jose5005 Publicado 20 de Marzo del 2006 Denunciar Compartir Publicado 20 de Marzo del 2006 Si alguien tiene idea de que puede ser pongo aqui el codigo de error he probado en borrarlo pero sigue apareciendo, se enciende el testigo a los 4 ó 5 minutos de arrancar. Bueno pongo todos los errores pero solo me preocupa el del ESP. Alguien con el mismo problema?. Un saludo. VAG-COM Version: Release 311.2-N Chassis Type: 8L - Audi A3/S3 Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56 Address 01 ------------------------------------------------------- Controller: 038 906 019 CK Component: 1,9l R4 EDC G400SG 1343 Coding: 00002 Shop #: WSC 06435 WAUZZZ8L42A003039 AUZ7Z0A1884649 No fault code found. Address 03 ------------------------------------------------------- Controller: 1C0 907 379 E Component: ESP FRONT MK60 0104 Coding: 0019970 Shop #: WSC 06435 No fault code found. Address 08 ------------------------------------------------------- Controller: 8L0 820 043 H Component: A3 KLIMAAUTOMAT 0105 Coding: 00043 Shop #: WSC 06435 No Faults Found or DTCs not supported by controller or a communication error ocurred Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8L0 920 932 L Component: KOMBI+WEGFAHRS. VDO D07 Coding: 07140 Shop #: WSC 00310 WAUZZZ8L42A003039 AUZ7Z0A1884649 No fault code found. Address 35 ------------------------------------------------------- Controller: 8D0 862 257 Component: ZV-Pumpe, DWA, Funk D16 Coding: 15179 Shop #: WSC 06435 4 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00956 - Key 2 09-00 - Adaptation Limit Surpassed Address 45 ------------------------------------------------------- Controller: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 00000 No fault code found. End ------------------------------------------------------- Responder Enlace al comentario Compartir en otros sitios web More sharing options...
michobicho Publicado 21 de Marzo del 2006 Denunciar Compartir Publicado 21 de Marzo del 2006 no tienes ningun error del esp al menos aqui no lo pones Responder Enlace al comentario Compartir en otros sitios web More sharing options...
jose5005 Publicado 21 de Marzo del 2006 Autor Denunciar Compartir Publicado 21 de Marzo del 2006 (editado) no tienes ningun error del esp al menos aqui no lo pones Volveré a hacer el test, el caso es que a los 4 ó 5 minutos se me desconecta el ESP. No se que será. Un saludo Editado 21 de Marzo del 2006 por jose5005 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
michobicho Publicado 21 de Marzo del 2006 Denunciar Compartir Publicado 21 de Marzo del 2006 se supone que el boton de desconexion lo tienes desconectado digo yo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
