Adolfoaventin Publicado 28 de Agosto del 2022 Denunciar Publicado 28 de Agosto del 2022 Con Vag-com me da un error que no lo consigo localizar en en el foro. Agradecería me ayudarais. Un saludo 1 Avería detectada: 00493 - Unidad de sensores del ESP 008 - Señal inadmisible Cuadro Congelado: Estado de Avería: 01101000 Prioridad de Avería: 3 Frecuencia de Avería: 1 Reseteos del Contador: 4 Kilometraje: 196712 km Indicación de Tiempo: 0 Fecha: 2022.08.28 Tiempo: 12:14:17 Cuadro Congelado: Valor Hex: 0x0000 Valor Hex: 0x42A2 Valor Hex: 0x0013 Valor Hex: 0x17AB Valor Hex: 0x00FF Responder
Carlisu84 Publicado 29 de Agosto del 2022 Denunciar Publicado 29 de Agosto del 2022 00493 - ESP-Sensor Unit (G419) 00493 - ESP-Sensor Unit (G419): Implausible Signal Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes Steering Angle Sensor (G85) not properly learned Wiring/Connectors from Brake Electronics (J104) to ESP-Sensor Unit (G419) faulty ESP-Sensor Unit (G419) faulty Possible Solutions Adapt Steering Angle Sensor (G85) Check Wiring/Connectors from Brake Electronics (J104) to ESP-Sensor Unit (G419) Check Measuring Value Blocks (MVB) Replace ESP-Sensor Unit (G419) Special Notes The ESP-Sensor Unit (G419) contains several individual Sensors like the Rotation Rate and/or Transverse Acceleration Sensor. 00493 - ESP-Sensor Unit (G419): No Signal/Communication Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes Wiring/Connectors from Brake Electronics (J104) to ESP-Sensor Unit (G419) faulty ESP-Sensor Unit (G419) faulty Possible Solutions Check Wiring/Connectors from Brake Electronics (J104) to ESP-Sensor Unit (G419) Check Measuring Value Blocks (MVB) Replace ESP-Sensor Unit (G419) Special Notes The ESP-Sensor Unit (G419) contains several individual Sensors like the Rotation Rate and/or Transverse Acceleration Sensor. 00493 - ESP-Sensor Unit (G419): Defective Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes ESP-Sensor Unit (G419) faulty Possible Solutions Replace ESP-Sensor Unit (G419) Special Notes The ESP-Sensor Unit (G419) contains several individual Sensors like the Rotation Rate and/or Transverse Acceleration Sensor. 00493 - ESP-Sensor Unit (G419): No or Incorrect Basic Setting / Adaptation Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes Basic Setting of ESP-Sensor Unit (G419) not performed Possible Solutions Perform Basic Setting for ESP-Sensor Unit (G419) Special Notes The ESP-Sensor Unit (G419) contains several individual Sensors like the Rotation Rate and/or Transverse Acceleration Sensor. fuente: http://wiki.ross-tech.com/wiki/index.php/00493 Responder
Deivid_g7 Publicado 30 de Agosto del 2022 Denunciar Publicado 30 de Agosto del 2022 Comprueba la batería Responder
Adolfoaventin Publicado 2 de Octubre del 2022 Autor Denunciar Publicado 2 de Octubre del 2022 En 29/8/2022 a las 8:20, Carlisu84 dijo: 00493 - ESP-Sensor Unit (G419) 00493 - ESP-Sensor Unit (G419): Implausible Signal Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes Steering Angle Sensor (G85) not properly learned Wiring/Connectors from Brake Electronics (J104) to ESP-Sensor Unit (G419) faulty ESP-Sensor Unit (G419) faulty Possible Solutions Adapt Steering Angle Sensor (G85) Check Wiring/Connectors from Brake Electronics (J104) to ESP-Sensor Unit (G419) Check Measuring Value Blocks (MVB) Replace ESP-Sensor Unit (G419) Special Notes The ESP-Sensor Unit (G419) contains several individual Sensors like the Rotation Rate and/or Transverse Acceleration Sensor. 00493 - ESP-Sensor Unit (G419): No Signal/Communication Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes Wiring/Connectors from Brake Electronics (J104) to ESP-Sensor Unit (G419) faulty ESP-Sensor Unit (G419) faulty Possible Solutions Check Wiring/Connectors from Brake Electronics (J104) to ESP-Sensor Unit (G419) Check Measuring Value Blocks (MVB) Replace ESP-Sensor Unit (G419) Special Notes The ESP-Sensor Unit (G419) contains several individual Sensors like the Rotation Rate and/or Transverse Acceleration Sensor. 00493 - ESP-Sensor Unit (G419): Defective Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes ESP-Sensor Unit (G419) faulty Possible Solutions Replace ESP-Sensor Unit (G419) Special Notes The ESP-Sensor Unit (G419) contains several individual Sensors like the Rotation Rate and/or Transverse Acceleration Sensor. 00493 - ESP-Sensor Unit (G419): No or Incorrect Basic Setting / Adaptation Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes Basic Setting of ESP-Sensor Unit (G419) not performed Possible Solutions Perform Basic Setting for ESP-Sensor Unit (G419) Special Notes The ESP-Sensor Unit (G419) contains several individual Sensors like the Rotation Rate and/or Transverse Acceleration Sensor. fuente: http://wiki.ross-tech.com/wiki/index.php/00493 He realizado todas las comprobaciones y ahora me sale algo parecido: 1 Avería detectada: 00493 - Unidad de sensores del ESP 004 - Sin señal/comunicación Cuadro Congelado: Estado de Avería: 01100100 Prioridad de Avería: 2 Frecuencia de Avería: 1 Reseteos del Contador: 40 Kilometraje: 196712 km Indicación de Tiempo: 0 Fecha: 2022.10.02 Responder
Adolfoaventin Publicado 2 de Octubre del 2022 Autor Denunciar Publicado 2 de Octubre del 2022 En 31/8/2022 a las 1:53, Deivid_g7 dijo: Comprueba la batería 13.80 V Voltaje Batería 45.2 % DF-Todas las ventanas y Cerrar techo corredizo 3.00 s Carga-Response 19:13:10 Grupo 002: Batterietemperaturen && Abschaltstufen 40.0°C Temperatura Stromschiene 22.5°C Temperatura Batería ApagConsumid0 Desconexión de emergencia CorriReposNiv 0 Nivel Desconexión Corriente Reposo 19:13:10 Grupo 003: Estado Batería I 100.0 % Estado Batería 4 ohms interior Resistencia 0 Ah Envejecimiento der Batería (Qv) 29 Ah Carga He realizado todas las comprobaciones y ahora me sale algo parecido: 1 Avería detectada: 00493 - Unidad de sensores del ESP 004 - Sin señal/comunicación Cuadro Congelado: Estado de Avería: 01100100 Prioridad de Avería: 2 Frecuencia de Avería: 1 Reseteos del Contador: 40 Kilometraje: 196712 km Indicación de Tiempo: 0 Fecha: 2022.10.02 Responder
Carlisu84 Publicado 3 de Octubre del 2022 Denunciar Publicado 3 de Octubre del 2022 hace 12 horas, Adolfoaventin dijo: He realizado todas las comprobaciones y ahora me sale algo parecido: 1 Avería detectada: 00493 - Unidad de sensores del ESP 004 - Sin señal/comunicación Cuadro Congelado: Estado de Avería: 01100100 Prioridad de Avería: 2 Frecuencia de Avería: 1 Reseteos del Contador: 40 Kilometraje: 196712 km Indicación de Tiempo: 0 Fecha: 2022.10.02 tienes que probar a lo que dice la pagina de rosstech haber si descartas este fallo. Responder
Adolfoaventin Publicado 7 de Enero del 2023 Autor Denunciar Publicado 7 de Enero del 2023 Ahora, además de ESP encendido, al pisar freno se enciende ABS. Ya no sé que hacer. Responder
Adolfoaventin Publicado 23 de Enero del 2023 Autor Denunciar Publicado 23 de Enero del 2023 Nadie sabe que podrñia hacer? Que puede ser? Agradecería una ayuda. Gracias Responder
MARIO-A6 Publicado 24 de Enero del 2023 Denunciar Publicado 24 de Enero del 2023 Me da que tienes el módulo del ABS averiado, yo vendí un módulo de ABS a un chico y tenía los mismos fallos que tu, en la casa detectaron que el módulo estaba mal, lo cambió y al parecer todo se solucióno, aunque me parece que si cambias el módulo hay que codificarlo, puedes empezar por comprobar eso. Salu2. Responder
ximo@6 Publicado 29 de Enero del 2023 Denunciar Publicado 29 de Enero del 2023 antes de cambiarlo, saca la codificación que tienes, Responder
