Buenas tardes gente. Tengo un Q5 3.0 TDI y no arranca.
Tengo vcds. Puede ayudarme?
dress 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8R0 907 401 S    HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H08 0005
   Revision: 15H08---    CVN: 2AB4E653
   Coding: 01210003240F0128
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM30TDI0118R0907401S 001006
   ROD: EV_ECM30TDI0118R0907401R.rod
   VCID: 428BFF0FD58FD89D15-8016
   VINID: 9D19537542222524400401C8201242AC34
3 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
          Not Confirmed - Tested Since Memory Clear
         Freeze Frame:
                Fault Status: 00000001
                Fault Priority: 6
                Fault Frequency: 2
                Mileage: 133828 km
                Date: 2010.02.16
                Time: 01:12:43
                Engine RPM: 0.00 /min
                Normed load value: 0.0 %
                Vehicle speed: 0 km/h
                Coolant temperature: 22 °C
                Intake air temperature: 27 °C
                Ambient air pressure: 860 mbar
                Voltage terminal 30: 11.520 V
                Unlearning counter according OBD: 40
                Crankshaft speed (RPM): 0.0 /min
                Vehicle speed: 0.00 km/h
                Cruise Control System: specified speed: 0.00 km/h
                CCS status-Bits 0-7: 00101100
                Cr Ctl st Shut Offirev-Bits 0-7: 00000000
                Cr Ctl st Shut Offrev-Bits 0-7: 00000000
                Cr Ctl st Shut Offrev-Bits 0-7: 00000001
                Cr C st Key 0-Bits 0-7: 00000000
4699 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
         Freeze Frame:
                Fault Priority: 6
                Fault Frequency: 2
                Mileage: 133828 km
                Date: 2010.02.16
