Xingular Publicado 1 de Junio del 2005 Denunciar Compartir Publicado 1 de Junio del 2005 ECS Tuning's Stage I brake kit for B5 A4s is an inexpensive way to upgrade the braking performance of your A4. This kit uses the stock calipers and brake pads on a larger rotor, which improves pedal feel and braking performance. This kit includes 13.1" (332mm x 26mm) zinc or cadmium coated rotor rings available slotted or crossdrilled-slotted, anodized aluminum hats on both rotors, hardened and coated hardware, a steel carrier bracket and complete instructions on our Web site. This kit fits under 17" or larger wheels and does not require spacers under most circumstances. It uses the OEM caliper and carrier and OEM style brake pads. Installation is easy and will result in better pedal feel, reduced rotor temperatures and shorter stopping distances. Low-cost replacement rotors are available, as well. For more information, please visit www.ECStuning.com. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
CaTFiSH Publicado 1 de Junio del 2005 Denunciar Compartir Publicado 1 de Junio del 2005 (editado) se los vas a poner? toca unas llantas de 17 entonces Supongo que con tu motorización no hay problema, en los motores más bajos si hay que cambiar bastantes cosas más. Por aqui anda un post sobre el tema de hace unas 2 semanas =) edito: unas rs4 de esas q te gustan seguro le kedan bien :clap1: Editado 1 de Junio del 2005 por CaTFiSH Responder Enlace al comentario Compartir en otros sitios web More sharing options...
