Xingular Publicado 9 de Agosto del 2005 Denunciar Compartir Publicado 9 de Agosto del 2005 New this month from Black Forest Industries is our collection of structural reinforcement bars for the MKIII and MKIV. Currently we are offering three options with an expanded range to come in the future. The first of our new structural reinforcement bars is the MKIV C-Pillar reinforcement bar. It is made from polished aluminum and will bolt into both the MKIV Golf and Jetta. The bar attaches to the hard points where the rear seatbelts mount and can be installed in just minutes. These bars help to stiffen the chassis and are particularly helpful in Golf applications in eliminating the various squeaks and rattles many are all too familiar with. The MKIV C-Pillar bar retails for $49.00 plus $8.00 fixed shipping. Additional $5.00 to Canada Mas información n addition to the C-Pillar bar we are now also offering our MKIV Front Lower Tie Bar. This bar is designed very similarly to the tie bars found on the MKI cars and it serves the exact same purpose. This bar ties the control arm mounting points together to once again make the chassis more rigid and prevent flexing under load. It is also constructed of polished aluminum with high quality adjustable heim-joint endlinks. Additional longer hardware is included and installation is very straightforward and simple. This bar will fit all MKIVs and retails for $55.00 shipped in the U.S. Más información. For the MKIII Golf we are now offering our Rear Shock Tower Brace. This bar bolts directly to the top of the shocks and helps to create a more unified rear end. We have found that this bar also helps eliminate some of the miscellaneous squeaks and rattles that develop over time. A nickel sized piece must be trimmed away from the hatch cover support on each side to install this bar but the hatch cover can still be retained. Installation is very simple and can be done in a few minutes. No additional hardware is required. This bar is also made of polished aluminum. Additionally, our bar will also fit Corrados if the rear speaker trays are removed completely. Retail cost is $40.00 plus $8.00 shipping in the U.S. Más información. Todo en America, eso creo. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
dameric Publicado 9 de Agosto del 2005 Denunciar Compartir Publicado 9 de Agosto del 2005 para q sirven? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Xingular Publicado 9 de Agosto del 2005 Autor Denunciar Compartir Publicado 9 de Agosto del 2005 para q sirven? rigidez al chasis, supongo. Como las delanteras. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
sybaris Publicado 9 de Agosto del 2005 Denunciar Compartir Publicado 9 de Agosto del 2005 ¿Y tienes que quitar los reposacabezas traseros? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
dameric Publicado 10 de Agosto del 2005 Denunciar Compartir Publicado 10 de Agosto del 2005 no creo q sea rigidez del chasis, las barras de refuerzo de suspension hace la tira de años q existen yo e visto montadas detras y van de torreta a torreta de los amortiguadores no hay arriba como en la foto se ve. quiza sea para poder sujetar algo que lleves tipo anclaje no creees? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
tante peláez Publicado 10 de Agosto del 2005 Denunciar Compartir Publicado 10 de Agosto del 2005 Pues según ellos sirven para esto. These bars help to stiffen the chassis and are particularly helpful in Golf applications in eliminating the various squeaks and rattles many are all too familiar with Mas o menos " ayudan a reforzar el chasis y son particularmente utiles eliminando chirridos y traqueteos (mas bien vibraciones)" Responder Enlace al comentario Compartir en otros sitios web More sharing options...
