Hola,hace ñunos días le pasé un autoscan con el vagcom a mi  coche  y me dio este log con todos los detalles,alguien sabría decirme si hay que alarmarse en algo o está bien?.
Friday,09,September,2022,16:12:01:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.3.0.1 (x64)
Data version: 20220225 DS336.1
www.Ross-Tech.com
Mileage: 231930km-144114mi   Repair Order:
Chassis Type: 8T0
Scan: 01 03 05 07 08 09 0E 10 14 15 16 17 19 1B 37 3C 42 46 47 52
          53 55 56 62 69 6D 72 77
   Mileage: 231930km-144114miles
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: Cannot be reached 1100
14-Susp. Elect. -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: Cannot be reached 1100
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 S    HW: 8K0 907 379 S
   Component: ESP8 quattro  H04 0210
   Revision: --------    Serial number: --------------
   Coding: 1BA500
   Shop #: WSC 00187 572 93110
   VCID: 499300E6E0B90BC755-801C
No fault code found.
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 AE    HW: 8K0 907 064 AE
   Component: BCM2 1.1      H71 0134
   Revision: 00002001
   Coding: 030200
   Shop #: WSC 06335 000 00000
   VCID: 73EF820ED2B52117CF-8026
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H37 0060
   Serial number: 0608000005290018
   Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000008454005
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 N    HW: 4E0 035 729
   Component: Interfacebox    H43 5170
   Revision: 00000000    Serial number: 329CT087551158
   Coding: 0001004
   VCID: 448D11D2079BD6AFA6-8010
   Subsystem 1 - Part No: 8T0 919 609
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000061721
   Subsystem 3 - Serial number: 0122.03.080000000100010095ÿ
   Subsystem 4 - Serial number: 010095ÿ
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 230381 km
                    Time Indication: 0
                    Date: 2022.08.06
                    Time: 21:48:03
             Freeze Frame:
                    Bin. Bits: 00100000 00000000
                    Bin. Bits: 00000000 00000000
Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-3Z.clb
   Part No SW: 8T1 820 043 Q    HW: 8T1 820 043 Q
   Component: KLIMA 3 ZONEN H05 0120
   Revision: C0000000    Serial number: 0117.03.080334
   Coding: 36000000
   VCID: 3F871E3EAE7DB577FB-806A
Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H21 0253
   Revision: 04021001    Serial number: 00000000115280
   Coding: 260050914034AF311E01000000001D0D0F9CA74800010141000000
   VCID: 2F674E7E7E1D45F76B-807A
   Subsystem 1 - Part No SW: 8K1 955 119     HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 180308  H06 0060
   Serial number: SWFBIE 0001669
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10083331
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002003080910
Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H41 0390
   Revision: 00041001    Serial number: AUZ5ZBH8352156
   Shop #: WSC 00000 000 00000
   VCID: 2A515F6A85FF20DFBC-807E
Address 10: Park/Steer Assist
Cannot be reached
Address 14: Susp. Elect.
Cannot be reached
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H10 0012
   Revision: --------    Serial number: 90315HBP000AC
   Coding: 000013
   VCID: 3E79633AA977BC7FF0-806A
   Component: E221 - MFL  H02 0003
Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 930 C    HW: 8K0 920 930 C
   Component: KOMBIINSTR.   H15 0221
   Revision: 00000000    Serial number: 7BX62JU38
   Coding: 0F04110032000008050000
   VCID: 2D5B5476741137E759-8078
Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
   Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0092
   Revision: FB402044    Serial number: 4400F0832480B1
   Coding: 010202
   VCID: 4A913FEAE5BF00DF5C-801E
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H03 0150
   Serial number: 1800CBB5070308
1 Fault Found:
01303 - Telephone Transceiver (R36)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 192
                    Mileage: 230028 km
                    Time Indication: 0
                    Date: 2022.07.20
                    Time: 00:25:15
Address 1B: Active Steering
Cannot be reached
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1060
   Revision: 00000000    Serial number: 333CW087552399
   Shop #: WSC 00187 572 68814
   VCID: 3B7F6A2E7A65A957D7-806E
Address 3C: Lane Change
Cannot be reached
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0110533016
   Coding: 013A062020393454012002
   Subsystem 1 - Part No: 8K0 951 177
   Component: DWA-Sensor  H02 0040
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS124  H06 0036
   Subsystem 4 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J394 PS220  H06 0036
2 Faults Found:
01134 - Alarm Horn (H12)
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 192
                    Mileage: 230028 km
                    Time Indication: 0
                    Date: 2022.07.20
                    Time: 00:24:30
03250 - Motor for Trunk Closing Assist (V382)
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 231615 km
                    Time Indication: 0
                    Date: 2022.08.29
                    Time: 22:16:56
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOM.clb
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814003148701
   Coding: 020101
   Shop #: WSC 12336 024 394758
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake
Cannot be reached
Address 55: Headlight Range
Cannot be reached
Address 56: Radio        Labels: 4E0-910-541.lbl
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 336CV087546473
   Coding: 0000001
   VCID: 2E59537AB9174CFF60-807A
Address 62: Door, Rear Left
Cannot be reached
Address 69: Trailer
Cannot be reached
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851     HW: 8K9 827 851
   Component: J605  Master  H24 0220
   Revision: --------    Serial number: 8K9827851
   VCID: 7BFFAA2EFAE5695797-802E
   Subsystem 1 - Part No SW: 8K9 827 852     HW: 8K9 827 852
   Component: J756  Slave  H24 0220
   Serial number: 8K9827852
4 Faults Found:
00317 - Rear Lid Control Module (J605)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 253
                    Mileage: 230082 km
                    Time Indication: 0
                    Date: 2022.07.21
                    Time: 15:45:13
03047 - Motor (in Trunk/Hatch control module) (V375)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 244
                    Time Indication: 0
03048 - Motor (in Trunk/Hatch control module 2) (V376)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 244
                    Mileage: 1048574 km
                    Time Indication: 0
02364 - Closing Assistance
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 231615 km
                    Time Indication: 0
                    Date: 2022.08.29
                    Time: 22:17:01
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:36)--------------------------
Yo siempre lo hago con el motor en marcha, creo recordar que intente hacerlo una vez con el contacto solo y no me dejo, no sé si hice algo mal en ese momento o que pasaría, desde entonces lo hago como dije., motor gasolina.
Saludos...
En 17/9/2022 a las 12:15, Susoline dijo:
Monday,19,September,2022,17:19:31:00009
www.Ross-Tech.com
VIN: WAUZZZ8K99A004057   License Plate:
Chassis Type: 8K-AU48 (8T0)
VIN: WAUZZZ8K99A004057   Mileage: 232350km-144375miles
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
1B-Active Steering -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J623-CAPA)      Labels😐 059-907-401-V1.clb
  Part No SW: 8K0 907 401 F    HW: 8K0 907 401
  Component: 3.0TDI EDC17  H01 0004
  Revision: --H01---    CVN: 5F3BA505
  Coding: 0104002C180F0828
  ASAM Dataset: EV_ECM30LTDIA5 A02004
  ROD: EV_ECM30LTDIA5_A02.rod
  VCID: 2E59537A71174CFF60-807A
  VINID: 9D196AAAA21B2494400040051C991B36D2
Readiness: 0 0 0 0 0
  Coding: 1BA500
  Revision: 00002001
  Coding: 030200
1 Fault Found:
01330 - Central Control Module for Central Convenience(J393)
           013 - Check DTC Memory - Intermittent
            Freeze Frame:
                   Fault Status: 00101101
                   Fault Priority: 6
                   Fault Frequency: 1
                   Reset counter: 4
                   Mileage: 232317 km
                   Time Indication: 0
                   Date: 2022.09.15
                   Time: 19:38:58
  Coding: 0001004
1 Fault Found:
03157 - Functionality limited due to CommunicationsDisruption
            Freeze Frame:
                   Fault Priority: 6
                   Fault Frequency: 1
                   Reset counter: 240
                   Mileage: 230381 km
                   Time Indication: 0
                   Date: 2022.08.06
                   Time: 21:48:03
            Freeze Frame:
  Coding: 36000000
  Coding: 00FD11
  Coding: 025028
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
  Part No SW: 8K0 919 475 B    HW: 8K0 919 475
  Component: PARKHILFE 4K  H06 0010
  Revision: 11001001    Serial number: 75330807801314
  Coding: 010003
  VCID: 387575228B53824F3A-806C
Address 14: Susp. Elect. (J250)       Labels: None
  Part No SW: 8K0 907 364     HW: 8K0 907 364
  Component: DAEMPFUNGS-SG H08 0052
  Revision: 00000000    Serial number: 27020803190002
  Coding: 050181
  Shop #: WSC 08006 572 86700
  VCID: 70E58D02A3A31A0F32-8024
Address 15: Airbags (J234)       Labels😐 8K0-959-655.clb
  Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
  Component: AirbagVW-AU10 H26 0410
  Serial number: 0038JD140HWB
  Coding: 30343434363030303030554A304C384B3053
  ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
  ROD: EV_AirbaECUVWAUDI010_A02.rod
  VCID: 3C7D6932B76BAE6FDE-8068
  Crash sensor for side airbag: driver side:
  Serial number: 6334MSME3531342B5
  Front Passenger's Side Airbag Crash Sensor:
  Serial number: 6344MSME3965676CS
  Rear Side Airbag Crash Sensor (on driver's side😞
  Serial number: 6352QSME58014677F
  Passenger side rear thorax airbag crash sensor:
  Serial number: 6362QSME5B1A4973S
  Crash sensor for front airbag: driver side:
  Serial number: 63732SME5A30191F0
  Crash sensor for front airbag: front passenger side:
  Serial number: 63832SME57031175T
  Coding: 000013
  Coding: 0F1D110032000008050000
  Shop #: WSC 06335 123 12345
  Coding: 010202
1 Fault Found:
            Freeze Frame:
                   Fault Priority: 2
                   Fault Frequency: 1
                   Reset counter: 192
                   Mileage: 230028 km
                   Time Indication: 0
                   Date: 2022.07.20
                   Time: 00:25:15
Address 1B: Active Steering (J792)       Labels: None
  Part No SW: 8K0 907 144 D    HW: 8K0 907 144 D
  Component: DYNAMIKLENK.  H05 0570
  Revision: 50000003    Serial number: --------------
  Coding: 0C0000
  VCID: 30654D0263235A0F72-8064
Address 3C: Lane Change        Labels: None
  Part No SW: 8K0 907 566 A    HW: 4L0 907 566 B
  Component: J0769_SWA_MasterH01 0020
  Revision: 00H01000    Serial number: 6PZ 009 014-12
  Coding: 0010102
  Shop #: WSC 08006 572 66304
  VCID: 356B7C165C417F2721-8060
  Subsystem 1 - Part No: 8K0 907 568 A
  Component: J0770_SWA_Slave_H01 0020
  Subsystem 2 - Serial number: 6PZ 009 014-32
  Subsystem 3 - Serial number: 5F01.04.0800H010003C710004ÿ
  Subsystem 4 - Serial number: 710004ÿ
Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
  Part No SW: 8K0 959 793 B    HW: 8K0 959 793
  Component: TSG FA        H10 0170
  Revision:             Serial number: 0000006951399
  Coding: 011C02204100410001
1 Fault Found:
02115 - Locking Unit for Central Locking
            Freeze Frame:
                   Fault Priority: 3
                   Fault Frequency: 3
                   Reset counter: 251
                   Mileage: 231810 km
                   Time Indication: 0
                   Date: 2022.09.03
                   Time: 10:00:55
  Coding: 013E062020393454012002
4 Faults Found:
           014 - Defective
            Freeze Frame:
                   Fault Priority: 2
                   Fault Frequency: 1
                   Reset counter: 192
                   Mileage: 230028 km
                   Time Indication: 0
                   Date: 2022.07.20
                   Time: 00:24:30
            Freeze Frame:
                   Fault Priority: 2
                   Fault Frequency: 1
                   Reset counter: 246
                   Mileage: 231615 km
                   Time Indication: 0
                   Date: 2022.08.29
                   Time: 22:16:56
03124 - Terminal 30 - 3
            Freeze Frame:
                   Fault Priority: 2
                   Fault Frequency: 1
                   Reset counter: 4
                   Mileage: 232317 km
                   Time Indication: 0
                   Date: 2022.09.15
                   Time: 19:38:58
03123 - Terminal 30 - 2
            Freeze Frame:
                   Fault Priority: 2
                   Fault Frequency: 1
                   Reset counter: 5
                   Mileage: 232317 km
                   Time Indication: 0
                   Date: 2022.09.15
                   Time: 19:38:58
  Coding: 020101
Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
  Part No SW: 8K0 959 792 B    HW: 8K0 959 792
  Component: TSG BF        H10 0170
  Revision:             Serial number: 0000006962090
  Coding: 011C02204D00410001
Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
  Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
  Component: EPB Audi B8   H04 0050
  Revision: 00000003    Serial number: 00000000098466
Address 55: Headlight Range        Labels: 8K0-907-357.clb
  Part No: 8K0 907 357 B
  Component: Dynamische LWR  H01 0010
  Revision: 00000001    Serial number:
  Coding: 0000005
  Shop #: WSC 06334 000 00000
  VCID: 346D4112573B662F16-8060
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
           000 - - - MIL ON
            Freeze Frame:
                   Fault Status: 11100000
                   Fault Priority: 7
                   Fault Frequency: 1
                   Reset counter: 204
                   Mileage: 231493 km
                   Time Indication: 0
                   Date: 2022.08.23
                   Time: 15:11:00
  Coding: 0000001
Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
  Part No SW: 8K0 959 795     HW: 8K0 959 795
  Component: TSG HL        H06 0170
  Revision:             Serial number: 0000006928975
  Coding: 010C02204000210001
  VCID: 7F075E3EEEFD7577BB-802A
1 Fault Found:
            Freeze Frame:
                   Fault Status: 01101000
                   Fault Priority: 3
                   Fault Frequency: 1
                   Reset counter: 192
                   Mileage: 230028 km
                   Time Indication: 0
                   Date: 2022.07.20
                   Time: 00:44:22
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
  Part No SW: 8K0 907 383 A    HW: 8K0 907 383 A
  Component: Anhaenger     H06 0040
  Revision: 1A002002    Serial number: 00000113885278
  Coding: 0100000000000000
  VCID: 3261470A6D2F681F04-8066
1 Fault Found:
16355 - Control Module - Watchdog Timer
           014 - Defective
            Freeze Frame:
                   Fault Priority: 3
                   Fault Frequency: 1
                   Reset counter: 225
                   Mileage: 204971 km
                   Time Indication: 0
                   Date: 2019.12.14
                   Time: 11:48:54
4 Faults Found:
            Freeze Frame:
                   Fault Priority: 3
                   Fault Frequency: 8
                   Reset counter: 253
                   Mileage: 230082 km
                   Time Indication: 0
                   Date: 2022.07.21
                   Time: 15:45:13
            Freeze Frame:
                   Fault Priority: 3
                   Fault Frequency: 1
                   Reset counter: 244
                   Time Indication: 0
            Freeze Frame:
                   Fault Priority: 3
                   Fault Frequency: 1
                   Reset counter: 244
                   Mileage: 1048574 km
                   Time Indication: 0
            Freeze Frame:
                   Fault Priority: 7
                   Fault Frequency: 1
                   Reset counter: 246
                   Mileage: 231615 km
                   Time Indication: 0
                   Date: 2022.08.29
                   Time: 22:17:01
Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-794.clb
  Part No SW: 8K0 959 794     HW: 8K0 959 795
  Component: TSG HR        H06 0170
  Revision:             Serial number: 0000006955584
  VCID: 7EF9A33AE9F77C7FB0-802A
Cannot be reached
End-------------------------(Elapsed Time: 04:06)--------------------------
Ami de momento el bluetooth  lo noto que funciona bien,pero como lo compre hace poco pues tampoco sabría decirte si va fino fino.
Respecto a la puerta del conductor y la del depósito,pues la verdad que a mi  me cierran de momento sin que note nada raro.
Gracias
Editado por Susoline
