Hola buenos dias, ando desesperado con estos errores, alguien sabe por donde meterle mano
        Address 08: Auto HVAC       Labels: 8P0-820-043.lbl
Control Module Part Number: 8P0 820 043 BG    HW: 8P0 820 043 BG
  Component and/or Version: KlimavollautomatH09 0100
           Software Coding:
            Work Shop Code: WSC 00000 000 00000
                      VCID: 72EB3C436D5AFA8E927-8027
5 Faults Found:
01087 - Basic Setting Not Performed
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 114
                    Mileage: 253015 km
                    Time Indication: 0
             Freeze Frame:
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 252888 km
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 12.50 V
                    (no units): 255.0
                    Temperature: 17.5°C
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 253015 km
                    Time Indication: 0
                    Date: 2023.04.11
                    Time: 19:56:38
             Freeze Frame:
                    Voltage: 12.50 V
                    (no units): 255.0
                    Temperature: 28.0°C
01272 - Positioning Motor for Central Flap (V70)
            003 - Mechanical Failure - Intermittent
             Freeze Frame:
                    Fault Status: 00100011
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 159
                    Mileage: 253035 km
                    Time Indication: 0
                    Date: 2023.04.12
                    Time: 14:39:32
             Freeze Frame:
                    Voltage: 14.10 V
                    Temperature: 35.0°C
                    (no units): 197.0
                    (no units): 26.0
                    Temperature: 26.0°C
65535 - Internal Control Module Memory Error
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 253048 km
                    Time Indication: 0
                    Date: 2023.04.12
                    Time: 14:49:18
             Freeze Frame:
                    Temperature: 36.5°C
  En 16/4/2023 a las 10:33, borjabarea dijo:
           Software Coding:
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 114
                    Mileage: 253015 km
                    Time Indication: 0
             Freeze Frame:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 252888 km
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 12.50 V
                    (no units): 255.0
                    Temperature: 17.5°C
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 253015 km
                    Time Indication: 0
                    Date: 2023.04.11
                    Time: 19:56:38
             Freeze Frame:
                    Voltage: 12.50 V
                    (no units): 255.0
                    Temperature: 28.0°C
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 159
                    Mileage: 253035 km
                    Time Indication: 0
                    Date: 2023.04.12
                    Time: 14:39:32
             Freeze Frame:
                    Voltage: 14.10 V
                    Temperature: 35.0°C
                    (no units): 197.0
                    (no units): 26.0
                    Temperature: 26.0°C
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 253048 km
                    Time Indication: 0
                    Date: 2023.04.12
                    Time: 14:49:18
             Freeze Frame:
                    Temperature: 36.5°C
Expand
Primero ejecuta un 'basic setting' que te lo esta pidiendo;
[select]
[08 - Heating/Air Conditioning]
[basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The basic setting takes approximately 40 seconds.
[Done, Go Back]
[Close Controller, Go Back - 06]
Luego borras errores, que algunos son intermitentes. Ves que errores se quedan. Si no queda ninguno, andas un par de dias y vuelves a diagnosticar, y seguimos viendo.
Unsaluso
  En 16/4/2023 a las 19:06, Lazpi dijo:
[select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Unsaluso
Expand
buenas tarde he comprobado lo que comentaste y nada me sale NOT OK cuando le doy a [ON/OFF/Next] he esperado mas de un minuto a ver si cambiaba pero nada, por un momento sale la palabra ADP.RUM y vuelve al NOT OK, me salgo borro los errores y sigue igual
Si no puedes hacer una adaptacion, mal asunto, porque el climatizador no sabe cual es el recorrido de las trampillas.
Por no decirte un 'cambia el climatizador' sin gastar otros cartuchos: que version de vagcom estas usando? Te pueden prestar otro cable?
  En 18/4/2023 a las 20:28, Lazpi dijo:
Expand
Buenas tardes lazpi, perdon por la tardanza pero he estado fuera todo este tiempo, pues resulta que pedi los servomotores v70 y v158 que es lo que me estaba dando fallos, y bingo , al cambiarlo me dejo hacer la configuracion de las trampillas como me dijiste y va todo perfe, me echa aire frio y tambien por el centro que me dejo de echar aire por culpa del servomotor v70, esta mañana he montado los dos y va todo perfecto por ahora, de pensar que podia ser el clima o el compresor resulta que han sido los servomotores y la multa a sido la cantidad que menos esperaba, muchas gracias por tu aporte y tiempo, ahh el el vag com que tengo es el 12.12 un poco antiguo pero me dejor hacer ajuste
  • 10 meses más tarde...
