ASI es el RACE Touareg 2
1787.5 kg
550NM de par
Caja de cambios secuencial 6 marchas X-Trac
5 cilindros TDI 2.5
Technical data Volkswagen Race Touareg 2
Engine
Construction Five-cylinder ‘in-line’ TDI diesel engine, two-stage super charging system with turbochargers and intercooler located longitudinally behind the front suspension
Cubic capacity 2.500 cm3
Power approx 202 kW (275 PS)
Torque over 550 Nm
Air intake restrictor 39 mm (FIA regulation)
Engine management Bosch
Transmission system
Gearbox Longitudinally mounted six-speed sequential race gearbox
Final drive Permanent four-wheel drive, three mechanical differentials with viscous locking
Clutch Hydraulically operated three-plate ceramic clutch
Suspension
Front & rear axles Double wishbone, two spring/damper units per wheel
Steering Servo assisted rack and pinion steering
Brake system Front and rear ventilated disc brakes (320 mm diameter), aluminium brake calipers (six piston front, four piston rear)
Wheels Size 7 x 16 inch
Tyres BF Goodrich 235-85/16
Chassis/bodywork
Construction Steel space-frame, two-door carbon-fibre composite bodywork
Dimensions and weight
Length/width/height 4171/1996/1762 mm
Track width 1750 mm front/rear
Wheelbase 2820 mm
Minimum weight 1787.5 kg
Editado por Xingular
Coches
N° Pilot Co-pilot Make Type Nat Team
301 SABY BRUNO PERIN MICHEL VOLKSWAGEN TOUAREG FRA VOLKSWAGEN MOTORSPORT
303 KLEINSCHMIDT JUTTA PONS FABRIZIA VOLKSWAGEN TOUAREG ALL VOLKSWAGEN MOTORSPORT
305 DE VILLIERS GINIEL THORNER TINA VOLKSWAGEN TOUAREG AFS VOLKSWAGEN MOTORSPORT
307 SAINZ CARLOS SCHULZ ANDREAS VOLKSWAGEN TOUAREG ESP VOLKSWAGEN MOTORSPORT
309 MILLER MARK VON ZITZEWITZ DIRK VOLKSWAGEN TOUAREG USA VOLKSWAGEN MOTORSPORT
310 HENRARD STEPHANE DE ROISSARD ANTONIA VOLKSWAGEN BEL HENRARD RACING TEAM
334 GUINOT JEAN-FRANCOIS KROISS MANFRED VOLKSWAGEN FRA HENRARD RACING TEAM
Camiones
N° Pilot Co-pilot 1 Co-pilot 2 Make Type Nat Team
533 LEIHENER KLAUS BAUMANN THOMAS GOLDBERG THORSTEN MAN ALL VOLKSWAGEN MOTORSPORT
539 PUJOL JOSEP CRUZ SENRA LUCAS VERBIST FRANCOIS MAN ESP VOLKSWAGEN MOTORSPORT
Henrard, supongo va con el Buggy Tarek.
He visto en un Buggie SMG también a un tal Henri Pescarolo...
Bueno! Notición!
Stéphane Henrard: "Me enorgullece el que VW haya confiado en mí"
Stéphane Henrard, primer piloto privado al que VW confía uno de sus Touareg, contestó a muchas preguntas en el parque de espera de Lisboa, algo que seguramente le habrá hecho sentir la importancia de su nueva condición. "Tengo ganas de que la carrera empiece ya mismo para poder disfrutar de este coche. Venimos preparando esta prueba desde hace ocho meses, ahora ma gustaría empezar a aprovechar el regalo que me hizo Kriss Nissen. Eramos muchos los que pretendíamos a este coche y me enorgullece el que VW haya confiado en mí. Ahora tengo que confirmar las esperanzas que depositaron en mí."
Versión del año pasado? El 2º coche será un Tarek?
a ver a ver!!!!!
