options...
RafaTT Publicado 28 de Mayo del 2005 Autor Denunciar Compartir Publicado 28 de Mayo del 2005 hola de nuevo instale la version es español pero cuando le doi a mira la lista de averias sale con caracteres raros? quien sabe la solucion?? gracias d antemano Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Baquero Publicado 28 de Mayo del 2005 Denunciar Compartir Publicado 28 de Mayo del 2005 Tiene toda la pinta de ser por que te has quedado sin batería o la has soltado para algo, borralos y mueve el coche y pasa otra vez el Vag-Com, yo creo que no se repetirán. Un saludo y suerte Responder Enlace al comentario Compartir en otros sitios web More sharing options...
tarin Publicado 30 de Mayo del 2005 Denunciar Compartir Publicado 30 de Mayo del 2005 Estoy con Baquero. Le has soltado la bateria o algo? Porque si te fijas en casi todos aparece Low Power Supply (alimentacion baja) Responder Enlace al comentario Compartir en otros sitios web More sharing options...
RafaTT Publicado 30 de Mayo del 2005 Autor Denunciar Compartir Publicado 30 de Mayo del 2005 antes de realizar el test por primera vez, cambie la bateria, el caso es que ahora no se si el vag-con graba los errores como en un historial, para despues borrarlos cuando se cambian las piezas, por que pase del nuevo el test le di a borrar los errores y ya no salen, pero m queda la duda, si se borraron por q ya no los tiene o ahora ingnora cuando detecta ese error. -antes del test tenia problema con la bateria. -cambio la bateria y paso el test x 1 vez (aparecenlos errores q veis en el post) repito el test varios veces con los mismo resultados ... No entiendo por q aparecen si ya tenia cambiada la bateria a no ser q memorice errores y cuando l conectas t salen -paso ho de nuevo el test y borro errores.... (ahora lo paso una segunda vex y ya desaparecen) AHORA NO SE SI LO BORRE COMO SI FUERA UN TALLER o desaparecieron??? en fin un lio... help!! please.. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Baquero Publicado 30 de Mayo del 2005 Denunciar Compartir Publicado 30 de Mayo del 2005 El Vag-Com borra los errores del registro del coche como si fuera la maquina original del taller, estate tranquilo, parece que esta todo correcto. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
