Dear Mr.Herrero,
thank you for your friendly inquiry!
NEW !
B&B set of doormats for AUDI !
Black mats in high-grade fabric, B&B logo imprinted, the ideal present...
for EUR 98 incl. VAT.
We ask you to check our various possibilities for the re-equipment of your
AUDI S3 and indicate us briefly afterwards which re-equipping version is
applicable for you. We will create then immediately a special supply for you
and would be very pleased to be allowed to do the optimization of your
vehicle reliably according to your desires.
NEW !!!
1) B&B ALUMINIUIM-wheel "B1" with 5-spokes, "B2" in multi-piece design, and
"B3" cross-spokes design
From 7"x15 to 10"x22 - for Audi A2 to A8 and for VW Lupo to VW Phaeton / VW
Touareg.
Type "B1" in classical 5-spokes design
Type "B2" in multi-piece design with 16 spokes
Type "B3" in mutli-piece design with cross-spokes
Every rim includes a polished high-grade steel rim base. This provides the
rim, apart from a shining optic due to its high stability, an up to now
unreached everyday life fitness.
Advantages:
- the high-grade steel rims can bear a confrontation with i.e. guid rails of
car-washes without lasting damages
- small scratches can be easily polished away and vanish totally
- profen up to 800kg (B1) and 900kg (B2) - so also qualified for heavier
modells like VW-Phaeton, VW-Touareg, VW-T4, AUDI A6/A8/Allroad.
Photo:
If you like to receive extensive AUDI folder material including test data,
please send a stamp duty of EUR 5 as banknote; we send you gladly in the
next days our AUDI folders inclusive performance data and price lists via
mail. We are sorry, but we had to raise this stamp duty due to the rising
request on folders. With an order this duty of EUR 5 will be credited, of
course.
Please indicate your motor vehicle type when ordering the documents.
If you were not able to receive the pictures of the vehicles and components
attached to this e-mail, the memory of your e-mail account might has been
too small. Should you nevertheless want to have the pictures transmitted,
please make sure your account has a memory capacity of at least 2-3 MB. The
pictures sent are of a size about 400KB to give detailed images.
NEWS !!!
- short-shift for 6-gear transmissions for AUDI A3/S3, A4/S4, RS4, A6, S6,
TT/TTS, VW Golf/Bora.
Shortening of the gear-shift about 40mm - thereby clearly faster and
sportier switching is achieved, which will inspire you!!!
Price: starting from EUR 298 inclusive assembly incl. VAT.
NEWS !!!
- aluminium air-circulation system for AUDI 1.8T + S3 + TTS
Exchange of the standard hose connector between turbochargers and air
cleaners to prevent the hose from pulling together at a higher engine torque
and to quarantee a more stable performance on highest engine torque.
By mounting the B&B ALUMINIUM air-circulation there is an increased air
induction (up to 30gr/s.) by which you achieve a direct response and a much
better performance.
Price: EUR 498 incl. VAT, assembly EUR 198 incl. VAT
self-adjustment possible - mounting-time about 3 - 4 hours
Photo:
NEWS !!!
- Pre-manifold exhaust tube - increased and flowoptimized for AUDI S3 + TTS
Exchange of the standard pre-manifold exhaust tube into the flowmoderately
optimized version to reduce the exhaust counter-pressure further and to
exhaust thus the exhaust gases faster.
Price: EUR 998 incl. VAT - assembly EUR 298 incl. VAT
NEWS !!!
- special racing catalysts 100CPSI for AUDI S3 + TTS
Exchange of the standard ceramic(s) catalysts into two flowoptimized
high-grade steel catalysts with 100CPSI network.
Thereby the exhaust counter-pressure is reduced clearly and the exhaust
gases are faster exhausted.
Price: EUR 1.498 incl. VAT - assembly EUR 198 incl. VAT (only with the B&B
sports exhaust system of high-grade steel)
Photo:
NEWS !!!
- Special pressure pipe with performance Pop off valve EVO 6 in connection
with special aluminium air-circulation
Increased input and output of the Pop off valve - thereby quicker conversion
of the boost pressure and optimized gas exchanges - for AUDI S3 + TTS
Price: EUR 1.198 incl.VAT - assembly EUR 298 incl. VAT
Current photos on our homepage under " projects/news "!!
Our new S3 final sport silencer (also as sport exhaust system) can be found
on our homepage under column " projects/news ".
The system is made of polished full high-grade steel, the chromium-plated
final pipes have a diameter of 70mm and a warranty of 2 years without any
delimitation of kilometers. The price for the final sport silencer amounts
to EUR 798 incl. VAT + dispatcht; the sport exhaust system amounts to EUR
1.198 incl. VAT. An increased output of 3-5h.p. with the final silencer, and
5-8h.p. with the exhaust sytem are to be expected. The sound of the exhaust
system is sportily dully/mustily without being importunate. The exhaust
system matches very properly and can be installed from any mechanic -
duration approx. 1-2 hours.
A re-equipment on level 2 with the assembly of the B&B sport exhaust system
(206KW/280h.p.) is possible within a day (also with chassis- and/or
brake-modification).
Photo:
We perform the optimization on level 1 at AUDI S3-engines by a complex
modification of the electronic code field. Here the boost pressure is raised
over approx. 0,2bar; injection pressure, -mixes and -point in time are
co-ordinated with the increased boost presure in dependency on the engine
torque. This is done on a non-standard basis differently at every other
controller, since ex factory different programmings are available. This has
the advantage of a seriesnear stability and a full everyday life fitness.
On level 2 the boost pressure is raised over approx. 0,25bar, the injection
code field is adapted to this boost pressure, the induction pipe system and
ventilation circuit are worked on as well as the ignition- and jet field
systems are optimized. Addtionally we install a modified and polished
pressure pipe and strengthen the air induction in this area.
Soon available: Exchange of the standard hose connector between air cleaners
and turbochargers into a B&B aluminium connecting piece in order to achieve
more effective pressure.
In preparation is a modified pre-manifold exhaust tube with an increased
cross section made of high-grade steel.
The performance of the 210h.p. AUDI S3 rises on level 1 to approx.
184KW/250h.p. - the torque rises from 270Nm to approx. 360Nm.
The performance of the 225h.p. AUDI S3 rises on level 1 to approx.
191KW/260h.p. - the torque rises from 280Nm to approx. 365Nm.
On level 2 the performance rises to approx. 200KW/272h.p. - the torque rises
to approx. 385Nm - in connection with our sport exhaust system to approx.
206KW/280h.p. - this is most interesting version concerning the price !
On level 3 - approx. 220KW/300h.p. - in addition to level 2, a processed
special turbocharger with modified exhaust elbow unions is inserted.
Additionally the modified air charge cooling is optimized, our sport exhaust
system is installed and the electronic codefield is co-ordinated completely
on that. Complete with all our new high-tech components (Level EVO) you will
get nearly 232KW/315PS!
Prices:
Level 1 EUR 1.198 incl. VAT + assembly
Level 2 EUR 1.998 incl. VAT inclusive assembly
Level 3 EUR 6.998 incl. VAT inclusive assembly
Level EVO EUR 11.498 incl. VAT inclusive assembly
Further increases in output of turbo models are possible - we ask in this
case for your separated inquiry - gladly also personal.
The B&B engine- and drive-guarantee is included in the prices of the
increases in output.
If you decide for the re-equipment up to a status of 10.000km, the period of
warranty is 24 months / without any limitations of kilometers.
Starting from 10.000km run performance the duration of the guarantee is 12
months / 100.000km* (* what comes first).
Starting from 100.000km run performance there is a guarantee of 6months /
50.000km on the control device. A warranty for engine and transmission is no
longer possibe.
On our electronic software there is a warranty of 5 years without any
The B&B chassis suspension kit puts the S3 over approx. 30mm deeper, has an
optimal tuning on the series shock absorbers and amoutns to EUR 298 incl.
VAT.
The B&B thread chassis for A3 S3 vehicles is available it in two different
tuning versions - comfort- and sport version - and is particularly
recommended with uprated vehicles, since it clearly contributes, apart from
a broader tyre, to the improvement of the road-hugging property and thus to
your security.
Price: EUR 1.198 incl. VAT
Our B&B/Porsche Bi-turbo 4-pistons brake calipers (322mm) for AUDI S3
vehicles amount to EUR 2.998 incl. assembly incl. VAT for the front axle
assembly (also for the rear axle possible - EUR 4.198 incl. assembly incl.
VAT) and is recommended as a useful supplement of the performance
optimization, since the braking action from high rates as well as the
stability are on the level of the Porsche turbo model with 300KW/408h.p.
Certified for wheel sets starting from 17"inch - e.g. series wheels of the
AUDI S3 (also with winter tires possible).
Photo:
The B&B shim disc record for series wheels of AUDI S3 vehicles consists
(inclusive mounting material) of 4x15mm aluminium shim discs (30mm per axle
or 30mm at front axle and 40mm at rear axle). The price: EUR 348 incl. VAT
We would be pleased to do the re-equipment of your vehicle and quarentee a
professional and reliable performance of all work.
B&B is a certified company for optimization of vehicles and member in the
VDAT - the federation of German automobiles tuner registered association -
www.vdat.de
For further questions (chassis, sport brake systems, wheels, etc.) you can
call us or sent an e-mail.
Visit us and become acquainted with our company: in our showroom you can
always find some interesting VW + AUDI vehicles - we look forward to your
visit!
Our AUDI S3 with 250h.p. was tested in number 9/1999 of "Sport Auto" and in
number 9/1999 of "Gute Fahrt " !
*** "sport auto" comment in number 9/99: " the engine tuning from B&B leaves
the most balanced impression. The harmonious performance development and the
broadly useable number of engine torque let it come out as winner. "
Yours sincerely
Stephan Baumeister
B&B automotive engineering GmbH
____________________________
Birlenbacher Str.126
57078 Siegen-Birlenbach
Tel.: 0049 / (0) 271 / 30323-0
Fax: 0049 / (0) 271 / 30323-99
Email: info@bb-automobiltechnik.de
Internet: www.bb-automobiltechnik.de
