The “RK Coupé” is the natural evolution of the RKSpyder which was presented in summer 2005. It is the perfect blend between German technology and Italian style. It will be limited to 49 vehicles and available also in the US .
The most striking feature of this custom-built car is its subtle and yet massive changes that are equally noticeable and unnoticeable. The design gives the car its well-balanced uniqueness and beauty.
The 440 horse power Coupé blends the balance of a mid engine power plant with chassis stiffness elegant curve lines and the perfect handling to make the “RK Coupé” a truly world class performer.
The RK stands for RUF KOMPRESSOR. The basis of this compressor engine is a centrifugal compressor with a planetary gearbox –a kind of mechanical turbo charger, which is driven mechanically by a Poly-Rip belt. The maximum boost is 0.7 bar. The engine has RUF designed intake manifolds with integrated intercoolers, new injectors, sports catalytic converters and a RUF electronic engine management system. The water-cooled charge cooler has a cooling water circuit with an electric water pump from the water cooler in the front spoiler.
The supercharged 3.8 litre engine of the RUF RK Coupé provides a 440 bhp (324 kW) at 7,000 RPM and 470 Nm torque at 5,500 RPM.
The acceleration from 0 – 100 km/h (0 – 62 mph) of the 3.8 litre RK Coupé with a RUF compressor engine takes only 4.3 sec., from 0 – 200 km/h (0 – 125 mph) only 13.0 sec. The maximum speed is 304 km/h (190 mph).
The base price of the RKcoupé is €190.000 (plus tax), approx. $245.000 (plus tax).
RK Coupe Technical Specifications
Constructor : RUF Automobile GmbH
Coachbuilder: STUDIOTORINO
ENGINE
Type
6 cylinders RUF Kompressor
Valves
4 x cylinder
Volume
3824 cm3
Power
440 bhp (324 kW) @ 7000 rpm
Torque
470 Nm @ 5500 rpm
Front brakes
Discs: 350 x 34 mm, Brembo-6-piston-caliper
Rear brakes
Discs: 299 x 24 mm, Brembo-4-piston-caliper
Front tyres
Dunlop SP Sport Maxx 235/35 ZR 19
Rear tyres
Dunlop SP Sport Maxx 275/35 ZR 19
Empty weight
1365 kg
Length x width x height
4329 x 1801 x 1250 mm
Wheel base
2415 mm
Front track
1525 mm
Rear track
1525 mm
ACCELERATION
0 – 100 km/h (0 – 62 mph) 4,3 s
0 – 200 km/h (0 – 125 mph)13,0
Max. speed
304 km/h (190 mph)
Igualito que el que tiene mi padre aparcado en casita :kss1::):bsh1::p
Muy bonito :) y muy buena argumentacion :kss1:
impresionante, muy bruto, tiene pinta de mala leche. Esas llantas negras tienen la culpa entre otras cosas... :lol2:
salu2
No me suelen gustar mucho las llantas negras pero en este modelo la verdad es que quedan fenomenal, de todos modos creo que ganaría estéticamente incluso más con otras llantas.
