VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 JL
Component: 1,9l R4 EDC 0000SG 1519
Coding: 00002
Shop #: WSC 63351
WAUZZZ8EX2A243973 AUZ6Z0B0008174
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 A
Component: A4 Klimaautomat 1012
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
01810 - Actuating Motor for Temperature Flap: Right (V159)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
1 Fault Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 00000
Shop #: WSC 04243
2 Faults Found:
00668 - Supply Voltage Terminal 30
01304 - Radio
49-00 - No Communications
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AG
Component: Komfortgerát T87 0315
Coding: 06720
Shop #: WSC 63351
3 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
01331 - Door Control Module: Driver Side (J386)
80-10 - Single-Wire Operation - Intermittent
01332 - Door Control Module: Passenger Side (J387)
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
3 Faults Found:
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
30-00 - Open or Short to B+
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
07-10 - Signal to Low - Intermittent
End -------------------------------------------------------
Datos:
- El coche se me quedo sin bateria.
- Me sale en el cuadro FIS la advertencia de la regulaccion automatica de faros.
Dudas.
- Que puedo hacer para solucionar esto.
- ¿Pasa algo si borro los fallos todos?
Te lo acaban de contestar. Al desembornar, se registran muuuuchos errores. Ten en cuenta que si tienes un error, el hecho borrarlos no implica que te los cargues. Te volveran a salir, asi que borra todo, limpia y observa los que te quedan tras darte una vueltecita. Esos seran los importantes.
Pues eso, lo hice y ya quedan menos.
Radio no comucation y uno del clima que no estoi seguro si habia borrado antes.
El de rango de xenon, tuve que ajustarlo para que desapareciera el error.
Y mañana u pasado le vuelvo a pasar el vagcom
Graciassssssss
