isidro Publicado 10 de Marzo del 2022 Denunciar Publicado 10 de Marzo del 2022 pPues eso que no me funciona el mando de las puertas no abren , no funciona el techo y por hora no he visto mas , he pasado el vag y me sale esto , que puede ser , fusibles los he mirado todos y nada . Gracias VCDS Version: Release 12.12.3 (x64) Data version: 20140822 Thursday,10,March,2022,19:39:33:30570 Chassis Type: 8P (1K0) Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 77 7D VIN: WAUZZZ8P57A051160 Mileage: 216940km/134800miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Cannot be reached 1100 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 7D-Aux. Heat -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKD.lbl Part No SW: 03G 906 021 RA HW: 03G 906 021 AN Component: R4 2,0L EDC G000AG 1214 Revision: --H05--- Serial number: AUX7Z0F7FN906K Coding: 0000078 Shop #: WSC 24795 002 1048576 VCID: 6FEBA3FE7EEA6666727-803A No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.lbl Part No SW: 02E 300 042 S HW: 02E 927 770 AE Component: GSG DSG 070 1102 Revision: 04507000 Serial number: 00000607050089 Coding: 0000020 Shop #: WSC 06314 000 00000 VCID: 23439FCEE2A29206A6F-8076 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Revision: 00H11001 Coding: 0023170 Shop #: WSC 06314 000 00000 VCID: 73E3AF8E12C2428696F-8026 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 M HW: 8P0 820 043 M Component: KlimavollautomatH18 0300 Revision: 365615 Serial number: 8P0820043M Shop #: WSC 06314 000 00000 VCID: 3665569A413017AE711-8063 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 200 Mileage: 216916 km Time Indication: 0 Date: 2022.03.10 Time: 14:08:13 Freeze Frame: ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl Part No SW: 8P0 907 279 K HW: 8P0 907 279 K Component: Bordnetz-SG H54 2501 Revision: 00H54000 Serial number: 00000008036039 Coding: A1884F019214100000160000160000000018FE175C01000E000000000000 Shop #: WSC 06314 123 08192 VCID: 458721560CD68C36E8B-8010 Subsystem 1 - Part No: 8P1 955 119 E Labels: 1KX-955-119.CLB Component: Wischer AU350 H01 0130 Coding: 00062736 Shop #: WSC 06314 2 Faults Found: 00834 - Signal for Activation of Heated Rear Window 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 243 Mileage: 216946 km Time Indication: 0 Date: 2022.03.10 Time: 19:14:00 Freeze Frame: OFF Voltage: 12.05 V OFF ON OFF OFF OFF 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 5 Reset counter: 203 Mileage: 216916 km Time Indication: 0 Date: 2022.03.10 Time: 08:58:00 Freeze Frame: OFF Voltage: 12.60 V OFF ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8P0-959-655-94.lbl Part No SW: 8P0 959 655 C HW: 8P0 959 655 C Component: Airbag 9.41 H12 3760 Revision: 91H12376 Serial number: 003620G1J79K Coding: 0070612 Shop #: WSC 06314 000 00000 VCID: 428D3A4A1DF8BB0ECD9-8017 Subsystem 1 - Serial number: 6332DRB403918A14J Subsystem 2 - Serial number: 6342DRB403924A1BO Subsystem 3 - Serial number: 63528RB4015C2E66Q Subsystem 4 - Serial number: 63628RB40178446BM Subsystem 5 - Serial number: 63729RB4017D985A- Subsystem 6 - Serial number: 63829RB4017D95A6Z No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8P0-953-549-F.lbl Part No SW: 8P0 953 549 F HW: 8P0 953 549 F Component: J0527 H36 0070 Coding: 0014142 Shop #: WSC 24795 002 1048576 VCID: 418F354618FEA016D43-8014 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 931 HW: 8P0 920 931 Component: KOMBIINSTR. VDO H18 0560 Revision: D0H18002 Serial number: 2247F002026589 Coding: 0000118 Shop #: WSC 00272 1023 1686429 VCID: F0E92082E3D4F99EEBD-80A5 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb Part No SW: 1K0 907 530 J HW: 1K0 907 951 Component: J533__Gateway H12 0160 Revision: H12 Serial number: 32001067228A31 Coding: 3F3F0BC207002102 Shop #: WSC 06314 000 00000 VCID: 2E557EFAB9602F6E391-807B 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 200 Mileage: 216916 km Time Indication: 0 Date: 2022.03.10 Time: 08:58:20 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8P0 920 931 HW: 8P0 920 931 Component: KOMBIINSTR. VDO H18 0560 Revision: D0H18002 Serial number: AUX7Z0F7FN906K Shop #: WSC 00000 000 00000 VCID: F0E92082E3D4F99EEBD-80A5 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl Part No: 8P0 959 801 H Component: Tuer-SG 020 0090 Coding: 0000144 Shop #: WSC 06314 000 00000 VCID: 4089304213F4A91EDBD-8015 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 L Component: EPS_ZFLS Kl.079 H07 1806 Shop #: WSC 02069 000 90108 VCID: 34616C92574C05BE4F5-8061 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 8Px-035-382.lbl Part No SW: 8P4 035 382 HW: 8P4 035 382 Component: AB2 SUBWOOFERBOXH04 0180 Revision: 00003 Serial number: 30674696441464 Shop #: WSC 00000 000 00000 VCID: F1EF2586E8DEF096E43-80A4 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl Part No: 8P0 959 802 H Component: Tuer-SG 020 0090 Coding: 0000144 Shop #: WSC 06314 000 00000 VCID: 418F354618FEA016D43-8014 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 56: Radio Labels: 8P0-035-1xx-56.lbl Part No SW: 8P0 035 186 C HW: 8P0 035 186 C Component: concert II EU H51 0100 Revision: 01S Serial number: AUZ2Z3D1090133 Coding: 0001001 Shop #: WSC 06435 000 00000 VCID: 326D6A8AAD580B8E5D9-8067 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 8P4-959-801.lbl Part No: 8P4 959 801 D Component: Tuer-SG 020 0070 Coding: 0000144 Shop #: WSC 06314 000 00000 VCID: 4089304213F4A91EDBD-8015 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 8P4-959-802.lbl Part No: 8P4 959 802 D Component: Tuer-SG 020 0070 Coding: 0000144 Shop #: WSC 06314 000 00000 VCID: 418F354618FEA016D43-8014 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8P0 862 335 S HW: 8P0 862 335 S Component: FSE_256x BT H34 0550 Revision: 00000000 Serial number: 00000005076536 Coding: 0001455 Shop #: WSC 09038 572 92676 VCID: 4685265A31D0872EE11-8013 No fault code found. ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 E HW: 1K0 963 235 E Component: PTC-Element 0404 Revision: 00800000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2D5779F6B466547600B-8078 No fault code found. End --------------------------------------------------------------------- Responder
isidro Publicado 10 de Marzo del 2022 Autor Denunciar Publicado 10 de Marzo del 2022 He cambiado la centralita por la original y sigue igual con lo cual es un rele seguro , pero cual . Gracias Responder
