Essence of a Swiss Supersportscar
It is Sportec's professed aim to provide people with a very special kind of mobility. In order to reach this goal, they make use of all their experience and any types of technology – to define new limits of what is possible. Here in Geneva, Sportec is able to present you the essence of all their efforts, a world première: the Sportec SPR1.
A classic sports car design committed to functionality and being full of emotions constitutes the framework for innovative technologies.
The sports car’s heart is situated inside the rear end: A flat engine featuring more than 800hp. This power allows performance ratings high above the possibilities of comparable sports cars. Thus, the coupé sprints to 100km/h in 3.0 seconds, to 200km/h in 8.7 seconds and is capable of a top speed far above 380km/h.
Specially manufactured drive components and axles transfer the existing force surely to the road surface. The electrically adjustable high-performance chassis adapts itself to any requirements at the push of a button. Thereby, the driver benefits from a high degree of safety at high speeds and may enjoy convenient travelling during short or long trips. Beneath the ultra-light and classy forged rims of the classic Sportec design, a luxuriously dimensioned brake system is waiting for the customer. The negative acceleration corresponds to a stopping distance shorter than 36 metres after a speed of 100km/h.
Inside, the customer finds a clear sports car design according to the highest quality of manufacturing and material. The furnishing will be tailored entirely to the wishes of the customer who will benefit from the advice of specially trained consultants while making his choice.
The variety of possible combinations and the strict limitation to ten vehicles make each SPR1 a unique specimen. This guarantees the highest degree of exclusiveness. The SPR1 – Sportec's commitment to the desire of reaching the unreachable ideal and of achieving the maximum possible in favour their customers.
General techical data
Engine T 70
Enginetype:
6 cylinder boxer engine
Displacement:
3600 cm3
Bore / stroke:
100 x 76.4 mm
Compression ratio:
9.2 : 1
Max power (EWG):
515 kW (700 hp) bei 7200 rpm
Max torque:
810 Nm bei 4800 rpm
Boost pressure:
220 kPa - overboost 230 kPa
Engine management:
Bosch ME 7.8 / SPORTEC MFC G3.0
Fuel quality:
98 ROZ unleaded
Idle speed:
800 rpm
Max engine speed:
7350 rpm
Emissions standard:
Euro 4
Engine T 80
Enginetype:
Displacement:
3600 cm3
Bore / stroke:
100 x 76.4 mm
Compression ratio:
9.0 : 1
Max power (EWG):
590 kW (802 hp) at 8200 rpm
Max torque:
880 Nm at 4800 rpm
Boost pressure:
225 kPa - overboost 235 kPa
Engine management:
Bosch ME 7.8 / SPORTEC MFC G4.0
Fuel quality:
98 ROZ unleaded
Idle speed:
850 rpm
Max engine speed 1:
1th gear 8700 rpm
Max engine speed 2:
2th - 5 th gear 8500 rpm
Max engine speed 3:
6th gear 8300 rpm
Emissions standard:
Euro 4
Power transmisson
gear ratios:
1. gear 3,82
2. gear 2,05
3. gear 1,41
4. gear 1,12
5. gear 0,92
6. gear 0,75
reverse gear 2,86
final drive ratio: 3,44
speed at 1000 rpm in 6th gear: 49.5 km/h
clutch disc diameter: 240 mm
Chassis
front axle front axle with light alloy links and McPherson struts, Unibal supported rear axle rear axle multilink suspension, Unibal supported steering electro power steering
steering ratio 1:16.9
steering from lock to lock 2,98
brakes front 8-piston light alloy caliper
rear 4-piston light alloy caliper
brake discs front drilled steel disc 380 x 34 mm
rear drilled steel disc 322 x 28 mm
wheels front 9Jx20“ offset 30
rear 12.5Jx20“ offset 40
tires front 255/30 R20 92Y XL
rear 345/25 R20 100Y
Weights
T 70: curb weight DIN (depend on equipment) 1360 kg
T 80: curb weight DIN (depend on equipment) 1345 kg
weight ratio front / rear 40% : 60%
gross weight 1700 kg
limited weight front axle 730 kg
limited weight rear axle 1110 kg
tank capacity: 64l
Dimensions
length 4467 mm
width 1878 mm
height 1275 mm
wheelbase 2350 mm
track front 1550 mm
rear 1564 mm
Performance T70 (depend on equipment)
Max speed (depend on equipment) 364km/h
acceleration 0 - 100 km/h 3.2 s
acceleration 0 - 200 km/h 9.5 s
acceleration 0 - 300 km/h 21.1 s
power / weight ratio 1.94 kg/hp - 2.64 kg/kW
power / litre 194 hp/l - 143kW/l
Consumption
urban: 17.6l
exurban: 9.3l
overall: 13.7l
CO2-emissons: 302g
Performance T80 (depend on equipment)
Max speed (depend on equipment) > 380km/h
acceleration 0 - 100 km/h 3.0 s
acceleration 0 - 200 km/h 8.6 s
acceleration 0 - 300 km/h 18.9 s
power / weight ratio 1.68 kg/hp - 2.28 kg/kW
power / litre 223 hp/l - 164kW/l
Fotos de esta Bestia
Eso se denomina de una manera: BRUTALIDAD!!
Ver eso en la autopista tiene que ser impresionante :clap1:
Mi pregunta es: si te compras este coche, a cuánto les pagarán la base a los de Porsche? Es para hacerme una idea de lo que se puede ganar en esta preparación.
Salu2
