yentini Publicado 10 de Abril del 2006 Denunciar Compartir Publicado 10 de Abril del 2006 Quería saber si alguién que haya conectado el VAG-COM en un Audi A3II, ha podido ver el siguiente menú, en particular la opción en rojo..... Control Module Coding Select 09 (Central Electronics) Coding -> Function 07 NOTE: This control module uses a long coding. Bytes 4 and 17-20 are only avialiable for cars from calendar week 45/2004. Byte 00 Bit 0 Fog Lights installed (PR-8WB) Byte 00 Bit 1 Xenon Headlights installed Byte 00 Bit 2 Footwell Lights installed (PR-QQ4) Byte 00 Bit 3 Daytime Running Lights (Scandinavia) Byte 00 Bit 4 Daytime Running Lights (North America) Byte 00 Bit 5 Assistance Driving Light & Leaving Home Byte 00 Bit 6 Rain/Light Sensor installed Byte 00 Bit 7 Coming-Home Byte 01 Bit 0 Rear Seat Recognition installed Byte 01 Bit 1 Headlight Washer installed (PR-8X1) Byte 01 Bit 2 Electronic Fuelpump Relay installed (Gasonline only) Byte 01 Bit 3 Rear Wiper installed Byte 01 Bit 4 Heated Side Mirror installed Byte 01 Bit 5 Rear Lid Remote Opening Byte 01 Bit 6 Rear Lid Remote Opening - Release Byte 01 Bit 7 Rear Wiper with Front Wiper continiously active Byte 02 Bit 0 Rear Wiper with Front Wiper intermittent active Byte 02 Bit 1 Comfort Turn Signals Byte 02 Bit 2 Cold Lamp Diagnosis active Byte 02 Bit 3 Load Management active Byte 02 Bit 4 Coming-Home via(1 = Potentiometer / 0 = Adaptation) Byte 02 Bit 5 Rear Lid Remote Openening(1 = Contact activated / 0 = Impuls activated) Byte 02 Bit 6 Side Turn Signal Lights installed Byte 02 Bit 7 Seat Heating installed (PR-4A3/4A4) Byte 03 Bit 0 Realy Terminal 15 installed (with 2nd Battery) Byte 03 Bit 1 Rear Fog Lights (1 = 1 active / 0 = 2 active) Byte 03 Bit 2 Reverse Driving Lights (1 = 1 active / 0 = 2 active) Byte 03 Bit 3 Reverse Driving Light off when Rear Lid open Byte 03 Bit 4 Xenon-Shutter installed (Bi-Xenon) Byte 03 Bit 5 Teardrop Wiping active Byte 03 Bit 6 2nd Battery installed Byte 03 Bit 7 Rear Lights (1 = Back Light/Brake Light dimmed / 0 = Back Light dimmed) Byte 04 Bit 0 Auxiliary Heating installed Byte 04 Bit 1 Auxiliary Heating installed Byte 04 Bit 2 Trailer/Towing Device installed Byte 04 Bit 3 Memory Seats installed Byte 04 Bit 4 Activation of both Rear Fog Lights Byte 04 Bit 5 Model (0 = Right Hand Drive / 1 = Left Hand Drive) Byte 04 Bit 6 Rear Fog Lights deactivated Byte 04 Bit 7 Climatronic installed Byte 05 Headlight Washer Delay (Standard: 1000 ms / Resolution: 50 ms) Byte 06 Headlight Washer Activation Time (Standard: 800 ms / Resolution: 50 ms) Byte 07 Extra Function: Turn Signal Front left/right as Parking Light Front left/right (USA and Canada) Byte 08 Extra Function: Low Beam left/right as Daytime Running Light - Scandinavia (Standard: 0%) Byte 09 Extra Function: Brake Light left/right Rear as Parking Light (Standard: 18%) Byte 10 Extra Function: Rear Fog Light left/right as Parking Light (Standard: 12%) Byte 11 Extra Function: Front Parking Light left/right (Standard: 0%) Byte 12 Extra Function: Rear Parking Light left/right (Standard: 0%) Byte 13 Replacement Function: Front Side Turn Signal left/right as Front Parking Light (Standard: 0%) Byte 14 Replacement Function: Front Parking Light left/right as Side Turn Signals left/right (Standard: 0%) Byte 15 Replacement Function: Rear Light left/right as Side Turn Signals left/right (Standard: 0%) Byte 16 Replacement Function: Front Fog Lights left/right as Low Beam Headlight left/right (Standard: 0%) Byte 17 Bit 0 Ermergency Brake Flash Light active Byte 17 Bit 1 Deactivation of Additional High Beam with Bi-Xenon Byte 17 Bit 2 Heated Front Window installed Byte 17 Bit 3 Diagnostics Terminal 50 active Byte 17 Bit 4 Daylight Running Light with dimmed Low Beam Byte 17 Bit 5 Front Fog Lights deactivated with High Beam Byte 17 Bit 6 Parking Light Function inactive (USA/Canada) Byte 17 Bit 7 reserved Byte 18 Bit 0 Cold Diagnosis License Plate Lights active Byte 18 Bit 1 Cold Diagnosis Brake Lights active Byte 18 Bit 2 Cold Diagnosis Front Fog Lights active Byte 18 Bit 3 Cold Diagnosis Rear Fog Lights active Byte 18 Bit 4 Cold Diagnosis High Beam active Byte 18 Bit 5 Cold Diagnosis Turn Signals active Byte 18 Bit 6 Cold Diagnosis Back Light active Byte 18 Bit 7 Cold Diagnosis Side Turn Signals active Byte 19 Bit 0 Cold Diagnosis Low Beam active Byte 19 Bit 1 Cold Diagnosis Front Parking Lights active Byte 19 Bit 2 Cold Diagnosis Rear Parking Lights active Byte 19 Bit 3 Diagnosis Rear Parking Lights active Byte 19 Bit 4 unknown/unused Byte 19 Bit 5 unknown/unused Byte 19 Bit 6 unknown/unused Byte 19 Bit 7 unknown/unused Byte 20 unknown/unused Muchas gracias!! Responder Enlace al comentario Compartir en otros sitios web More sharing options...
yentini Publicado 11 de Abril del 2006 Autor Denunciar Compartir Publicado 11 de Abril del 2006 A ver si alguién me puede decir algo........ en el taller con la máquina BOSCH, no se pueden acceder a la mayoría de menús..... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
