Earenas Publicado 30 de Septiembre del 2006 Denunciar Publicado 30 de Septiembre del 2006 [code]AG-COM Version: Release 311.2-NChassis Type: 8E - Audi A4 B6Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76Address 01 ------------------------------------------------------- Controller: 038 906 019 JQ Component: 1,9l R4 EDC 0000SG 1570 Coding: 00002 Shop #: WSC 63351 WAUZZZ8E83A289268 AUZ6Z0B0456554No fault code found.Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 1729 Coding: 04255 Shop #: WSC 06435No fault code found.Address 08 ------------------------------------------------------- Controller: 8E0 820 043 J Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 633516 Faults Found:00710 - Defroster Flap Positioning Motor (V107) 41-10 - Blocked or No Voltage - Intermittent00727 - Potentiometer in Positioning Motor for Defrost Flap (G135) 30-10 - Open or Short to B+ - Intermittent01809 - Actuating Motor for Temperature Flap: Left (V158) 41-10 - Blocked or No Voltage - Intermittent01810 - Actuating Motor for Temperature Flap: Right (V159) 41-10 - Blocked or No Voltage - Intermittent01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-10 - Open or Short to B+ - IntermittentAddress 09 ------------------------------------------------------- Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0203 Coding: 00001 Shop #: WSC 63351No fault code found.Skipping Address 15-AirbagsAddress 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00001 Shop #: WSC 63351No fault code found.Address 17 ------------------------------------------------------- Controller: 8E0 920 900 K Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 00000 Shop #: WSC 04808 WAUZZZ8E83A289268 AUZ6Z0B04565541 Fault Found:01304 - Radio 49-00 - No CommunicationsAddress 46 ------------------------------------------------------- Controller: 8E0 959 433 AR Component: Komfortgerát T85 1310 Coding: 06720 Shop #: WSC 63351No fault code found.End -------------------------------------------------------[/code] Esto es lo que me dice el autoanalisis, luego no me deja entrar en los modulos de navegador ni de la radio... Alguien puede traducirmelos a algo mas cristiano por favor... S2 Responder
Earenas Publicado 3 de Octubre del 2006 Autor Denunciar Publicado 3 de Octubre del 2006 ¿En serio nadie puede contestarme? Por favor... solo necesito que alguien con el etka o el elsaWin instalado me diga que es y si lo puedo hacer yo mismo. S2 Responder
