oscarcaco Publicado Viernes a las 19:00 Denunciar Publicado Viernes a las 19:00 Muy buenas, hoy me ha empezado a parpadear el testigo de calentadores lo he conectado al cable y hecho test y me hadado esto, si alguien me sabe decir que es lo que me falla y como solucionarlo. Friday,11,April,2025,12:40:55:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.0.0 Data version: 20130910 VIN: WAUZZZ8R4AA111339 License Plate: Mileage: 356600km-221580mi Repair Order: Chassis Type: 8R (8T0) Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77 VIN: WAUZZZ8R4AA111339 Mileage: 356600km/221580miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 NH HW: 03L 906 022 B Component: R4 2.0l TDI H04 9978 Revision: 11H04--- Coding: 01210023180F2120 Shop #: WSC 06067 005 1048576 ASAM Dataset: EV_ECM20TDI03L906022NH A01010 ROD: EV_ECM20TDI03L906022JT.rod VCID: 78FF0E6BC32690DEAC3-802D 2 Faults Found: 4515 - Radiator Fan (V7) P1950 00 [039] - Movement Restricted / Jammed Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 356601 km Date: 2025.04.11 Time: 12:32:20 4892 - EGR Valve (N18) P0403 00 [175] - Malfunction MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Mileage: 356561 km Date: 2025.04.10 Time: 20:17:22 Readiness: 1 1 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8R0-907-379.clb Part No SW: 8R0 907 379 L HW: 8R0 907 379 L Component: ESP8 quattro H07 0010 Revision: -------- Serial number: -------------- Coding: 0C1540 Shop #: WSC 06335 000 00000 VCID: 4999BBAFE04CD95603D-801C No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0328 Revision: 00002001 Coding: 030500 Shop #: WSC 06335 000 00000 VCID: 8109E38F18FC51161BD-80D4 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H50 0070 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AM HW: 8T1 820 043 AM Component: KLIMA 1 ZONE H08 0180 Revision: A0000000 Serial number: 01130520100032 Coding: 34010000 Shop #: WSC 06335 000 00000 VCID: 7CF7127BFF1EBCFEC8B-8029 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 5 Reset counter: 75 Mileage: 355446 km Time Indication: 0 Date: 2025.01.18 Time: 19:55:52 Freeze Frame: Temperature: 8.0 C RPM: 2440 /min Speed: 0.0 km/h ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 N HW: 8K0 907 063 N Component: BCM1 1.0 H29 0380 Revision: 09029001 Serial number: 00000000665210 Coding: 260050914034AF010001000000001D0D0F1C070802010101000000 Shop #: WSC 06335 000 00000 VCID: 3A7BD463B5AA42CE9A7-806F Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB Component: WWS416 100428 H10 0041 Coding: 01DD13 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Coding: 024D25 Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090 1 Fault Found: 00979 - Lamp for Low Beam; Right (M31) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 58 Reset counter: 99 Mileage: 338542 km Time Indication: 0 Date: 2023.10.30 Time: 22:05:00 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 R HW: 8K0 919 475 A Component: PARKHILFE 8K H06 0070 Revision: 11001001 Serial number: 50941013005364 Coding: 100005 Shop #: WSC 06335 000 00000 VCID: 489FBEABFB46205E1C3-801D No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8R0-959-655.clb Part No SW: 8R0 959 655 E HW: 8R0 959 655 E Component: AirbagVW-AU10 H41 0610 Serial number: 003GND0G1792 Coding: 30423331313030303030554A304C38523053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaAU10SMEAU416 002004 ROD: EV_AirbaAU10SMEAU416.rod VCID: 4683B093F952362EEEF-8013 Crash sensor for side airbag; driver side: Serial number: 6334MSME520536600 Crash sensor for side airbag; passenger side: Serial number: 6344MSME53314135% Crash sensor for side airbag; rear driver side: Serial number: 6352QSME0761342CC Crash sensor for side airbag; rear passenger side: Serial number: 6362QSME4D5D4C36 Crash sensor for front airbag; driver side: Serial number: 63732SME0B61341E$ Crash sensor for front airbag; passenger side: Serial number: 63832SME0A611F3E7 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90319JEA000KH Coding: 000017 Shop #: WSC 06335 000 00000 VCID: 3D71DF7FA48475F6BF5-8068 Component: E221 - MFL H04 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb Part No SW: 8R0 920 930 D HW: 8R0 920 930 D Component: KOMBIINSTR. H11 0255 Revision: 00400000 Serial number: CJL46NV4A Coding: 0F44220002000008050000 Shop #: WSC 06335 123 12345 VCID: 3561C75F9CB4ADB6775-8060 1 Fault Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 88 Mileage: 321070 km Time Indication: 0 Date: 2022.11.28 Time: 11:01:57 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0117 Revision: GB800053 Serial number: 5300G105078401 Coding: 00C303 Shop #: WSC 06335 000 00000 VCID: 8109E38F18FC51161BD-80D4 Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181 Component: J367-BDM H07 0140 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 H HW: 8K0 959 793 D Component: TSG FA H11 0306 Revision: Serial number: 0000010631515 Coding: 011D02205000440004 Shop #: WSC 06335 000 00000 VCID: 4581B79FCC543D36E75-8010 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0328 Revision: 00002001 Serial number: 0130107571 Coding: 013A0620203900C00520053280000000 Shop #: WSC 06335 000 00000 VCID: 8109E38F18FC51161BD-80D4 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb Part No SW: 8R0 035 223 F HW: 8R0 035 223 E Component: DSP STD H11 0440 Revision: 00000000 Serial number: 00000000000001 Coding: 0203010102 Shop #: WSC 06335 000 00000 VCID: 2F6DF5377EE897663D9-807A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 H HW: 8K0 959 792 D Component: TSG BF H11 0306 Revision: Serial number: 0000010632122 Coding: 011D02205000440004 Shop #: WSC 06335 000 00000 VCID: 4487AA9BC76E043EF0B-8011 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 10000000513432 Shop #: WSC 00000 000 00000 VCID: 3467FA5B97CEB4BE40B-8061 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 P HW: 8T1 035 186 P Component: Concert3 H07 0350 Revision: 00000011 Serial number: AUZ5Z6J1401983 Coding: 0502008201058500015B070000 Shop #: WSC 06335 000 00000 VCID: 4487AA9BC76E043EF0B-8011 Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F Component: Display No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HL H10 0306 Revision: Serial number: 0000104202667 Coding: 010C02204000240004 Shop #: WSC 06335 000 00000 VCID: 428BAC83DD7A0A0EC27-8017 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HR H10 0306 Revision: Serial number: 0000104200348 Coding: 010C02204000240004 Shop #: WSC 06335 000 00000 VCID: 428BAC83DD7A0A0EC27-8017 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8T0 862 335 D HW: 8T0 862 335 D Component: FSE_256x BT H39 0600 Revision: 00000000 Serial number: 00000005189962 Coding: 0010350 Shop #: WSC 06335 000 00000 VCID: 3B75D1677A907BC6811-806E No fault code found. End --------------------------------------------------------------------- Responder
